Did I get ripped off?
01-27-2010, 10:25 AM | #1 |
Rep 393
I recently put new wheels on my car and lowered it on H&R sport. So I went to Irish mike in Orlando to get alignment, the tech comes up to me and say we need to drill a hole in the front to adjust my front camber, thats the only way he could adjust it because they lock it in the factory or something like that. I have no problem if that is the only way to adjust it but I was just wondering if you guys had the same issues.. Oh by the way he charged me another $100 top of my regular alignment $130
01-27-2010, 10:40 AM | #6 |
Rep 2,575
Drives: '73 2002,'18 X5 35d,'17 328d T
you did get ripped off and if they drilled into your car too then you have upgraded to raped...
1988 E28 535is Euro Conversion --- sold 2009 E90 335 6MT --- sold 2003 E39 540iT Msport --- sold |
01-27-2010, 11:01 AM | #8 |
Rep 6,127
I agree with the early majority on this one. It just doesn't sound right. Maybe get your car back and go to a different shop?
When you say impact instead of affect/effect, you are communicating that you don't understand the difference between the two words, and are too lazy to learn.
01-27-2010, 11:02 AM | #9 |
Rep 69
To the OP - yes.
Cheers, Doug
_______________________________________________ 2010 E93 Titanium|Black|Aluminum 2001 Audi A4 1.8T Quattro/1973 Datsun 240Z/1966 MGB |
01-27-2010, 11:13 AM | #11 |
Rep 5,458
I certainly wouldn't let them drill it, there is no camber adjustment from the factory, but the proper way to do it is to put camber plates on top of the shock towers instead of drilling the shock tower to adjust hte camber.
2025 X5 Msport
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
01-27-2010, 11:16 AM | #12 | |
DENY THE WORLD THAT SURROUNDS YOU
505
Rep 35,580
Drives: JB 33ZERO
Eurocharged V5 | ROW's / CC Delete | K&N's | H&R Springs | Single Fin G.B. Grill | Mode Carbon Diffuser | JBSpeed CF Spoiler | Arkym Style CF Splitter | CF Mirror Caps | 5% Tints | 12mm Spacers | |
01-27-2010, 11:32 AM | #15 |
Rep 139
I remember reading a post similar to this a while back similar to this, and the conclusion was that there is actually a hole near the strut tower that is supposed to be drilled out to adjust camber in cases where the car is lowered some certain amount.
01-27-2010, 11:34 AM | #16 |
Rep 1,481
Drives: '11 M3 MW/FR - '12 M3 FO/SC
Garage List 2004 Honda Hornet [0.00]
2003 Chevrolet 2500 ... [0.00] 2011 BMW S1000RR [0.00] 2011 BMW E92 M3 [0.00] 2012 BMW E92 M3 [0.00] |
Hey was probably talking about the alignment pin that they put in for installation purposes from the factory.
By design the E90/E92s were not intended to have very much if any camber adjustment at all. By drilling out this pin that is only there from the factory to assist in the installation of the strut you can squeeze out at most another -0.2 degrees of camber. In case you are wondering where I gathered this information from. I am friends with a master tech at my BMW dealer who at my request was trying to squeeze out as much negative camber up front on my car to give me more grip on turn-in while still remaining in the F-stock class for auto-x and the most camber we were able to squeeze out with the stock set up was -0.5 degrees. So short answer is yes...there is an alignment pin that is supposed to be drilled out if camber is to be adjusted. However, if your tech drilled something else out then there may be other issues. Alignment at the dealer ran me $200, but I'm not complaining.
01-27-2010, 11:35 AM | #17 |
Rep 1,730
I would have taken my keys and walked out the minute i heard the word drill... Find a better shop with experienced tech who know the aftermarket market.
Also take your car to someone else to make sure those guys did not mess up any components up-front. No drilling is needed. They only need to remove the factory pins to get the camber where it needs to be.
'11 Space Grey E92 335xi M-Sport (KWv1 Coils | Saddle Brown | Bamboo) (Returned)
'14 Mineral Grey F32 335i M-Sport (Dinan DHP | LED Lights | Coral Red | Hexagonal Aluminum) (Returned) '16 Mineral Grey F80 M3 ZCP |
01-27-2010, 11:41 AM | #19 | |
Rep 6,594
That's not normal.
X7 LCI // Incoming C7 ZR1 ZTK // Sebring + TRX // Hydro + Raptor Gen1 Roush // Tuxedo |
01-27-2010, 12:02 PM | #21 | |
Dismembered Member
3613
Rep 9,213
My delivery experience and beach photoshoot here. |
01-27-2010, 12:19 PM | #22 | |
Rep 1,481
Alignment pin needs to be removed to adjust camber as directed by the BMW Tech Manual. For future reference if you have no idea what you are talking about, you should just keep your comments to yourself.
