Car still rolls forward when in gear
03-28-2009, 01:54 PM | #1 |
Rep 7,000
Following my experience with the car rolling off the handbrake and crashing the following happened today.
Parked car on an average hill and turned off the engine. Put in to first gear with the clutch de-activated. Handbrake off and the car moved slightly as it engaged with the first gear, as to be expected. Then after about 10 seconds it moved forward very slightly and stopped, it did this about 6 times over a minute and moved about 8 inches. How wierd is that. Put it into reverse and it did the same thing, how is this possible. |
03-28-2009, 01:58 PM | #2 |
Rep 7,519
Drives: 2009 E90 335i MT
Put the handbrake on whenever you're not in the car.
2009 E90 335i Montego Blue · Black Leather · Burl Walnut · 6MT · US Spec
SatNav • ZPP • ZCW • 6FL • TPMS • iDrive • PDC • HWS • Xenons • BMW Assist • Power Rear Sunshade • Logic 7 European Taillights • Rear Foglamp • OEM Alarm • PicoTray • DataToys XM-DVR • Multi-view Processor Quaife ATB LSD • Short Shift Knob • Hartge Anti-Roll Bars • AP Racing Front Brakes • 19" Style 269 |
03-28-2009, 02:04 PM | #4 |
Rep 896
I always thought you incident was weird - when I park mine on a hill, when I take the handbrake off, it still won't roll off - I have to drive it away, against some braking resistance. I assumed it was some kind of extra safety, in case the handbrake comes of accidentally.
Phil
03-28-2009, 02:23 PM | #7 |
Rep 7,519
Which one, a car rolling while in gear or someone parking over the edge of Beachy Head?
03-28-2009, 02:27 PM | #8 |
Rep 7,000
I am gonna find another hill and see if it will do it again, if it does will speak to BMW.
For the last 23 years I always thought that if it was in gear it was going nowhere. |
03-28-2009, 03:03 PM | #9 | |
Rep 8,972
In-gear is just trying to turn the engine over using the cars weight. It will push the engine round slowly as compression leaks by the piston rings. Same in any manual car ever built. Reverse is the lowest gear so its the hardest to turn the engine. 1st is similar. Someone said 3rd, but thats even easier to roll away.. In reverse, rolling forward is turning the engine backwards BTW... An auto-box in park physically locks the transmission, which is different to a manual. |
03-28-2009, 03:29 PM | #11 |
Rep 3,899
Best advice when parked on a hill is to turn the front wheels towards the
kerb. Even if everything fails and the car rolls , the car will not roll back on an incline or forward on a decline as it will be stopped when the rear or front wheels hit the kerb. Hope you get your car sorted. |
03-28-2009, 03:33 PM | #12 | |
Rep 7,000
03-29-2009, 03:26 PM | #13 |
The Tarmac Terrorist
958
Rep 29,345
Drives: 997.2 GT3
Did this last night.
Miswah tiny little Opel thing, worried bout handbrake i asked her to test leaving it in gear and it did exactly same.
997.2 GT3
