      02-21-2009, 12:59 AM   #1
The_Blob
The_Blob's Avatar
503
Drives: 2008 E92 335i
Smoothness of zoom rings
I have a Nikon AF Nikkor 28-200mm 1:3.5-5.6D (made in Japan), and I just realized that the zoom ring isn't super smooth when zooming and in out. Zooming feels a bit heavy, and it's not like ball bearing smooth like on some low end lenses. It's a used lense so I don't know if it's normal or not. Anyone here have the same issue with their Nikon lenses? I would suspect a smoother zooming feel for this mid ranged priced lense.
      02-21-2009, 02:21 AM   #2
asdflkijd
Aberry is a scammer
asdflkijd's Avatar
Drives: SGM E92 335i, AM E90 335i
Hmm, I have a 28-135mm Canon and it feels a little heavier compared to the 18-55mm.. Have you tried testing the same lens at an electronics store? My hunch is that it just feels heavier because of the weight/ material (metal vs plastic)..
      02-21-2009, 02:31 AM   #3
rodi
188
Drives: your FACE!
try the pro lenses (f/2.8 zooms).
2009 135i | space grey | sport | navi | hifi | heated
dinan stage 2 software | bmw performance exhaust
kw v2 | hotchkis front sway | vmr v710
      02-21-2009, 04:14 AM   #4
TWiTCHY
TWiTCHY's Avatar
Drives: '13 AW E92 M3
I recently tried out a new Nikon 17-55mm f/2.8 at a store then bought a used one the day after. The newer ones are noticeably stiffer. It seems like you have to break in the zoom ring and after a couple of uses it should be a bit looser. The used one I bought wasn't as bad as the new one at the store.
      02-21-2009, 01:06 PM   #5
The_Blob
The_Blob's Avatar
503
The Nikon AF Nikkor 28-200mm 1:3.5-5.6D has been discontinued so I couldn't try it at a store selling new lenses. It's one of those heavier metal construction lenses. I guess that could be the case why it's not like ball bearing smooth when I zoom in and out.
      02-23-2009, 12:18 AM   #6
The_Blob
The_Blob's Avatar
503
I just read a reivew of a similar lens http://www.bythom.com/18200lens.htm and I know why it's a bit stiff and rough while zooming
"The zoom ring is stiff and has a very different feel at different focal lengths (I should note that some users claim it is loose and subject to zoom creep; that isn't the case on my sample). As you zoom in to 200mm, the zoom ring has a sudden "loose point" just before you get to the maximum focal length. Zooming the other direction is smoother, though still what I'd call rough."
I guess having a fairly stiff zoom ring handling is a good thing to prevent zoom creep when shooting photos upwards or downwards.
However, when I zoom in or out of the lense still creates a very tiny dry screeching noise. Anyone else have a similar issue their lenses while zooming?
