Weird brake pedal during morning startup?
11-29-2009, 07:33 PM | #1 |
Rep 41
For the past few weeks, with cooler weather, I notice my brake pedal wont go all the way down when starting my car. In the morning, I step on the brake, it goes down maybe a inch and feels very tight, then I push the start button next. As soon as the engine starts up, the brake pedal goes all the way down like it should. Is this normal or something I should be worried about. Happens on most mornings, and sometimes in the afternoon. Occurs with or without handbrake on, and on flat even ground. car appears to be normal besides that startup issue. its a e92 335i steptronic.
11-29-2009, 08:18 PM | #4 |
Rep 959
I think it's normal. There's a brake mechanism that allows the brake to depress fully when the car is on, kinda like a spring system. When the car is off, you can depress the brake but then when you come back up the air cannot escape the system so the brake pedal cannot be depressed as much.
11-29-2009, 08:58 PM | #7 |
Rep 1,190
Pump the peddle whenever the engine is off and the pedal will tighten up as you mention.
2011 VW GTI 4dr-6mt-Sunroof-Nav-Xenons
OLD: 08 335i AW/CR/Poplar 6mt-ZSP-ZPP-ZCW-iPod-iDrive-PDC-Style 230s w/FK 452-Dinan LSD |
11-29-2009, 09:03 PM | #8 |
Rep 5,458
It is a defective valve and BMW will fix it as there is a SIB for it. Basically the issue is a small valve that maintains some vacuum after the car is shut off so that you have some power assists when you press the brake after the engine is off and the car sits. The defective valve lets the vacuum bleed off and then the peddle feels very hard when you go to press it the next day. Mine was fine for almost 2 years and then started doing it - there is an updated part, or if you are off warranty, it is $20 and easy to install yourself.
Rob
2025 X5 Msport
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
11-29-2009, 09:44 PM | #9 |
Rep 41
I drove many cars before and never experances this before. Besides, I got this e92 for almost two years now, and it just started doing this recently. Is this SIB a big deal? dont have anything schdule for my car, and I dont want to drop my car off for a day to fix this if its not prioity.
11-29-2009, 09:51 PM | #10 |
Rep 207
Drives: 2013 X3
The SIB can be found here http://www.bmwtis.com/tsb/bulletins/...p/B340607g.htm
Refer to it/bring a copy with you when you discussing the issue with your service department. If you search the forum for "brake booster" you will see that for some people replacing the check valve didn't solve the problem - they had to have the entire brake booster replaced.
2014 Z4 35is Deep Sea Blue - Sold
2009 E92 335i X-Drive 6MT - Sold |
01-31-2010, 03:48 PM | #12 |
Rep 41
Bump and update
So I took the car in couple months ago and they confirm the problem plus changed the valve. Anyways, the same issue came back a week later and I just left it as is since. Recently, my hpfp was dying, so I took it in for replacement, but I took it to another dealership. I brought up this brake issue to them, and they claim this is normal. They even got the foreman inspect it and said its normal for it to be stiff before engine start. My only problem is, ITS INCONSISTENT! If its suppose to stiff like this dealership said, then it should be like that all the time, not some times! they had the car for 2 days, and of couse it wasnt stiff for them, but once i picked the car up, it got stiff agian. This issue is annoying |
01-31-2010, 04:17 PM | #13 |
Rep 959
Maybe it has to do with how you leave the car...After you turn the car off (press the stop button) do you pump the brake once or twice?
And even if it is sometimes stiff before the car starts, does it start normally nonetheless? |
01-31-2010, 04:29 PM | #14 |
Rep 41
I do not touch the brakes once i shut her down. here is what i usually do, get to my spot, while stepping on brake, i put the car on park, let brakes go, push and hold the start button for 3 secs to shut her down completely. never touch the brakes afterward.
when i get back to the car, i'll step on the brake, if its stiff, itll go down maybe a inch, push start button and the brakes will then unstiff and go all the way down. once its up and running, no other problems, works like it should. like i said, its inconsistent, which worries me with all the gas padel chaos that toyota is going though |
01-31-2010, 05:12 PM | #16 |
442
Rep 18,331
Mine has been doing it since the first winter I purchased the car...Have to press the brake harder than normal to start but its not a problem...Its normal to me now and it doesn't bother me as much as when I first bought the car!
01-31-2010, 05:23 PM | #17 |
Rep 8,003
Drives: '08 E90 335i, '99 E36 M3
Every car I've ever driven does this. It's normal.
01-31-2010, 05:48 PM | #19 |
Rep 6,604
Drives: e92 335i
normal
01-31-2010, 07:16 PM | #20 |
Rep 1,523
its normal. and most other cars are the same.
2002 Laguna Seca Blue E46 M3 6MT 2017 White C63 AMG Coupe 2002 Oxford Green E46 M3 6MT - Sold |
01-31-2010, 07:26 PM | #21 |
Rep 959
