10-28-2009, 05:38 PM | #1 |
318
Rep 3,635
Drives: R56 Cooper S
My first attempt at rig rolling shots.
...and it looks like I'm in need of a lot of help.
Here are the final products: Here is an original. I had to use WAY to much PS to make it look halfway decent. I only had a short pole so I couldn't get the whole car in the frame. I'll go to Home Depot to get a longer one. Some questions: 1. Is it possible to do this in bright daylight without a filter? I couldn't get any long exposure times even with f22 and ISO100. You must have to be driving ad 50mph+ to get any motion. 2. Is it better to push the car or drive it? I found the car to be sharper when pushed (the two I posted are being pushed at 1mph max), but the motion blur obviously wasn't as apparent. So if you guys have any tips, tricks or criticisms let me know. Thanks guys. |
10-28-2009, 05:46 PM | #2 |
Apex Everything!
999
Rep 4,378
Drives: 2007 Honda S2000, 2017 GT350
Definitely need a dark ND filter in the day time. I like to push the car for at least 10-15 seconds. No need to drive the car.
Be careful pushing the car too fast especially if the ground isn't completely smooth. My camera started bouncing a bit because I was pushing the car too fast and ended up putting a small dent in my roof. I'm sure the hood is a bit stronger though.
2011 E92 M3(Sold). 2007 Honda S2000 (Track Car). 2016 Cayman GT4 (Sold). 2017 Shelby GT350 (AKA Crowd Killer).
My pet project: https://stickershift.com |
10-28-2009, 08:14 PM | #3 |
Rep 5,382
what lens are you using?
10-29-2009, 01:06 AM | #4 |
aka 1013MM
1288
Rep 9,545
get a wider lens!!!!
10-29-2009, 07:11 PM | #6 |
Loading...
350
Rep 2,187
Drives: 91' E30 318is
Um on a side note, the second picture looks fucking awsome!
10-29-2009, 11:53 PM | #7 |
Rep 5,382
have you read this article?
http://www.rigshots.com.au/howto1.ht..._shutter_speed
10-30-2009, 11:15 AM | #8 | ||
318
Rep 3,635
http://www.diyphotography.net/take-c...alized-car-rig Quote:
11-01-2009, 12:03 PM | #9 |
Rep 346
Filters are the only way for daylight. Even at ISO50 @ f32, I have problems. A 10 stop ND filter would be awesome but need to be careful of vignetting on a UWA.
I would recommend pushing the car with the gearbox in neutral. Less vibration from the engine and only vibration should be from the road. This was the original motion shot Here it is finally edited I had to use a composite of the stationary shot and the motion shot to bring back sharpness. If I had pushed, would have required WAY less editing. |
11-02-2009, 01:28 PM | #11 |
318
Rep 3,635
OK, looks like I need a filter. Something like this would probably work:
https://www.adorama.com/HY58PF.html |
11-02-2009, 01:41 PM | #12 | |
Rep 346
11-02-2009, 02:06 PM | #13 |
318
Rep 3,635
11-02-2009, 02:11 PM | #14 |
Rep 346
Something along these lines.
https://www.adorama.com/BW62ND8XDP.html |
11-02-2009, 03:42 PM | #15 |
318
Rep 3,635
^^ Cool- I might just go with the adjustable polarizing one for the versatility for now. If I do, I'll definitely post the results/feedback here.
Thanks for everyone's help guys! |
