      08-17-2006, 06:45 AM   #1
- Paul -
- Paul -'s Avatar
England
784
Drives: see above.
2005 320D SE  [10.00]
2005 645  [9.00]
Drive the 320si (virtually)
http://www.race-game.org/cars/bmw.htm
BMW 320si
Engine
4-cylinder in line, longitudinally installed; distribution: two overhead camshafts, 16 valves; displacement: 1999 cc; bore x stroke: 86 x 86 mm; compression ratio: 11:1; maximum output: 275 bhp @ 8300 rpm; maximum torque: 242 nm @ 7250 rpm; engine management: BMW Motorsport ECU 404; lubrication: wet sump.
Transmission
Rear-wheel-drive; gearbox: BMW Hpattern 5-speed, with straight cut gears and dog engagement; clutch: carbon-fibre single-plate; differential: mechanical limited slip differential.
Dimensions
Length: 4535 mm; width: 1845 mm; wheelbase 2763 mm; minimum weight: 1140 kg including the driver.
Chassis/suspension/tyres/wheels
Front suspension: double-joint strut, coil springs, gas-filled dampers, anti-roll bar; rear suspension: five-arm multi link axle, coil springs, gas-filled dampers, anti-roll bar; steering: power assisted rack and pinion.
Brakes & Wheels
Power assisted dual circuit system; front brakes: 4-piston calipers, 332 mm steel ventilated discs; rear brakes: 2-piston calipers, 291 mm steel discs.
