oil temp running at 270?
11-30-2009, 12:47 PM | #1 |
Rep 393
Hi i have 2007 e92 with jb tune and my oil temp runnig around 270 in 40degree weather... only when i push the car little hard... Is this normal? I dont have OEM oil cooler..
THnaks |
11-30-2009, 12:57 PM | #2 |
Rep 403
That seems only slightly above normal. Shouldn't be too much of a problem unless your car begins to go into limp mode. I thought the 07s have an oil cooler in the front tire wall on the passenger side.
My Ferrari 458 experience http://www.e90post.com/forums/showthread.php?t=738262
My McLaren MP4-12c experiences http://www.e90post.com/forums/showthread.php?t=794746 http://www.e90post.com/forums/showthread.php?t=939740 |
11-30-2009, 01:21 PM | #3 | |
Rep 634
+1 Seems a little high. The OEM oil cooler can be seen as metal grating at front wheel well. From what I've read on the forums, it is unpredictable which e90s have the oil cooler and which don't.
"Of course I do. I'm Leonard Shelby. I'm from San Francisco." (Memento)
"Look, we are all reasonable men here. We don't have to give assurances as if we were lawyers." (Godfather: Part II) |
11-30-2009, 01:57 PM | #4 |
ahat
1038
Rep 2,592
So what does it run at normal driving?
Should be about 240 max. Is this at any kind of altitude or close to SL?
'13 335IS N54 (1 of 373 LeMans Blue out of 3597 total production e92)- Grey interior (1 of 24 in LMB with any trans- 1 of 14 with DCT)-MODS -MFactory LSD/MHD-BQ custom Tune/ATM-IC/AFE Momentum GT Intake/Konis/Mfront&HeimJoint Rear rods&arms/Brembos. https://photos.app.goo.gl/Lo6aHZRo7XqtPkhL8 |
11-30-2009, 02:23 PM | #5 |
Rep 7,433
not every 07 had the oil cooler i don't think. i believe that started in 08?
-Brian
2X 2006 BMW 325i [Electric Red & Mystic Blue] | ZPP | V1 | Rear Fogs | M3 Lip Spoiler | EAS RemoteKey | BMS Powerbox | Projector90 Headlights w/ LED AE | LED plate lights | OEM Blacklines http://www.tech-shine.com |
11-30-2009, 02:33 PM | #6 |
ahat
1038
Rep 2,592
Actually, only manual cars with the sport package had them up until about March 2007. Then all 07s with SPP got them.
11-30-2009, 02:39 PM | #7 |
Rep 436
That is normal for the early 335i's without the oil coolers. Later models with the sport package got the coolers, and now I think all 335i's have the cooler. And yes 240 is way high for any engine to run even air cooled ones. Your oil temp should be around 212 just high enough to get all the moister out. My M3 runs under 212 in all temps here in TX when just driven normal. You really have push it to get them over 212. Put an oil cooler on if you plan on keeping the car for any length of time. This is a real design short fall for this engine.
HS |
11-30-2009, 03:05 PM | #8 |
ahat
1038
Rep 2,592
Well, the N54 motor is a little hot (close mount turbos) even with a OC. Even with an OC, mine still gets 235/240 on long drives (at normal velocities). But it should not be consistently getting 250+ on normal drives. Highspeed maybe.
During several 20 minute sessions at the local road course (2.9m), it got to 265. But that is the highest I have ever seen it. Even before the OC was installed it only infrequently went to 240 - never above.
12-01-2009, 12:39 AM | #9 |
Rep 1,922
Drives: E90 335i, E70 X5
mine is an 07 early production, ZSP but no cooler. normal driving is around 225-230 in a 40F day, summer 100F day will be around 240-245F but never go over 250F.
yesterday, mid 40F - mid 50F morning, went to mountain twisties run with bunch of friends, i kept the rpm higher than usual, ~4000rpm, oil temp was around 235F. at some points i was redlining/holding gear @ ~6000rpm, then i started seeing 250F, but never went over it. once i let the rpm fall back to lower, oil temp significantly dropped quick back to 230-235F. even my friends' prosches were running a bit warmer than usual, they said they saw ~220F, so mine isn't too bad at all. but yes, definitely i need a cooler for a safer run. side note, i am running JB+ 75%.
-eric
E90 335i TiAg *STOCK* see my garage for mod list.. E70 X5 SGM *try to stay stock* :/ |
12-01-2009, 12:39 AM | #10 | |
Rep 794
Drives: 2021 M2C, 97 M3
How high does your oil gauge read? Early cars only went to 300, later cars like 320. Early cars tend to read a bit higher.
Performance Center Delivery, June 21, 2013: 2013 E92 335is | Le Mans Blue | Gray Leather with Black | 6MT | 19" Style 313's | Michelin Pilot Super Sports | BMW Carbon Fiber Rear Spoiler | |
12-03-2009, 03:48 AM | #13 |
Ski bum
321
Rep 6,198
With a tune, in any weather, that sounds reasonable, esp w/o the oil cooler.
1999 e46 328i Ti Silver / Black[retired] 2007 e90 335xi Jet Black / Black[retired] 2011 e70 X5 35d Vermillion Red / Cinnamon 2011 e92 M3 LeMans / Fox Red extended |
