E90Post
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > Pro Nav - Speed Cameras
Reply
      09-27-2006, 08:27 AM   #1
NFS
NFS's Avatar
United Kingdom
275
Drives: M340i
I managed to get speed camera data on my Nav - following advice from Mathmos here:
http://www.bmwnavaddpoi.co.uk/
It wasn't easy to create the eng.lsc file, but once you have it it's easy to copy the disc insert the new file and burn a copy with the poi data installed.
If you have any doubts that we are plagued by speed cameras check out these screen shots
If anyone would like any help with this I would be happy to oblige. I can also upload the files needed so that all you have to do copy the disc, insert the files and burn.
      09-27-2006, 09:02 AM   #2
BMW to BMW
Would it be possible for you to upload the entire disc itself so that we can download it whole and just burn it to a DVD. This would be much easier!!
Thank you and great work!!
      09-27-2006, 09:43 AM   #3
booforty
booforty's Avatar
United Kingdom
337
Drives: E92 M3
2008 E92 M3  [0.00]
NFS - I'm very interestd in this. Not brilliant at burning/copying things so I will need your help. Any chance you could do a disc for me and I cover any costs? Or is it so easy you could walk me through it?
Paul
      09-27-2006, 09:56 AM   #4
NFS
NFS's Avatar
United Kingdom
275
Drives: M340i
Paul
My disc is the one that doesn't have proper postcode search It only has 3 digit postcodes and only for London)
The discs are about 4.6 gigs as well, so sending them over the net would be difficult, even though I have a pretty fast internet connection (1.3meg up and 14meg down ).
Options are :
1. I burn and send you a copy of my disc - but you will not get postcode search.
2. You create a copy of your disc (I can talk you through this) and I help you amend it and burn it.
      09-27-2006, 09:59 AM   #5
NFS
NFS's Avatar
United Kingdom
275
Drives: M340i
The disc is 4.2 gigs so uploading it would be a pain. The amended files are pretty small, but are different depending on the age of your nav disc.
I already have the amended files for the latest disc, I could create a set for the older one as well and just e-mail them to anyone interested.
You would have to create an image of your disc on your PC, insert the new files and burn it.
This will be quite easy - much easier than creating the files from scratch.
      09-27-2006, 10:43 AM   #6
booforty
booforty's Avatar
United Kingdom
337
Drives: E92 M3
2008 E92 M3  [0.00]
Originally Posted by needforspeed
Options are :
We could try option 2 first. Do I need a blank CD or blank DVD?
Paul
      09-27-2006, 11:15 AM   #7
NFS
NFS's Avatar
United Kingdom
275
Drives: M340i
Paul
You need a blank DVD - preferable a rewritable one from a decent brand.
I used a Verbatim DVD + RW
Then you need to download this programme:
http://fileforum.betanews.com/detail...r/1011845169/1
To copy the DVD follow the instructions here:
http://www.bmwnavaddpoi.co.uk/imageway.htm
This will create an ISO (disc image file on your hard drive).
You will need to extract files from this image and copy them back to it, for which you will need an ISO (image) editing programme.
I'll send you a PM about that
      09-27-2006, 11:34 AM   #8
booforty
booforty's Avatar
United Kingdom
337
Drives: E92 M3
2008 E92 M3  [0.00]
Great, thanks NFS!
      09-29-2006, 04:08 AM   #9
booforty
booforty's Avatar
United Kingdom
337
Drives: E92 M3
2008 E92 M3  [0.00]
Simon, a friend of mine who's a whizz with computers is going to help me with this at the weekend. I've got the older Nav disc (took delivery June 05), is it possible for you to upload the files needed so all I have to do is copy and burn?
Thanks,
Paul
      09-29-2006, 05:02 AM   #10
BMW to BMW
thanks needforspeed, i will do this when i have a little time...
thanks
      09-29-2006, 11:46 AM   #11
NFS
NFS's Avatar
United Kingdom
275
Drives: M340i
Thanks,
Paul
I think you are going to have to create the files yourself as they are slightly different for the older disc than for the one I have, because mine has more POI categories.
This means you will need a text editor prog and cygwin to run the perl script.
Trust me - it is MUCH easier than it sounds - just follow the instructions here:
The instructions are excellent - just 2 things to note that I thought were not totally clear:
In step 7 - for the TPD-SEV files the values for .idx and .url entries should be the same as the files you create in step 12. Just add 1 to the highest file number that you have. So if you have 00097.idx - it's 00098.idx
Also when downloading cygwin - you need to read carefully to make sure that you select the 'perl' elements and make sure you install it to the directory suggested in the instructions.
I'll send you a PM about the text editor
      11-05-2006, 03:37 PM   #12
Brett
Drives: 2000 BMW 323 CiC
Are the same cordinates available for the US? Just curious.
EDIT: This thread was a link from another, I did not realize it was in the UK Forum. Anyway, my question still stands
-Brett
      11-06-2006, 03:06 AM   #13
SRT
United Kingdom
Drives: BMW 5 Series
Probably not, Brett
You would need your own database of speed camera locations, first
      11-13-2006, 05:32 AM   #14
Dave_3
Dave_3's Avatar
Scotland
652
Drives: G22 M440D
I'm expecting to take delivery very soon of my first BMW ... with the SatNav.
I will certainly have a crack at this.
needforspeed: I notice in your pics that your display also shows a road symbol with an exclamation mark. I'm not familiar with the BMW SatNav system, is that related to the location of the speed cameras ?
D.
Escort Mk1 RS2000 (2.1 2x44IDFS, BVH, Kent FR32, 5spd, 180 BHP) : M440D ¦ Previously : F32 435D : F32 430D M Sport sDrive, 335D E92 2006
      11-13-2006, 01:19 PM   #15
London320d
London320d's Avatar
England
Drives: '06 E90 320dSE
The exclamation mark sysbols are TMC (real time traffic) information. Red surround if it is on your satnav route, black if it is not. there are also other TMC symbols such as two cars with one of them on its side to show locations of accidents etc. The extent of the queues are shown by arrows alonng the affected stretch of road.
      11-13-2006, 02:14 PM   #16
Dave_3
Dave_3's Avatar
Scotland
652
Drives: G22 M440D
Thanks for clearing that up. I wasn't offered any real time traffic option here in Switzerland.
Looking forward to getting my hands on the new car and the DVD to play around with adding these cameras
D.
Reply
e90post
