Gear ratios and gas mileage
07-28-2006, 09:52 PM | #1 |
Rep 80
I don't fully understand what the gear ratios mean, but I had a question about how the gears affect fuel efficiency. Aside from the obvious that the revs lower as you shift to a higher gear, how does driving in one gear versus another affect gas mileage. Will driving in 6th at 2k rpms give you better fuel economy than driving in 5th at 2.5k rpms? Personally, I like to keep the car closer to 3k all the time because I like having the power available without having to downshift. Am I losing fuel efficiency because of this?
Thanks, Rich |
07-29-2006, 04:05 AM | #2 | |
Rep 9,218
07-29-2006, 05:31 AM | #3 | |
Rep 7,519
Drives: 2009 E90 335i MT
On the US 330i, 1st gear is 4.35:1, 2nd is 2.50:1, 3rd is 1.67:1, 4th is 1.23:1, 5th is 1.00:1, and 6th is 0.85:1. Take 5th gear for example. For every 1.00 revolutions of the crankshaft, the rear wheels will make 1 revolution. If the wheel is 1 meter in diameter (for explanation purposes only) and the engine is running at 2500 rpm, then you move down the road 2500 meters in one minute. In 6th gear at 2000 rpm you move 2,353 meters. However, in one minute the engine has fired 15,000 times in 5th gear vs. 12,000 times in 6th. The engine has fired 25% more to go a mere 6% further. To paraphrase needforspeed, the higher the gear and lower the rpms the better the fuel economy. Grant you, you won't get 50% economy driving strictly 6th gear as you would in 5th because there are other factors that actually cause a greater load on the engine. For example, an engine running at 2000 rpm moving a heavy load will use more fuel to maintain that 2000 rpm than an engine moving a lighter load at the same rate or even moving a given load up a hill at 2000 rpm compared to the same load and rpm on a level road. Don't try driving long distances in reverse and expect good gas mileage. Its ratio is 3.93:1. You'll be mighty disappointed. Not to mention tired.
2009 E90 335i Montego Blue · Black Leather · Burl Walnut · 6MT · US Spec
SatNav • ZPP • ZCW • 6FL • TPMS • iDrive • PDC • HWS • Xenons • BMW Assist • Power Rear Sunshade • Logic 7 European Taillights • Rear Foglamp • OEM Alarm • PicoTray • DataToys XM-DVR • Multi-view Processor Quaife ATB LSD • Short Shift Knob • Hartge Anti-Roll Bars • AP Racing Front Brakes • 19" Style 269 |
07-29-2006, 08:00 AM | #4 |
Rep 18,858
watch your MPG gague as you drive... youll figure out how your driving affects the economy...
sometimes, the higher gear is not the best economy. If your cruising on a flat road it will help you. If your going uphill and you are hard on the throttle in 6th gear, you can use more fuel than if you were in 5th because of the strain you are putting on the engine... |
07-29-2006, 11:05 AM | #5 |
Rep 519
Follow up question: someone here once mentioned that it's better (solely from a gas mileage perspective) to coast down a hill in a gear vs. in neutral. The argument was that, despite the higher RPM when in gear, the turning wheels were keeping the engine at that RPM, versus neutral where the engine was doing all the work keeping itself at idle.
Is there truth to this? I tend to think that higher RPM results in higher fuel consumption.
'14 535i (ED)
Retired: '08 M5, '08 550i (ED), '06 330i |
07-29-2006, 11:15 AM | #6 | |
Rep 4,838
07-29-2006, 11:21 AM | #7 |
Rep 519
That is very interesting, and implies that RPMs are not directly correlated to fuel efficiency, but rather the source of the RPM.
I guess it makes sense from a common sense perspective. Going down a hill at a constant speed in 2nd @ 4k is basically using gravity to move the car. Going up a hill at a constant speed in 2nd @ 4k is using all fuel to move the car. In the downhill/no throttle case, then, is there no gas being fed into the engine?
'14 535i (ED)
07-29-2006, 11:32 AM | #8 | |
Rep 4,838
07-29-2006, 11:35 AM | #9 | |
Rep 9,218
07-29-2006, 11:50 AM | #10 |
Rep 178
The August issue of Car and Driver has a column by Larry Webster on this very subject, even using the C and D Long-Term Test 330i six-speed as the car. He experiments with various fuel-saving measures in the BMW, namely:
1. Always cruise in top gear 2. Drive slower (duh) 3. Turn off the A/C (yeah right, in Houston?) 4. Keep your tires properly inflated 5. Accelerate moderately |
07-29-2006, 12:19 PM | #11 | |
Rep 80
Thanks guys, Rich |
07-29-2006, 01:08 PM | #12 | |
Rep 883
Avid collector of the very finest Deutscher Schrott
07-29-2006, 04:40 PM | #13 |
Darth Tator
Rep 20
why does the MPG gauge displays higher fuel comsumption right before every stop? is this due to engine breaking? my foot is off the throttle yet the mpg is at 12 and then goes up when the car is at a complete stop. i have a step
07-29-2006, 04:52 PM | #14 | |
Rep 3,566
Drives: F30 M-Sport 328i Estoril Blue
now from lots of feedback bmw decided to change the display to zero in the e90, so people would not panic as much. with todays fuel prices, it was a good chce. however, the reality is that the car is still consuming infinity mpg till you push off again.
328i M-Sport, Estoril Blue, Carbon XP 35 Tint, front heated seats, black Dakota, Sports Suspension, Anthracite Headliner, HUD, Pro Nav, Sunroof, hk 600w, Bi-Xenon, 19" 403M wheels, Reversing Camera, DAB+, Xenon, BT Ext Connect, MST turbo intake pipe, MST Cold Air Intake, JB4 on Map 2 with Catless DP produces awesome performance in Sport.
07-29-2006, 07:01 PM | #15 | |
Rep 49
E90 330i | Deep Green | Beige Leather | ZPP | ZSP | 6 MT |Confort Access
