E90Post
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > starting problem
Reply
      10-11-2009, 11:57 AM   #1
oka101
Drives: 2006 330i
starting problem
yesterday i woke up in the morning to start my car but it wouldnt start. you can hear it cranking but wouldnt start. it has a quarter tank of gas and i tried to jump start it but it wouldnt start. has anyone had the same problem or knows what this is from?
      10-15-2009, 07:37 AM   #2
oka101
Drives: 2006 330i
I took the car to bmw. They put the fuel pressure gage on the engine but it wasnt moving. They think the fuel isnt flowing. Ill know the exact problem today
      10-15-2009, 08:30 AM   #3
deathsightx
Drives: 2006 330i
If theres no fuel pressure then it's most likely your fuel pump, theres also a possibilty of clogged fuel lines/filter or a leak but not likely.
      10-15-2009, 09:56 AM   #4
max_asdf
Drives: e90
whats the problem
      10-17-2009, 02:26 AM   #5
oka101
Drives: 2006 330i
yeah it turns out to be the fuel pump and fuel filter. i asked them if it was my fault to cause this malfunction and they said no. so should i be responsible to pay for the repair or should BMW take care of it?
      10-17-2009, 02:36 AM   #6
jayely1
jayely1's Avatar
228
Drives: 335i
emm what?
      10-17-2009, 02:48 AM   #7
Lenaxia
Drives: 2006 330xi 6MT
2006 330xi  [0.00]
Your car is an '06 so it should be coming up on Warranty soon if you haven't busted out of 4/50 yet. If you're still under warranty it should be covered. However it sounds like you're not since you're asking about who should pay for it.
Unfortunately unless you can get a goodwill gesture from the dealership, you'll have to foot the bill for it. It's out of warranty and it's normal wear and tear. It shouldn't've failed so early but it does. I just had to replace the front shocks and axle boots on my Jeep, I'm lucky they managed for as long as they did. I haven't been so lucky with other things.
Good luck man.
      10-17-2009, 12:19 PM   #8
oka101
Drives: 2006 330i
whats the goodwill gesture?
      10-17-2009, 12:55 PM   #9
mojojosung
South Korea
16
Drives: SG 328i
It's basically, the dealer doesn't charge you for the repair and they pay for it. Fuel pump replacement must be a lot of money..you should try to get the dealer to cover that. Hope everything works out!
      10-18-2009, 06:21 PM   #10
oka101
Drives: 2006 330i
yeah i got the fuel pump + fuel filter + new battery . total cost $2021
      11-08-2009, 04:59 PM   #11
oka101
Drives: 2006 330i
after getting my car fixed i noticed that my rpm keeps bouncing when im not on the gas. does anyone know what this might be from?
      11-08-2009, 05:50 PM   #12
GMWNashville
Drives: 19 G05, 16 F80, 10 E70x5D
like at idle?
      11-08-2009, 09:58 PM   #13
aesfah
Max Powers
29
Drives: E90 330i
whoooah! shoulda had it towed to an indie shop.
      11-15-2009, 11:16 AM   #14
oka101
Drives: 2006 330i
yeah as soon as i start it. the RPM starts bouncing and then when you reverse. sometimes it happens at low RPMs when driving.
      11-15-2009, 12:46 PM   #15
ShinyRedCar
Drives: 2006 BMW 325i
Had the same problem with the same three parts as the solution. Went to an independent to purchase all three. Total cost to remove and replace the fuel filter and pump was $908.17. The total cost to remove, replace, and reprogram the battery was $179.44. Final total was $1087.61.
Battery replaced at 68,632 miles.
Fuel filter & pump at 69,508 miles.
Jeff
      11-15-2009, 12:57 PM   #16
Zero.7
Zero.7's Avatar
97
Drives: F30 340i AW M-Sport
Ouch! This is definitely an argument for getting an extended warranty for these cars IF you plan to keep them longer. The cost of this repair almost cost as much as the ext. warranty.
'16 f30 AW 340i M-sport
8-speed Auto
BMW ///M Performance Power and Sound Kit with Carbon Tips / Gloss Black Performance grilles
      11-15-2009, 11:55 PM   #17
aesfah
Max Powers
29
Drives: E90 330i
My SA told me that my extended maintenance plan or CPO warranty wont cover battery replacements. Can anyone confirm?
      11-16-2009, 12:23 AM   #18
TurboFan
Ski bum
TurboFan's Avatar
321
Drives: sideways
I thought the fuel pump was covered under an extended warranty? Is that only to original owners?
1999 e46 328i Ti Silver / Black[retired]
2007 e90 335xi Jet Black / Black[retired]
2011 e70 X5 35d Vermillion Red / Cinnamon
2011 e92 M3 LeMans / Fox Red extended
      11-16-2009, 09:40 AM   #19
BMWinNorthdakota
Drives: 2007 bmw 335i e90
Dont think so, it stays with the car
      11-16-2009, 12:29 PM   #20
oka101
Drives: 2006 330i
yeah it is always a good idea to get the ext warranty. i think the battery is the only thing that isnt covered with the warranty, but you might wanna double check.
after fixing my car the RPM keeps bouncing around when it is started. its like it wants to drive although im not pressing the gas. anyone knows why the RPM keeps bouncing?
      12-01-2009, 01:44 PM   #21
Frank@M-Force_Design
Drives: 330i
Just talked to my SA today. He said battery is a wear/tear item, and is not covered by extended warranty or maintenance program.
      12-01-2009, 02:22 PM   #22
burberry
Caffeine Addict
Drives: E93 M3
should've got the part numbers, purchased them yourself, and brought it to a 3rd party shop. i would never buy anything from BMW... unless that was my last resort. I asked for a quote for a passenger side mirror and they said 900$ just for parts, i got them online for like 160$.... Big difference.
'07 E90 335xi ► '09 E90 335i ► '08 E93 M3 ► ???
Reply
e90post
