01-06-2010, 09:14 PM | #1 |
192
Rep 2,391
Official BimmerPost Photo Contest #19: CONTROLLED LIGHT
________________________________________ RULES: 1. Any interpretation of the theme that falls within Bimmerpost.com rules is welcome. 2. You must be the person that took the photo. Previous photos are acceptable as long as you are the one that captured the image. 3. One submission per contest. 4. Images must be no larger than 800px in any direction. Links to larger images are allowed but you must have one that is under 800px for the poll. 5. All contestants must host their own pictures (which includes hosting them on bimmperpost). 6. All images must have a title. 7. While post processing in Photoshop is allowed, adding or removing parts of the picture is not. In the event a photo is suspected to be "photo-chopped," the contestant will be asked to provide the original picture. THEME: a scene or frame where you control AND MODIFY all the light needed to expose the photograph. it doesn't have to be artificial light, but you do have to control all aspects of light in the scene (natural light is okay as long as you are controlling it or modifying it in some way). with one stipulation: no on-axis artificial light sources. meaning, don't use the built-in flash on your camera nor mount a flash onto your camera's hotshoe to light the scene. do not just flip the switch on a ceiling fan = uber FAIL. do not just capture available light!! and i may leave entries subject to my discretion so that all entries are of equal effort and creativeness to ensure use of modified and controlled light. if that's okay with you. ;] all themes are open as long as these criteria are met. you do NOT need fancy flashes/strobes to do this!! you can control natural light, or lighting fixtures with varies things (wax paper, linens, bodies....). *I reserve the right to enforce these standards as necessary. Be creative, have fun, dont get hurt IMPORTANT DATES: Entries must be submitted to this thread no later than Sunday, January 17th at MIDNIGHT EST. The poll will commence shortly thereafter. Light. Shoot. if i got the dates wrong, let me know. i'm exhausted.
2009 135i | space grey | sport | navi | hifi | heated
dinan stage 2 software | bmw performance exhaust kw v2 | hotchkis front sway | vmr v710 Last edited by rodi; 01-09-2010 at 05:57 PM.. |
01-06-2010, 10:16 PM | #3 |
Bootleggin' 'n Gunrunnin'
155
Rep 2,372
off-camera flash is good. Built-in or shoe mounted not good.
Scott
2024 G01 X3 M40i, Brooklyn Grey Metallic /// 2015 F15 X5 35i, Space Gray Metallic, 99K miles /// 2013 F30 320xi, Mojave Metallic, 112k miles 2019 Ford F450 STX, Oxford White 2013 Ducati Multistrada Touring S, Red |
01-06-2010, 11:44 PM | #5 |
Rep 24,685
Drives: '04 330i ZHP
sweeeeet
01-07-2010, 12:09 AM | #6 |
Night Sh1ft
471
Rep 3,079
Drives: F95 X5MC LCI
so...nikon users can use their single flash...canon users sol?
"Your first 10,000 photographs are your worst.” ― Henri Cartier-Bresson |
01-07-2010, 01:04 AM | #7 |
Night Sh1ft
471
Rep 3,079
theres no canon flash that can be used remotely without either having 2 flashes, or a wireless flash unit attached
i believe some of the nikon ones let u use them wirelessly w/o the need for the extra unit or a second master flash... (correct me if im wrong...)
01-07-2010, 01:27 AM | #8 |
Rep 9,783
I believe you are correct. I think you need a receiver or something like that no? I know that the 580 EX II can be used as a master unit but it needs to be connected via wire to the camera or wirelessly via a receiver. The 430 EX II can be used as slaves to the 580 EX II. That's about all I know about those kind of stuff as I normally don't use flash or I would use the hotshoe mounted ones.
01-07-2010, 05:37 AM | #9 |
155
Rep 2,372
Depends on the Nikon. My D300's built in flash will work as a commander and fire my SB-600 remotely. The built in can be set to provide no light on the subject too. If your camera doesn't have a built in or it won't work as a commander, you will have to creative. But it isn't flash, it is about controlling the light. Use bounce screens, diffusers or scrims, etc.
I did see 3 SB-900's in the used case for $370. Hmmmm, what better excuse to buy equipment than a contest!!
Scott
01-07-2010, 07:29 AM | #10 | ||
Rep 29,217
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals | |
01-07-2010, 12:35 PM | #11 |
Rep 9,783
01-07-2010, 06:57 PM | #12 |
Long Time Admirer, First Time Owner
18667
Rep 9,445
It's a combo on the lighting source. I left the high beams on the ATV pointed at the closer trees on the right so that the onboard flash wouldn't pick up the further trees on the left. It was the "blue moon" but I moved. . .
01-07-2010, 07:20 PM | #13 | |
Night Sh1ft
471
Rep 3,079
hmm...perhaps I need to get the st-e2
01-07-2010, 07:22 PM | #14 |
Rep 7,308
Drives: see above.
So flash is ok if off camera? - How about if flash is altered by custom diffusers/reflectors etc?
01-07-2010, 11:38 PM | #15 |
192
Rep 2,391
as long as it's not on camera and on-axis.
glad to see everyone excited. :] let's see some stuff! you don't have to use flash/strobes. you can't just turn on a light source, though. you need to control it and modify it.
dinan stage 2 software | bmw performance exhaust kw v2 | hotchkis front sway | vmr v710 |
01-08-2010, 12:14 AM | #16 |
Rep 7,308
Drives: see above.
Excuse all the questions - but what if you use natural light which is blocked by something in order to create an effect? Backlighting etc
01-08-2010, 12:20 AM | #17 |
192
Rep 2,391
did you block it?
01-08-2010, 12:20 AM | #18 |
192
Rep 2,391
you can't just catch natural light in a cool setting/situation - you have to control how it got there.
01-08-2010, 12:55 AM | #19 |
Rep 7,308
Drives: see above.
ok - so natural light backlighting is no good. No way to control the sun!
01-08-2010, 01:07 AM | #20 |
Rep 24,685
you can naturally backlight with a reflector....
01-08-2010, 01:09 AM | #21 |
Night Sh1ft
471
Rep 3,079
hmm, this all seems to require a good amt of gear i dont have...
01-08-2010, 01:17 AM | #22 |
no longer a BMW owner
174
Rep 1,463
