Comfort Access + Pathway Lighting = No love?
08-11-2006, 10:20 PM | #1 |
Rep 162
So my car has the CA option and since I got it I have been trying to get the pathway lighting (referenced in the manual) to work properly. This is the option to flick the highbeam switch to activate the lights when you exit the vehicle at night so you can see where you are walking.
So after trying this for awhile I figured there was something wrong that it wasn't working, on a whim I put the fob into the dash started/stopped the car and removed the fob and tried the pathway lighting and bingo, works perfectly. So the question then becomes, does pathway lighting simply not work if you use the CA option of not inserting the fob into dash? And/Or is there a way to make pathway lighting work with CA? |
08-11-2006, 11:45 PM | #2 | |
Rep 959
I've gotten it to work, but it may have required the headlights to be "off".
330xi SG/Terra/Burl -- ZPP, ZSP, ZCW, CA, Sirius, PDC |
08-12-2006, 03:52 AM | #3 | |
Rep 282
It's quite easy to make this work if you have comfort access (took me a while to figure it out too) 1. Instead of pressing the start/stop button once, press it twice to also turn off accessories (make sure the 2nd press isn't with the clutch depressed otherwise the engine will just start again) 2. Now flick the light stalk to activate pathway lighting Hope this helps... |
