High beam assistant and roadside parking lamps.
01-31-2010, 05:42 PM | #1 |
Rep 557
I've been reading the manual, and for the life of me I cant figure out these functions. The roadside parking lamp just turns on turn signals, and high beam assist just turns on high beams if you push the switch away from you, or flashes them if you pull it towards you. Can someone explain how these features work?
Also, my i-drive menu doesn't seem to have High beam assistant selection? |
01-31-2010, 05:46 PM | #2 |
Where'd my VTEC go?
481
Rep 6,067
I don't think high beam assistant is an option on US 3ers.
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear |
01-31-2010, 05:49 PM | #3 |
Rep 8,003
Drives: '08 E90 335i, '99 E36 M3
01-31-2010, 06:06 PM | #4 |
Rep 767
High beam assist is only an option in the US for 2010s. The manual for the roadside lights is not written very well. You must turn the vehicle off AND open the door AND THEN press the light switch in the appropriate direction. The manual leaves out the detail that the door must be open when you "park " the car.
01-31-2010, 06:29 PM | #5 |
Rep 767
also be very careful using the roadside parking assist. These lights will not turn off when the car goes to sleep. You will come back to a dead battery if you leave them on for a while or by mistake.
01-31-2010, 09:28 PM | #7 |
Rep 767
It is an OPTION so if you did not buy it you don't have it. My guess is that since it is not in your Idrive that you did not buy it.
01-31-2010, 10:26 PM | #8 | |
Freude am Fahren
339
Rep 5,254
The lights are intended to be left on when parking and not turn off. The car is designed to handle the load.
Freude am Fahren.
Jonathan E90 2006 330xi E90 2006 325i E39 2003 530i Sport* E46 2000 328Ci* E36 1996 328iS* E36 1992 325i* E30 1991 318is E21 1982 320iS* E21 1979 320 (6-Zyl)* *retired Nominated: Most Contributing Member |
02-01-2010, 08:47 AM | #9 |
Rep 767
They are designed to be left on for a short period of time when parking briefly not for an extended period of time. The manual even states this as I recall. All I am saying is that it WILL drain the battery so use it sparingly or you will come back to a dead car. If you think that you are going to leave them on over night and come back and the car start right up then you are gravely mistaken. All I said was USE CAUTION I did not say don't use them .... though I can not really see a reason to use them in the US.
02-01-2010, 12:01 PM | #10 |
Rep 95
When I turn the car off, and then listen to the radio for literally 30 seconds, the yellow battery light comes on... I'm pretty sure you're not going to make it through the night.
02-01-2010, 04:13 PM | #11 |
Rep 801
There's no option in the iDrive for it. It's always on. It's also part of the Premium package if you got it.
02-01-2010, 04:20 PM | #12 |
Supreme Allied Commander
1971
Rep 61,781
Drives: A BBS WHORE
I guess what he meant is the auto-dim sensor instead.
02-01-2010, 06:15 PM | #13 | |
Rep 1,110
2016 GLE 350d - White on Black
02-01-2010, 06:23 PM | #14 |
The power of V!
99
Rep 1,971
Drives: 2007 335i coupe steptronic
Garage List 1998 Lexus Gs400 [0.00]
2010 ebony & ivory [0.00] 2006 BMW X3 [0.00] 2009 pics [0.00] 2009 e92 335 xdrive [0.00] |
This is correct. Och do you have a premium pack 335?
2007 335 coupe Alpine white, steptronic, sportpack, etc. (gone)
2006 X3 3.0 steptronic Titanium Silver, 2009 E92 335xdrive, next.... Caddy CTS_V! 13 Lincoln MKZ? hmmm. |
02-01-2010, 06:58 PM | #15 |
Rep 557
Nope, no premium package. The specs on the car - Alpine White with Saddle Brown Dakota leather and Dark Burl Walnut trim, automatic with heated seats and navigation.
