      02-23-2009, 10:47 PM   #1
Prissy
Prissy's Avatar
Taiwan
1091
Drives: M340i
2015 BMW F30  [5.50]
2020 M340I  [0.00]
2017 X3  [0.00]
2008 BMW E92  [9.00]
2010 BMW E92  [10.00]
Need Help from Expert/IT
I am having this screen resolution problem after reformatting... I have a HDTV(1080p) hooked up to my computer as secondary/primary monitor, but now I can't fit the picture to screen on my HDTV, I can only fit to screen with 1152 by 648, if I pick 1280 by 1024 the picture would only show in the middle of the screen. And for my computer monitor if I pick any other resolution besides 1280 by 1024 the picture would like very weird and distorted, it was never like this before... Can anyone help? Thanks
      02-23-2009, 11:02 PM   #2
danniexi
danniexi's Avatar
Drives: 2022 F97 X3M Comp LCI
1080p = 1920 X 1080
720p = 1360 X 768
BMW MY22 F97 X3MC LCI - CURRENT BUILD THREAD| Instagram: @danniexi
BMW MY16 F80 M3 - GONE
BMW MY08 E92 335XI - GONE
BMW MY06 E46 325XI - GONE
      02-23-2009, 11:11 PM   #3
lowcash_dreamcar
lowcash_dreamcar's Avatar
Drives: his bimmer like it should be
2008 328i Coupe  [0.00]
Is there a Full Screen option that might help? Or check if the TV is set to display in 16:9 mode.
I have a macbook and I have hooked mine onto different sized HDTV's without an issue. And I believe I 'Fit to Screen' kinda always put it at the center with black boundaries..
      02-23-2009, 11:21 PM   #4
danniexi
danniexi's Avatar
Originally Posted by Phiberglass View Post
I would stay away from a TV as a monitor at all costs, but good luck.
Why do you say that? I'm genuinely interested since I've been using my LCD (sony xbr4) for a while now.
As for OP, just make sure the pixels are either of those sizes. No other sizes (that are not 16 x 9) will work.
      02-24-2009, 12:42 AM   #5
sinnet112
Drives: 2009 E89 Z4
Don't know what brand of TV it is, but I do know all of my Samsungs have a Wide TV versus a Wide PC view/zoom. The Wide PC angle lets you see everything.
Z4 sdrive30i | Deep Sea Blue | Ivory White Nappa Extended Leather | ZSP
      02-24-2009, 02:42 AM   #6
at_boy
at_boy's Avatar
China
15
Originally Posted by danniexi View Post
1080p = 1920 X 1080
720p = 1360 X 768
he was right
MY screen was 1024 764
笑吧 笑吧 这样你就能得到全世界吗?FUNNY?Can you get the world by your laugh?SHOW
      02-24-2009, 09:37 AM   #7
Prissy
Prissy's Avatar
Taiwan
1091
Drives: M340i
2015 BMW F30  [5.50]
2020 M340I  [0.00]
2017 X3  [0.00]
2008 BMW E92  [9.00]
full screen only works when I set it to 1152 by 648, it will not work with any other resolutions...
Tv as monitor rockss
How do I check that?
ya I have a Samsungs, it's a great Tv but the remote just stinks.
      02-24-2009, 09:42 AM   #8
Prissy
Prissy's Avatar
Taiwan
1091
Drives: M340i
2015 BMW F30  [5.50]
2020 M340I  [0.00]
2017 X3  [0.00]
2008 BMW E92  [9.00]
I am thinking to reinstall my driver...
      02-24-2009, 12:09 PM   #9
danniexi
danniexi's Avatar
16 X 9 is the aspect ratio which is exactly what it means... a ratio.
For example: 1920 X 1080 to its lowest common denominator is 16 X 9. Any pixel ratio that follows this ratio (widescreen) should be fine for your TV. 1152 X 648 works as well (divide 648 by 9 which = 72, 1152 divided by 72 = 16).
Try the pixel ratios that I have given to you earlier (1920 X 1080 or 1360 X 768) to your TV.
Unless you have a really really old video card, your current video card should work. Update the drivers and try again. If you can't set your secondary monitor (aka your TV) to a pixel ratio of 1360 X 768 or higher, get a new video card (newegg is your best friend). Make sure the video card has two dvi-ports for multi screens.
I'm actually doing this for my home theater project (computer monitor on table for general internet browing with a secondary monitor for my movies).
Hope this helps. And by all means, if I am incorrect, somebody please correct me.
      02-24-2009, 01:35 PM   #10
sinnet112
Drives: 2009 E89 Z4
Once you're in VGA/DVI source, hit P.Size on it a few times until it says Wide PC, see if that helps.
      02-24-2009, 02:43 PM   #11
Prissy
Prissy's Avatar
Taiwan
1091
Drives: M340i
2015 BMW F30  [5.50]
2020 M340I  [0.00]
2017 X3  [0.00]
2008 BMW E92  [9.00]
I am sure you are correct, it was working fine before I reformatted... I somehow installed the wrong video driver, although i switched it back to the original driver, maybe this is why it's causing me problem now.
      02-24-2009, 02:44 PM   #12
Prissy
Prissy's Avatar
Taiwan
1091
Drives: M340i
2015 BMW F30  [5.50]
2020 M340I  [0.00]
2017 X3  [0.00]
2008 BMW E92  [9.00]
all the options with "PC" in my TV has been grayed out... wasn't like this before I reformatted the computer.
      02-25-2009, 01:27 AM   #13
boymonkey
Taiwan
41
Drives: slow
Formatting your PC shouldn't affect your TV or the options on it... If the options are grayed out, maybe you are not plugged in to the VGA/PC port? If you're just plugging in HDMI or S-Video, the TV might not know it's a PC source and won't give you PC options.
Like danniexi said, HDTV/widescreen is 16:9 ratio. 16/9=1.78. Use a ratio that divides to the same number 1.78, or the image will be stretched to fit your TV.
After you format your PC, you should definitely reinstall the video card drivers. I recommend getting the latest version of the drivers from the web. It will give your more functionality than what came on a disc. Download and run the installer for the drivers, and that should fix your driver version problems.
      02-25-2009, 02:38 AM   #14
darkphantom
Drives: E93 335i
1920x1200 = 1200P
