New To Site - 335 questions
01-30-2010, 02:14 PM | #1 |
Rep 445
Hello. I've been an admirer of this site for a while and now that I'm in the market for a 335 I've decided to join. I must say that the members here have some of the hottest looking cars and I have a lot of ideas of what I'd like to do. I've always been a big fan of the 3-series and my 1st car was a 4spd '77 320i.
I've been searching for a 6spd 335xi Coupe w/Nav and its slim pickings as far as these cars are concerned. So I'm wondering if I can get by with a 6spd 335i as a daily driver in the Northeast. If I buy a 2nd set of rims and use snow tires will I be able to make it through the winter? If you drive a 335i in the winter time, please let me know how you make out. I don't mind a little fishtailing or having to muscle the car to get by, I just need to know that with good tires and traction control that I can manage on the 10-20 days a year it snows. My current daily driver is an '04 6pd Accord Coupe and I've been fine for 5 years with high performance all season tires. Also, if there are any useful and informative threads that answer a lot of questions about 335's and what to look for in a used one, I would be grateful to anyone who can pass them on. Thanks in advance for any opinions/advice. |
01-30-2010, 02:16 PM | #2 |
Rep 2,558
Sorry, I live in Texas so I can't help, but just wanted to welcome you to the boards
'07 Space Gray 335i coupe - R.I.P.
COBB ProTuned | AMS | CP-e | BMS | Quaife |
01-30-2010, 02:21 PM | #3 | |
Rep 95
01-30-2010, 02:28 PM | #4 |
Rep 445
Thanks. I know for sure that I'd never attempt to run summer tires in the winter so I've budgeted funds for the 2nd set of rims and tires.
01-30-2010, 02:36 PM | #5 |
Rep 1,190
I'm doing just fine in MA with 6spd and snow tires . Haven't been in a situation that they car wasn't able to get out of.
2011 VW GTI 4dr-6mt-Sunroof-Nav-Xenons
OLD: 08 335i AW/CR/Poplar 6mt-ZSP-ZPP-ZCW-iPod-iDrive-PDC-Style 230s w/FK 452-Dinan LSD |
01-30-2010, 03:01 PM | #6 | |
Rep 445
Does the TCS ever close your throttle when you reach zero traction where you have to disable the TCS and spin your way to traction? This happens in my current daily driver, but in this case I have the luxury of FWD. |
01-30-2010, 03:29 PM | #7 | |
Rep 14
I would just go with the RWD. I traded in an Audi S4 (AWD) for a 335i RWD and have not missed the AWD one bit. Once I got winter tires, I've had no problems getting through the snow. I live in hilly area in the midwest and we had one stretch of 14 days where it snowed every single day earlier this month. As long as the snow isn't higher than the under belly, you'll be fine.
I'll also add, do not try to go even around the block with those summer tires on in the snow or ice. You will not make it. I would also not try to get by with all-season tires, the winter tires are much better. Quote:
01-30-2010, 03:32 PM | #8 |
Rep 1,190
There are 2 modes of driver assistance that the 3 has. Dynamic Stability Control(which can be described here http://www.youtube.com/watch?v=j-hHW...om=PL&index=21 ) and dynamic traction control (which is also explained in the above video).
Basically the manual states to turn off the DSC and engage DTC to get started when wheel slip is needed to get going. Once you get going, swich dsc back ON. The video should show you why that's a good idea. I have not added any weight to the trunk unless you count the spare wheel since I don't have run flats anymore.
01-30-2010, 04:27 PM | #10 |
Rep 20,998
you'll get by just fine with RWD and snow tires.
09' E92 335i | 6MT | Montego Blue | Black Dakota Leather | Dark Burl Walnut | Premium | Sport | Cold Weather | Nav | Sirius | Comfort Access | iPod and USB adapter
01-30-2010, 08:40 PM | #13 |
Rep 14,829
I've driven in 7" of snow with 4 snows, no problem at all.
When it was 23" this year, I took the FWD Nissan with A/S......just don't want to push it with the 335i, but I think it would be ok....... |
01-30-2010, 08:55 PM | #15 |
Rep 24
Willkommen,
Where I live in Colorado we get 120" of snow each winter. I have Blizzak snow tires on my 335i and have not had a problem yet. On one occasion I had to turn the traction control off but I was on a steep 15% uphill grade on a narrow road and sharp turns and 3" of new snow. You'll be fine without the all wheel drive 335xi.
2007 E92 335i Manual 6-speed
2002 E39 540i Manual 6-speed - gone 2000 Z3 Roadster Manual 5-speed - gone |
01-30-2010, 09:24 PM | #16 |
Rep 1,028
+1
335i with a dedicated set of 17" snow tires drives like a dream on ice and snow. I usually disable the traction control so I can do what I need to do. DSC will cut power instantaneously if it senses the slightest wheelspin - it's a super-safe mode that I don't like when I'm trying to power through the white stuff. As far as advice...it sounds like you've driven on snow & ice before and it's a very predictable driving experience. It's a lot like driving on a gravel road - you can get sideways if you want, but a skilled driver can turn, stop and accelerate safely. It can actually be fun!
"The likelihood of one individual being right increases in direct proportion to the intensity with which others attempt to prove him wrong."
2015 F82 M4 - Sakhir Orange Metallic 2013 E92 M3 / 2013 E92 335is / 2010 E90 335i / 2007 E90 335i Last edited by thkfast; 01-30-2010 at 09:30 PM.. |
01-31-2010, 09:46 AM | #17 |
Rep 1
Hi, I am from CT and have a 2009 335 Xdrive with all-season tires.
I went to an empty parking lot with about 2 inches of snow to test things out. Taking off in a straight line is okay, but turning and braking can get you in trouble if you are not careful. It sounds like snow tires can be a big help whether you have AWD or RWD. Just a thought ... I did not buy AWD just for the snow. I can do a full power take off in the pouring rain without any wheelspin. It is amazing! I can get the holeshot on most cars I run into. LOL. |
01-31-2010, 10:04 AM | #18 |
Rep 318
I can tell you that my 335i with *GOOD* snow tires has safely and reliably gotten me to work and back through Kansas City's worst winter in 20 years.
We received 7-8 inches of snow on Christmas Eve/Christmas Morning and only my brother with a Subaru WRX and myself in my 335i were able to make the trip to the parents house. FWIW I had Dunlop Winter Sport 3D on my stock 18" sport package wheels. Forget the X...you're just going to take a hit on resale value and fun-to-drive factor. |
01-16-2012, 05:31 PM | #19 |
Rep 169
2008 bmw 335i
Hi
Welcome to the site thank you for looking at my car. I have sent you a private message. If you want you can call me on my cell. My be you can come see my car, and see for yourself the mint condition the car is in. Also I can go over all the warrantys with you they are all transferable to the new owner. I sent you a good price for my car let me know what you think. Joe |
01-16-2012, 05:47 PM | #20 |
Rep 14,829
I think common sense prevails. You need snow tires any place the temps go below 37F. It was 16F this morning in the northeast, even though there was no precipitation, a person is ill-advised to head out on the highway with summers.
Next, there is a point at which 4 snows won't help anymore because the ground clearance in not there. I've been ok with 9". but I've been caught in 23" with a FWD car and "gotten by." I don't think any 335i is going to do that well in 23", so it's good to either stay off the road, or have a 2nd car to drive in extreme weather. |
01-16-2012, 06:35 PM | #21 |
Rep 2,856
Drives: 2011 335is E93
I'm driving in Ontario and haven't had any issues whatsoever. Fact of the matter is if you have a good set of 4 winter tires and a good driver you're 99% of the time fine.
Enjoy the new car when you get it, these things are a blast to drive. Keep your eye on the speedo though, you'll tend to be foot heavy with these cars. And, post pics when you get her!! |
01-16-2012, 06:56 PM | #22 |
Rep 4,703
Don't let winter sway you away from this car. Put dedicated rims with good snow tires and you will be just fine. The car is so well balanced and all the fancy electroic stability controls make it a breeze to drive in the snow. I have drvien up to ski country in snow storms and have been fine. Don't worry - enjoy the drive
