E90 Traction control makes dust
09-17-2006, 09:18 PM | #1 |
Rep 5,767
someone told me that if you turn off the traction control less brake dust is made while you are driving, i tried it and it seemed to work. anyone else find this?
09-17-2006, 09:31 PM | #2 |
Rep 1,928
Drives: had e90, 330i mystic blue
nope but I prefer to clean my break dust than crash at 100+ mph and have someone pick up what is left of my car and clean my blood of the steet
easier solution clean your wheels with F21 wheel cleaner from TurtleWax is the best and it repels brake dust
E90 Mytic Blue 330i 07-20-2006. 05-17-2011
Doesn't the idea of making nature against the law seem to you a bit . . . unnatural? Support NORML |
09-17-2006, 09:59 PM | #3 | |
Rep 2,355
2006 E46 M3 ZCP 6SPD-Interlagos Blue - 6SPD - SSK - AA Headers -AA Tune - Navigation w/ Splashscreen Mod - 3M Crystalline Series 60 - Carbon Splitters - Swissvax Treated - Bridgestone
2012 Yamaha FZ8 - Matte Black/Grey - Michelin Pilot Pure 2CT - Vortex Rear Sets - Yoshimura R-77D & Fender Delete - Spectro Race Oil - GP Reverse Shifting |
09-17-2006, 10:01 PM | #4 |
Rep 417
calvin, how does DSC/DTC prevent you from crashing at 100+mph?
anyway, DSC/DTC uses your brakes, so it'd make sense if you find less brake dust after turning DSC/DTC off.
2006 e90 325xi | Alpine White | Beige Leather | Burl Walnut Wood Trim | Premium Package | Steptronic | Comfort Access | Xenons | Lux 4.0
09-17-2006, 10:14 PM | #5 |
Rep 1,928
if I'm goign at 100+ and suddenly an idiot cut in front of me and I have switch lanes to avoid crash DSC will prevent my car from spin check this out click DSC
09-17-2006, 11:00 PM | #6 | |
misadventurer
59
Rep 708
ive been driving with my DTC on lately and noticed that my wheels have less brake dust. ive wondering about that and never realized that ive been driving with DTC on. i dont drive far with my DSC fully disabled. very seldom that i fully disable the system.
325i I SP
09-17-2006, 11:52 PM | #7 | |
Rep 548
09-17-2006, 11:58 PM | #8 |
Rep 417
no joe bimmer, DSC & DTC is the first, default mode. DTC only is the mode that turns on when you push the button once. Then holding turns it all off like you said. Dont get mad cause you're the confused one. I know you dont believe me so just go read the manual... page 79 under 'controls'
09-18-2006, 12:16 AM | #9 | |
misadventurer
59
Rep 708
DSC is on when you start up the car. DTC is turned on when you press the button once. its weird how BMW set it up. DTC is another mode at which DSC gives you a higher treshold meaning it lets your tire spin. most people would put it as disabling half of DSC which gets confusing because what DTC really does is raise the treshold of DSC. making DSC kick in later than normal. so DTC lets you compromise without fully disabling DSC and gives you more headroom for control. when i first got my car my dealer told me that i could turn "ON" DTC if its raining but it could wear my tire out faster. i thought he didnt know what he was talking about until i read about the threshold explanation. if im really wrong ill gladly accept corrections.
325i I SP
09-18-2006, 12:17 AM | #10 | |
Rep 2,002
DTC is on ONLY when you press the DTC button once. If you press and hold the DTC button for 3 sec, both DTC and DSC are deactivated. When I press the DTC button, iDrive said: " DTC activated, DSC limited!" - that means that DTC is activated ONLY when you press the DTC button once.
09-18-2006, 12:18 AM | #11 | |
Rep 1,928
if u push the button once it deactivate DTC if u hold it it will deactivate both
09-18-2006, 12:21 AM | #13 |
Rep 417
I didnt wanna do this but heres the quote from the manual. DTC Dynamic Traction Control DTC is a version of DSC in which the drive output is optimized for particular road conditions, e.g. unplowed snow-covered roads. The system assures the maximal drive output, but with reduced driving stability. It is therefore necessary to drive with appropriate caution. You may find it useful to briefly activate DTC under the following special circumstances: > When driving uphill on snow-covered roads, in slush or on unplowed, snow-covered roads > When rocking a stuck vehicle free or starting off in deep snow or on loose ground > When driving with snow chains Activating DTC Briefly press the button; the DTC indicator lamps in the instrument cluster come on. Deactivating DTC again Press the button again; the DTC indicator lamps in the instrument cluster go out. Deactivating DTC and DSC together Press the button and hold it down for at least 3 seconds; the DSC indicator lamps in the instrument cluster light up. Stabilizing and drive-output promoting actions are no longer executed. Now can we please never mention this again?
09-18-2006, 12:22 AM | #14 |
Rep 1,928
whatever I only know if I press the botton once I can spin tires and do burn outs etc... and if I hold it I'm on my own no computers
09-18-2006, 12:25 AM | #15 |
Rep 1,928
I'm in florida so is not like I'm going to use DTC for snow only for tire spin
09-18-2006, 12:43 AM | #16 | |
BMW, can I have some LSD please?
88
Rep 1,591
But don't come running to me if your brakes over heat and rotors warp and have significant brake fade...
2006 330i | TiAg | Black | Al | 6MT | Sports Package | Logic 7 retired
2008 335i | AW | Black | Al | 6MT | Sports Package | Logic 7 retired 2013 328xi | Red | Gray | Al | 8AT | Sports Line | Premium | Executive | Heat Pkg retired 2017 340i xDrive | Estoril | Black | Al | 8AT | M Package |
09-18-2006, 01:02 AM | #17 | |
Rep 2,658
09-18-2006, 01:03 AM | #18 | |
Rep 2,658
09-18-2006, 01:23 AM | #19 | |
misadventurer
59
Rep 708
i even thought that my dealer didnt know what he was talking about.
325i I SP
09-18-2006, 05:51 PM | #20 |
Rep 2,355
guys i have not been with traction control on my car for about 2 months already because it is malfunctioning, it is not very big of a deal...if someone knows how to handle a car properly its very easy, and with this car being so balanced..... domonic if u want to drive with traction control off do as you please, my friend with an s2k doesnt even have traction control and he has a car with default oversteer...
09-18-2006, 06:05 PM | #21 |
Rep 242
Drives: E92 328, BS CB, CA, Nav, PDC
How about this, experts explain it this way
Most Control/Car Intevention: DSC "On or Off" / DTC "On or Off" Less (or middle ground): DSC "On or Off" / DTC "On or Off" Least Car Intervention: DSC "On or Off" / DTC "On or Off" ???? does that make sense, i dont know the answers i am just trying to figure out a way to explain this clearly |
09-19-2006, 09:49 PM | #22 |
Rep 5,767
alright guys thanks, but i know the whole push the button thing, but i was just wondering if you have both off (NO COMPUTER INTERACTION) if it makes less dust. and i can drive my car, its slow compared to the race car that i drive professionally. man when it rains im lovin life
