05-02-2009, 04:34 PM | #1 |
Rep 2,829
Night Shoots are difficult.....pics!
Did my first night shoot here, which was only my second shoot ever. Anyway, very difficult. Out of 100+ shots these are the only ones I dare show to anyone Shot with Nikon D40 and kit lens on"bulb" mode.
05-02-2009, 05:07 PM | #2 |
Rep 9,783
It is difficult- especially for those kind of pictures. That's why it's usually recommended that you shoot right after sunrise or before sunset. Try shooting the Bay Bridge around 6:30-7:15PM. You will get much better views of the bridge as well as the city.
05-02-2009, 05:10 PM | #3 |
Rep 2,829
Yea I know. Just wanted to get that late night look. Oh well....will try again as my skills improve.
05-02-2009, 05:54 PM | #4 |
Rep 1,730
did you have a tripod? did you use the timer release? looks like they're still a bit blurry from some camera motion.
2018 Grigio Telesto F80 M3 DCT | :: Bone Stock :: 2004 Titanium Silver E46 M3 6 Speed | :: Track Car :: |
05-02-2009, 05:55 PM | #5 | |
Rep 10,584
did u try -set ISO to as low as possible...say iso 100 -use tripod -use IR remote -set to Apt priority -focus to the spot you want and then shutter release w/ remote -adjust exposure after a few shots to fine tune your shots thats all I normally do, sometimes put it full manual but mostly apt priority. keep playing around. Also, looks like you need to play with white balance as well. Ex of shot using above "technique" taken at night last week.
05-02-2009, 06:16 PM | #6 |
_________________
55
Rep 3,584
if all else fails, you can always try adjusting during post-process. i did some quick editing on your pic via adobe lightroom and came up with this:
05-02-2009, 06:31 PM | #7 |
Bootleggin' 'n Gunrunnin'
155
Rep 2,372
Not sure exactly which lens you are using, but if it has VR (Vibration Reduction), turn it off when using a tripod.
The thing is, you are out there experimenting with the camera and trying different things. Take some notes on settings and lighting conditions, and your shots will improve.
Scott
2024 G01 X3 M40i, Brooklyn Grey Metallic /// 2015 F15 X5 35i, Space Gray Metallic, 99K miles /// 2013 F30 320xi, Mojave Metallic, 112k miles 2019 Ford F450 STX, Oxford White 2013 Ducati Multistrada Touring S, Red |
05-02-2009, 06:42 PM | #8 |
Rep 2,829
Thanks for all the tips folks. I did use a tripod. Not sure which settings. need to be better at taking notes I also tweaked these pics in Capture NX2. May try Lightroom out.
05-02-2009, 07:16 PM | #10 | |
Rep 619
05-02-2009, 07:37 PM | #11 | |
155
Rep 2,372
But then again, I guess it depends on your objective for the image. If you want it to look like what your eye sees at the time, then it should stay yellowish. If you want the color to render more true, then you need to correct it.
Scott
05-02-2009, 07:45 PM | #12 |
Rep 619
i usually set the wb in light room. i cant stand the yellow light both in pics or with my eyes. just doesn't seem natural.
05-02-2009, 10:27 PM | #13 | |
Ski bum
333
Rep 6,198
In this case there were sodium vapor lights, which are extremely yellow and harsh. I've had better luck with the night shots on a clear night with a full, or close to full moon. I go with ISO 800 or so (higher ISO numbers are more sensitive to light, but can have more noise, depending on your camera), f4 or f2.8, depending on the lens, and a very well stabilized tripod. Use your timer if you don't have a remote, it will help with the camera shake. Lastly, you can play around with HDR if you don't want to take the time to do things in the field. If you really want to get creative, realize the key to excellent photography is really understading light capture. The best subject / composition will suck if you don't know how to capture the light. Conversly, you can do really cool stuff with absolutely nothing if you understand filters, white balance and light capture. So, with your shutter set to 15-30 seconds, you can have a lot of fun with external light sources. I've done some shoots where there is almost no light, and I'll use a mega heavy duty flashlight (4 cell LED maglite) or one of those 1,000,000 candle power flood/spot lights and use it to "paint" the car. You can do highlights with it by focusing and holding the light on a particular spot for a period of time. I've also used my speedlight in a full manual configuration off the hotshoe where I'll manually fire the light via the button on the back (most speedlights have these). You can get different effects using different types of light (xenon flash, incandecent flood, LED maglite) on a given white balance setting, so play around a lot! Have fun, the most important thing is to get out there and make some images. This is a very important time to take notes, becuase none of what you do will be recorded in the exif data.
1999 e46 328i Ti Silver / Black[retired] 2007 e90 335xi Jet Black / Black[retired] 2011 e70 X5 35d Vermillion Red / Cinnamon 2011 e92 M3 LeMans / Fox Red extended |
06-04-2010, 06:55 PM | #14 |
Rep 954
a lot of people mentioned using a shutter release trigger while working with a tripod at night. To cut down on cost, I'd say just put the camera on self timer (the 10 seconds can be spared to not have any camera shake while pressing the shutter button).
in the above photos, it seem like the camera just didn't catch focus a few times (usually the case @ night). |
06-05-2010, 12:29 PM | #15 |
Rep 3,435
Holy old thread batman.
To add to it (if it matters), don't forget your whitebalance. Adjusting the whitebalance to the correct setting for whatever lighting you are under will help make this orange pictures clear and white. Try to stay away from shooting under mixed lighting. Using the self timer does help too when you dont have a shutter release. |
