Gas Mileage
11-24-2009, 10:10 AM | #1 |
Rep 372
Gas Mileage
Lately I have been getting terrible gas mileage. It's around 17-18mpg. Last night it even dropped to 8mpg. I was idling for a while. Most of my driving now are city. I swear that I saw my gas needle gauge go towards the E side slowly.
11-24-2009, 10:44 AM | #5 |
Mad Linux Guru On The Loose
1129
Rep 5,400
Drives: 2008 335i Sedan, 2023 M3
Folks,
Thats normal. It happens every winter. Here are the reasons: 1. The air is colder. Colder air is thicker. Thicker air creates more drag which means you need more fuel to keep the same speed. Air at 0 degrees Celsius (32F) is about 30% denser than air at 30 degrees Celsius (90F). 2. The air is colder. Colder air is thicker. Thicker air contains more oxygen molecules per volume of air. Your car computer has to maintain proper Air-To-Fuel ratio which is more technically true to say proper Oxygen-To-Fuel ratio. The more oxygen goes into the intake per unit volume of air, the more fuel the engine will need to maintain proper AFR ratio. The way the ECU knows what's going on is via the oxygen sensors. That's one reason why you should not be using an O2-simulator. 3. Winterized fuel is now sold everywhere. Winterized fuel has less energy (BTUs) per unit volume compared to non-winterized fuel even though the octane level is the same. Even if you live in Florida, you still might see winterized fuel there because of people traveling north. 4. Check your tire pressure. In the cold, air shrinks. You can loose good 2-8 psi in the tires on a very cold morning. This will affect your fuel efficiency. To help "restore" some of the lost fuel efficiency: * Check your tire pressure. * Slow down a bit while @ cruising speed in cold weather. * Empty the trunk. Carrying 2 dead bodies in your trunk will definitely eat your fuel quickly. * Check your air filter and replace it if needed. |
11-24-2009, 05:06 PM | #8 | |
Rep 6,594
X7 LCI // Incoming C7 ZR1 ZTK // Sebring + TRX // Hydro + Raptor Gen1 Roush // Tuxedo |
11-24-2009, 05:10 PM | #9 |
Member
Rep 84
Be happy, I get like ~16mpg mostly city driving here in LA. Always getting stuck in traffic kills my mpg. I got great gas mileage bringing my car out here though (~31)
11-24-2009, 05:15 PM | #10 | |
Rep 61
If its colder in Denver than it is in San Diego, it doesn't mean that there is more oxygen in Denver at the time compared to San Diego. I will agree to a point that colder air is more dense, but not as extreme as you think. Atmospheric pressure has more to do with density than temperature. Personally, I think it is more likely to be a winter blend of gasoline. Gart Last edited by Gart; 11-24-2009 at 05:30 PM.. |
11-24-2009, 06:46 PM | #11 |
Chicks dig wagons!
43
Rep 1,375
Drives: 2009 E91
Location: Where you can see through the people, but not the air (i.e., Los Angeles!)
I agree. In fact, I am on my way out to the garage to remove the dead bodies from my trunk right now.
E91 Montego Blue gray leather burl walnut , Idrive, PDC, Logic7, CA, Sirius, xenons, 6FL, ZPP, heated seats, 17" tires.
4, 8, 15, 16, 23, 42 |
11-24-2009, 06:57 PM | #12 |
Rep 14,829
I was concerned about what mine would be after a software upgrade, but sorry, hit 31 mpg on the highway today. I'm really not sure but I'm willing to bet my car IS slower after the software upgrade. I'd rather have the same mpgs and stuff not broken and the car not dying on the highway while giving up some performance...
11-24-2009, 07:02 PM | #13 | |
Rep 603
11-24-2009, 07:23 PM | #14 | |
Chief Executive
304
Rep 2,889
Drives: 2008 335xi 6spd Coupe
Winter gas has an effect, but not that dramatic. I see roughly 25 miles difference / tank between the oxygenated crap and summer gas. Great post vasillalav |
11-24-2009, 08:30 PM | #15 |
Rep 257
Guys, don't rely on that silly gauge or trip computer for mileage info. Why don't you just divide the total number of miles driven after a near empty tank by the number of gallons it takes to fill up the tank, and you'll know your mileage? Don't forget to reset the odo to 0 after the last full fill-up to get an accurate distance driven.
11-24-2009, 08:38 PM | #16 |
Rep 757
I wish I was getting 17 mpg in traffic/city driving. I only get 13 mpg and have to fill up every few days. I guess you have to pay to play.
G20 with some ///M3 stuff = G80
11-24-2009, 08:58 PM | #17 |
Rep 154
I get 21 city and 31 highway in my 335i. If I set the cruise control to 75 mph, I get 32 mpg. We are 600 feet above sea level.
11-24-2009, 09:22 PM | #18 |
Rep 2,415
I'm actually ecstatic that I'm getting b/t 18-21 mpg with my 335i. Coming from a B7 RS4, I was averaging 13-15 mpg (and that's when I'm not driving too spirited!) I realize that's not comparing apples to apples, but you get why I'm happy to average 18.5 mpg now.
'16 f30 AW 340i M-sport 8-speed Auto BMW ///M Performance Power and Sound Kit with Carbon Tips / Gloss Black Performance grilles |
11-24-2009, 11:34 PM | #19 |
1129
Rep 5,400
Folks,
I admit. I made a mistake on the numbers of the density of the air. It is not 30%. It is 10%. Source: http://en.wikipedia.org/wiki/Density_of_air It shows that air at 0 degrees Celsius is 10% thicker than air at 30 degrees Celsius. It also shows that air at -20 degrees Celsius is whole 17% thicker than air at 30 degrees Celsius. Basically, the air density between a very cold winter morning and a hot summer day is 17%. For me, that's a significant difference if you are cruising at 80 mph. |
11-25-2009, 01:41 AM | #20 |
Rep 7,433
just curious, do you think having the sunroof vented vs closed makes any difference?
-Brian
2X 2006 BMW 325i [Electric Red & Mystic Blue] | ZPP | V1 | Rear Fogs | M3 Lip Spoiler | EAS RemoteKey | BMS Powerbox | Projector90 Headlights w/ LED AE | LED plate lights | OEM Blacklines http://www.tech-shine.com |
11-25-2009, 03:25 AM | #21 | |
Rep 14,829
I think what people often miss is that use a statistic it should be reliable and valid. Without driving 100+ miles, most numbers are not repeatable. |
11-25-2009, 03:26 AM | #22 |
Rep 14,829
