Anyone know about a cold air intake for 2007 E92 328i?
09-07-2006, 05:11 PM | #1 |
Rep 10,200
Drives: 2024 Golf R / 2022 718 Spyder
Just curious--is Dinan going to put out a cold air intake for the 07 328i coupe? I have been told that is one of the easiest ways to boost the 230 horses that will come standard under the hood.
I have also heard some things @ the dealer about chips and downloads, but no specifics. Could anyone shed any light? |
09-08-2006, 05:06 PM | #2 |
Rep 10,200
I guess this was a dumb question......
Past rides: 2016 981 BGTS, 2020 MINI JCW, 2017 F80, 2015 981 CS, 2014 F22 235, 2011 E82 135, 2008 E82 135, 2007 E92 328, 2007 E92 328 (My lady drives an OG M2. So does my dad)
09-09-2006, 10:53 AM | #3 |
Rep 2,355
fujita is usually the first company to release air intakes for bmw. they are "Competition" intake systems.
2006 E46 M3 ZCP 6SPD-Interlagos Blue - 6SPD - SSK - AA Headers -AA Tune - Navigation w/ Splashscreen Mod - 3M Crystalline Series 60 - Carbon Splitters - Swissvax Treated - Bridgestone
2012 Yamaha FZ8 - Matte Black/Grey - Michelin Pilot Pure 2CT - Vortex Rear Sets - Yoshimura R-77D & Fender Delete - Spectro Race Oil - GP Reverse Shifting |
09-22-2006, 05:08 PM | #5 |
Rep 10,200
That is exactly what I thought--it is the same engine in the 325, 330 E90 as the 328, 335 E92s--they are just tuned differently right? That is why I thought if a cold-air intake would fit a 325 E90, then I could put it on my 328 E92 (currently floating across the ocean).
Maybe that is completely dumb, but that is how i understood the differences in each model. Thoughts, anyone?
11-25-2006, 12:27 AM | #6 |
Ferris Bueller
Rep 79
I may be wrong - but due to a strange series of events I will be getting a 2007 328i E90 to replace my 2006 325i E90. I purchased the Dinan cold air intake for my 325 - didn't get around to putting it on yet - thank goodness! Anyways, I plan to put it on my 328 - it is the same engine as the 325 - either tuned differently and/or changes made to transmission yield changes to output. Either way I believe the CAI from Dinan will work just fine to boost my HP and ftlbs. Good luck.
11-25-2006, 01:29 AM | #7 |
Rep 6,750
The E90 328i is not the same engine as in the E90 325i/330i. It is the one from the X3.
11-25-2006, 09:54 AM | #8 | |
Rep 659
How do you know this? also, the x3 is rated at 260hp and 225 ft-lbs... so is the 328 just underated or undertuned..??? |
11-25-2006, 11:32 AM | #9 |
Rep 2,485
The 328i doesn't have the N52 engine??
2006 E90 330i (retired)
2009 E90 335i (retired) 2012 E70 X5 50i M Sport (retired) 2016 F10 535i M Sport |
11-25-2006, 12:47 PM | #10 | ||
Rep 6,750
There has been a lot of discussion about engine types in these forums, and the general consensus is that the E90 328i has the N53 engine. The E90 325i and 330i utilize the N52, and the E90/E92 335i, the N54. Quote:
http://www.e90post.com/forums/showthread.php?t=17829 I'm beginning to have some doubts on these rumors, because it's my understanding the 328i does not have direct injection yet, at least in the U.S. Last edited by ksfrogman; 11-25-2006 at 01:04 PM.. |
11-26-2006, 09:40 AM | #11 |
Rep 6,750
Okay, here's an update. I did some research, and the E92 coupe is one of the first vehicles to use an enhanced version of the original N52. This new and improved engine is referred to as the N52KP or N52B3001. The current E90 325i/330i use MSV70 for engine management. The new one uses MSV80. As with the E92 335i, the 328i uses a lighter weight plastic material for the throttle valve. The sensor is "magnetoresistive," which has no moving parts, and gives much more accurate feedback for the DME. The air mass flow sensor now uses a heated film rather than the previous hot-wire arrangement on the HLM. This new version is called HFM or Hot Film Air Mass Meter. This makes the new meter less prone to effects of contamination.
Here are exerpts from the BMW tech training manual. What I find interesting is that power output is not much different for the "high output" version, though the enhancements do make the engine more mechanically sound. I would think the changes would also make the engine more responsive. I believe there has been talk of a direct injection motor for the 328i (E90Fleet had posted some photos), but that may be a few years off. By the way, see that compact SUV photo down below? Last edited by ksfrogman; 11-26-2006 at 10:02 AM.. |
11-26-2006, 10:15 AM | #12 | |
Rep 659
11-26-2006, 10:21 AM | #13 | |
Rep 6,750
http://www.e90post.com/forums/showth...ighlight=stage Those motors actuate valves that selectively channel the flow of intake air from the front (cylinders 1,2,3) to the rear cylinders (4,5,6) via overshoot and resonance pipes. The 330i uses a three-stage system, and if you read the fine print, it implies that there may be both a one-stage and two-stage system. |
11-26-2006, 10:29 AM | #14 |
Rep 6,750
One more thing. The channeling of intake air within the intake manifold directly affects how the cylinders fill at different engine RPMs. So based on an educated guess alone, the VANOS could be programmed differently depending on the intake manifold type. If the E90 325i has collector and resonance pipes that cannot be closed off at idle or during medium engine speed ranges, the cylinders would get too much air and fuel at those engine speeds. To compensate, the valve lift could be reduced via Valvetronic control. Or hypothetically, the amount of air flow into the cylinders could be decreased uniformly (via cam or VANOS control). This is interesting, because it could explain why the 325i N52 puts out less peak power at higher rpms.
12-14-2006, 04:01 AM | #15 |
Rep 3,431
can we just put in the existing aftermarket intakes, like fujita, into the e92 328i?
Current: 09' E90 335d - Titanium Silver/Black Leatherette/Sports Package/6AT Paddle Shift/USB Integration/19" Staggered Breyton GT Gloss Black
Retired: 07' E92 328i (Jet Black) |
12-14-2006, 05:35 AM | #16 | |
Rep 143
The difference is like a 325 and a 330, the engine is the same but the intake manifold alone(+ECU of course) is why they have produce difference power. |
