      11-13-2006, 03:59 PM   #1
txusa03
Drives: TS330iPPSP6MT
my turn to ask for help (IT guru)
I am trying to install a Lexmark Z43 printer on a brand new Core II Duo Hp computer. I installed the Lexmark drivers. Added brand new black catridge ink onto printer. But could not do a "print test page" or print any other word doc? Anyone know what I need to do here? Printer is power on, printer usb cable is connected. What else should I look for? Thanks in advance.
under construction!
      11-13-2006, 04:41 PM   #2
ska///235i
***** noob
ska///235i's Avatar
Drives: 325xi>M235i>428GCx Mspor
2006 325xi  [0.00]
you prbly have the wrong driver
uninstall the driver and start again.....if you're using XP...make sure you install the XP driver. also, make sure the usb cable is not connected to the printer until it prompt you to...then restart/reboot
2006 325xi (Sold)
2014 M235I (Current)
2015 428xi Gran Coupe (STB)
      11-13-2006, 07:14 PM   #3
txusa03
I got XP running. Installed the printer via the add printer wizard. I selected the USB001 Virtual printer port for USB. The driver is called Lexmark Z42-Z43 Series ColorFine. Still cannot print. Even many restart. I get no error when trying to print test page and the freaking hour glass appeared everytime I click into the Test print window. It is also set to bidirectional printing. What is going on?
under construction!
      11-13-2006, 07:15 PM   #4
ska///235i
***** noob
ska///235i's Avatar
2006 325xi  [0.00]
is it a wireless printer?
reboot the printer (turn it off...and on), see if it does the routine start-ups like all printers do
make sure the ink cartridge is install correctly, make sure the tape is peel off
2006 325xi (Sold)
      11-13-2006, 07:42 PM   #5
txusa03
not wireless. I use a usb to parallel cable since the new computer no longer have parallel connection in the back of computer. The printer is an old printer but the computer is brand new.
under construction!
      11-13-2006, 07:43 PM   #6
Ninjaneer
Shadow Warrior
Ninjaneer's Avatar
Drives: '07 335i Sedan
tx: why are you going the add printer route? If you have the Printer's CD you could probably just pop that in and it'll install the drivers and guide you through it, as well as install the extra printer software if you want. Or follow the quick install guide? This is assuming you still got these lying around. Or grab the drivers off the printer's website?
335i E90 / Arctic / Gray / Burl Walnut / Steptronic / ZPP / ZSP / Paddles / CA / Nav / PDC / OEM Spoiler
Mods:
PIAA Angel Eyes, Rear Fog Switch, Escort X50 Blue hardwire, 30% Charcoal Llumar
Installing soon: Rear Power Outlets (Happy Robot mod!)
      11-13-2006, 07:44 PM   #7
TommyBahama
Drives: e90 330i
look for new drivers on company website?
uninstall and try everything over, just take it slow and understand that windows is like an fine woman...once a month it bleeds out it's unfertilized babies.
      11-13-2006, 07:48 PM   #8
Ninjaneer
Shadow Warrior
Ninjaneer's Avatar
Originally Posted by TommyBahama
just for new drivers on company website?
Get... these... images... out... of... my... poor... fragile... mind
Mods:
      11-13-2006, 08:11 PM   #9
txusa03
Ok, I got communication error when i tried to turn on bidirectional capability. What is that anyway. I think this printer is 5 years old. I don't have the original cd and i agreed with tommy in that i want the latest driver from Lexmark website for the window XP (which I have downloaded and installed). Any more ideas or remarks ?
under construction!
      11-13-2006, 08:23 PM   #10
txusa03
ok, no more communication error when I turn off bidirectional printing. But when i tried to print a word pad doc,it recognized the printer and I can see the freaking doc in the print queue but no action. :mad:
also, found the cd so now i am gonna tried the cd method which I don't think gonna work but what the heck.
under construction!
      11-13-2006, 08:41 PM   #11
txusa03
update, surprisingly the driver installed from cd, it even picked the usb port by default. But when I tried to print, it starts out with the print status of printing and 1 minutes later status change to Error Printing. Also, using the cd installation, the printer property list has the bidirectional capability grey out. So this particular printer does not support bidirectional right out of the cd installation. My question is I bought a bidirectional usb to parallel cable and will that cause the error and do I need to buy a non-bidirectional usb to parallel cable?
under construction!
      11-13-2006, 09:25 PM   #12
ska///235i
***** noob
ska///235i's Avatar
2006 325xi  [0.00]
so this is a old printer? did you use win98 before???
if so...this printer is too old for XP...my guess
2006 325xi (Sold)
      11-13-2006, 10:00 PM   #13
mds82
mds82's Avatar
379
Drives: 2006 325xi
Sell The Lexmark, Get An Hp Printer
      11-13-2006, 11:53 PM   #14
KaBoom
KaBoom's Avatar
Drives: 2006 325i
when you plug in your printer with the usb to parralel cable, does your computer recognize a usb device has plugged in? If so, install your printer as you would with proper driver. After that try this. Go into Printer Properties then go to Advanced tab and at the middle section of that tab, chose Print directly to the printer.
Also make sure your Print Spooler service is running.
      11-14-2006, 01:31 AM   #15
Gearcraft
misadventurer
Gearcraft's Avatar
Philippines
64
Drives: bubbie mystic blue whale
+1
325i I SP
      11-14-2006, 07:59 AM   #16
txusa03
yes, this printer was purchased back in the days when win98 was available. IT works on an older win98 computer.
Kaboom, Windows XP recognizes a new device. I no longer have the communication error. As I said, I now can see the print job in the printer queue, the print job initial status is 'PRINTING' and after a minute the job status change to 'ERROR-PRINTING'. I will try you suggestion when I get home. Thanks everyone for your inputs...
mds82, sorry cannot sell it since it is not my printer. I am just helping someone out.
under construction!
      11-14-2006, 06:16 PM   #17
txusa03
KaBoom, you the man, thanks. The print directly to the printer is the solution. However, if you choose print directly to the printer you cannot activate printer spooling. Thanks everyone else for your enlightful remarks as well
under construction!
