Anyone used a honda sissor jack to jack up the e9x?
10-06-2009, 02:24 AM | #1 |
Rep 1,465
Anyone used a honda sissor jack to jack up the e9x? at the plastic lift pads of course.
thinking about trying. |
10-06-2009, 02:48 AM | #2 |
BMW, can I have some LSD please?
88
Rep 1,591
Don't even think about it! The coupling is not designed to fit properly.
When or if it slips, the least of all problems would be a broken suspension and scraped undercarriage. The worst would be loss of life or limb.
2006 330i | TiAg | Black | Al | 6MT | Sports Package | Logic 7 retired
2008 335i | AW | Black | Al | 6MT | Sports Package | Logic 7 retired 2013 328xi | Red | Gray | Al | 8AT | Sports Line | Premium | Executive | Heat Pkg retired 2017 340i xDrive | Estoril | Black | Al | 8AT | M Package |
10-06-2009, 10:12 AM | #4 |
Rep 645
Yeah, I woudn't do it. You run the danger of the car slipping from the jack while you are working on the car. If you work on your car at all, you should get an inexpensive jack kit like this one:
http://www.autobarn.net/jack-and-jack-stand.html |
10-06-2009, 10:13 AM | #5 |
Smiling politely
167
Rep 7,931
Here's what happened when someone used a MB jack:
http://www.e90post.com/forums/showthread.php?t=306504 If you want a scissors jack, get the OEM one. Otherwise, get a low profile hydraulic jack.
E90 330i Black Sapphire 6MT | 991.1 C4 Platinum Silver 7MT
10-06-2009, 10:20 AM | #6 |
Moderator
319
Rep 17,767
Drives: F36 428i,E90 328i, E85 Z4 3.0i
I kept an old scissor jack from a corolla in the trunk, used it a couple of times with no ill effect. I don't trust it 100% however, I always make sure to jam in a spare wheel under the car should the jack start to fail.
Official DC Metro Registry - Current, New & Prospective Area Members Roll Call! |
10-06-2009, 02:32 PM | #7 |
king of the hills
92
Rep 2,915
Drives: 2011 M3 w/ESS55, 2001 540i/6
+1 I keep my old Camry jack in the trunk, fits in the lift cups perfect. There should be no problem at all using it if it fits the lift cups.
Just look at the OEM BMW jack kit, has the same type of scissor jack. Like any jack, don't use it to crawl under your car....use jack stands! Otherwise for changing a tire its fine. |
10-06-2009, 04:53 PM | #9 |
Rep 2,446
Avoid HONDA jacks. Mine failed on me. The threaded socket made of plastic just gave up. I filed a complaint at Federal office for this. the only unoffical feedback was that I shouldn't use it to change wheels on a regular basis (simmer/winter seasons).
I bought one with steel socket. Had to do it anyway because my car is so low that my floor jack won't fit under. |
10-06-2009, 04:57 PM | #10 | |
Rep 1,252
2012 528XI Saphire Black
Stock for now 2007 e92 335i - Monaco Blue Injen DCI w/ Cyba Scoop - M-Tech Rear - ///M3 Rear Lip Spoiler - ///M5 SMG Shift Knob & iDrive Knob - BMW Performance Hand Brake - BMWCCA Member |
10-06-2009, 05:25 PM | #12 | |
Rep 14,829
10-06-2009, 07:02 PM | #13 |
Rep 1,465
So then how can I put or use a regular jack stand, you know the V-shaped ones that you get from harbor freight or sears crafts man that look like this: \_v_/
onto the jack pad so that it will not crush/deform the jack pad? what do you guys put in between safely? or do you not put anything at all? my jack has a nice flat lift pad so i'm not worried about that. |
10-06-2009, 07:17 PM | #14 |
Rep 8,003
Drives: '08 E90 335i, '99 E36 M3
I use one from a 1991 Toyota Camry that fits perfectly into the plastic jack point.
10-07-2009, 02:30 PM | #15 | |
king of the hills
92
Rep 2,915
For the jack stand issue, you can remove the cups and just use them on the flat spot beneath, or put them just to either side of the cup. |
10-08-2009, 09:14 AM | #16 |
Rep 258
For the record I hope you guys realise that jacks have rated capacities.
Prior to getting my E90 I had an integra and I would NEVER even think about using that little scissor jack on the E90. I got myself the 3500lbs heavy duty jack.
"Her name is Naomi, that's I moan backwards"
10-08-2009, 11:44 AM | #17 |
king of the hills
92
Rep 2,915
Lifting a corner up on the 3 will never exceed 1000lbs, the scissor jacks will be fine for that. However yes I agree if you are trying to lift up half of the car...that's when you need a hydraulic jack.
10-10-2009, 02:48 PM | #19 |
king of the hills
92
Rep 2,915
Is it a scissor jack? No not all BMW jacks are the same...my E34 jack is way different, and so was my E36. The e36 has an adapter that goes into a hole in the side skirt.
10-10-2009, 04:14 PM | #20 |
Rep 3,402
I use a floor jack and a jack pad adapter from ECS to ensure the plastic jack points don't get destroyed. As far as jack stands go, I am simply unable to figure out how one would jack a car up using the designated point and then get a jack stand under that same point once the car is raised. There are other points on the car that are approved but they are at the center of the car and since most jack stands have that U shaped point of contact they don't work well towards the goal of a stable point of contact. That U shape is designed to be placed on a solid axle not a flat surface as it present in most modern cars. I wish someone would just come up with a floorjack that had a mechanical lock so it would essentially convert to a jack stand once the car is raised. Maybe one of you companies like ECS should jump on that idea.
10-10-2009, 04:26 PM | #21 | |
Rep 522
10-10-2009, 05:56 PM | #22 |
Rep 78
My Toyota Camry scissor jack fits the plastic lifting pad on E92 perfectly. Using the jack to put spare tire on seems fine but DON'T ever use any scissor jack for any work under the car!
