E90Post
TNT Racewerks
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Reading, and have some orange peel questions...
Reply
      01-27-2010, 05:58 PM   #1
shanecarmaster1
shanecarmaster1's Avatar
Drives: e90 325i, F01 750Li, e38 740i
1. When treated, does this treatment stay forever or for as long as the last ones occured?
2. How much money to remove it?
3. Anyone got before/after pics?
      01-27-2010, 06:01 PM   #2
Tee212
Drives: yes
2010 335  [8.00]
It should stay forever, a portion of the clearcoat will be removed clear up the "peel". Theres a thread on here with the process well documented along with a youtube clip...search for it if you feel the need.
      01-27-2010, 06:05 PM   #3
JayKay335i
Egypt
189
Drives: ///M323 DCT
You need to wet sand the car to remove it.
      01-27-2010, 09:42 PM   #4
Healey3000
Drives: 2008 328i, with 3 pedals
Hi,
Orange peel is endemic in modern cars primarily because of the mandated use of low VOC urethane paints. The flow characteristics are affected adversely as a result.
While the clear coat certainly contributes significantly to the overall appearance of orange peel, there is a possibility that the base coat also has some. If that's the case, there's really no way to eliminate it.
Wet sanding the car with 2000 grit paper followed by sequential polishing with finer and finer compounds will help. However, and here's the big problem - you will end up thinning the clear coat. That's a recipe for disaster if the original clear was just thick enough (which it probably is). A thin clear coat will delaminate prematurely and since its function is to keep the sun's UV rays from reaching your base coat, the base coat will also start to fade prematurely.
The right way to do it is to have a body shop apply more clear coat such that the resulting film after wet sanding meets the specification for thickness.
Better yet, find a shop that will apply nitrocellulose lacquer :-)
Regards,
Adnan
      01-27-2010, 09:57 PM   #5
Craig@SupremePower
G.O.A.T.!
Craig@SupremePower's Avatar
Drives: '18 GMC Yukon XL
common problem with bmw's...
      01-27-2010, 09:59 PM   #6
jopa489
Drives: Anything with Wheels
Correct. The entire car needs to be wetsanded, which could negatively impact the integrity of the clear after a while depending on how it's done. It's a permanent fix, orange peel doesn't grow back.
X7 LCI // Incoming
C7 ZR1 ZTK // Sebring + TRX // Hydro + Raptor Gen1 Roush // Tuxedo
      01-28-2010, 04:59 PM   #7
e60_M5_2020
e60_M5_2020's Avatar
24
Drives: MB C Class
I never noticed orange peel until my dad had his hot rod repainted and I finally saw what a jet black is supposed to look like. Nonetheless, it seems like overkill to eliminate peel on a something like a 3 series, or any dd for that matter.
Reply
e90post
