E90Post
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > noobie question
Reply
      04-18-2010, 03:08 AM   #1
510xcharles
Drives: 09 328i e90
noobie question
hey guys does anybody know if the supersprint full exhaust for the e90 325 and 330 work for 328s?
      04-18-2010, 01:50 PM   #2
Wlew
Wlew's Avatar
Drives: 2011 E90 335i
it should. I dont see why not.
2011 335i Sports Package | VRSF FMIC | Cobb AP3 | Dinan Exhaust | BMS Intake | VRSF CP | Lux H8 Angel Eyes | Mtec LED Fogs |
      04-18-2010, 05:27 PM   #3
Alexander
Mad tyte EuR0 style boooi <--- Joke
Alexander's Avatar
Drives: E30, E85, MKVI
325i, 328i, and the 330i are for the most part the same.
So yes.
      04-18-2010, 08:44 PM   #4
e90pilot
Freight Dawg
e90pilot's Avatar
Drives: E90 325i
The BMW performance exhaust fits on all the NA 3.0Ls so the SS exhaust shouldn't be a prolem. Also, all three engines share the same exhaust manifolds.
--Marcelo
'06 Arctic Metallic 325i | Sport Package | 6MT | Dinan Stage III suspension | Dinan exhaust | 330i manifold swap! Click here! | Active Autowerke tune | 135i Brake Calipers | Deiselboost caliper brackets | E46 M3 front rotors
      04-18-2010, 09:14 PM   #5
ramtin325i
ramtin325i's Avatar
17
Drives: 02 E46 ZSP
+1, the biggest difference on those cars are air intake manifolds + valvetronic timing/bore stroke.
      04-18-2010, 09:18 PM   #6
alpha325i
this chick >
alpha325i's Avatar
Drives: E92 328i
It will fit but don't waste your money on the full exhaust. I would just go with the Supersprint centre pipes w/o resonator and do a muffler delete.
Life's short, live fast ... drive a BMW
E90 325i - totaled 03/17/10 (R.I.P.)
E92 328i - took delivery 04/02/10
      04-18-2010, 09:25 PM   #7
Alexander
Alexander's Avatar
I saw that every day to this question. Why pay that much money for a cat back its crazy! Just go to an exhaust shop have a y-pipe installed to replace your resonator, then either straight pipe instead of a muffler, or get a Top Speed muffler or a Magnaflow muffler... Practically any exhaust system will work, it's so pointless to spend 1 grand + for a crappy cat back, which is practically the same as an OEM muffler.
My set-up
http://www.e90post.com/forums/showthread.php?t=356016
      04-18-2010, 09:52 PM   #8
BlackBimmer1991
BlackBimmer1991's Avatar
25
Drives: Black f32 428i xdrive
Dont waist money on something your going to loose hp on
      04-18-2010, 11:09 PM   #9
Alexander
Alexander's Avatar
Ehh... Still not sure about that. Touchy subject.
      04-18-2010, 11:53 PM   #10
e90pilot
Freight Dawg
e90pilot's Avatar
Drives: E90 325i
If it's a US spec 325/25/30 bore and stroke are identical. Part numbers for pistons and blocks are identical.
As for power loss, I don't really know about that but for a car like min which doesn't have a lot of power, I'd buy an exhaust purly based on sound provided it doesn't throw codes or rusts off in a month.
--Marcelo
      04-19-2010, 01:21 AM   #11
510xcharles
Drives: 09 328i e90
My set-up
well the thing is id like to eventualy convert the rear to centralized quads, and if i were to get a y pipe wouldnt i need to take out the trunk compartment as well. if so that would require more work =/
      04-19-2010, 02:19 AM   #12
Wlew
Wlew's Avatar
I have done a lot of research on the whole power loss thing. with a new muffler you may key word may lose a couple ft/lbs of tq in the low rpms, but you gain at least 5-8 hp or so in the upper RPMs. so when you think about it, not too many of us are going to the drag strip on a daily basis. it worth losing a few ft/lbs for nice sound. I wouldnt spend the money on a full system unless it was bmw performance. but thats my opinion. I have the Top Speed pro 1 muffler and love it. its cheaper and has nice sound/good gains in high rpm's.
with the muffler and res delete, yea you proabably do lose a little power, too much backpressure lost, but on the other hand you also lose about 60 or so pounds with deleting it all. so every 10 lbs is 1hp, in theory. so it probably evens out.
with that in mind how much does the stock muffler weigh? I have heard everywhre from 35-65 pounds and the resonator about 14 lbs.
      04-19-2010, 03:37 PM   #13
BlackBimmer1991
25
Does the bmw performance exhaust get rid of the resonator?
      04-20-2010, 12:46 AM   #14
e90pilot
Freight Dawg
e90pilot's Avatar
Drives: E90 325i
No, but it does replace it.
--Marcelo
Reply
e90post
