06 330i + 4yrs + 57k miles = Trouble begins. (Mis-fire related)
05-05-2010, 06:04 PM | #1 |
missing two turbos.
581
Rep 4,859
Drives: fast around corners.
Yesterday, my car took a dump on me.
Perfectly fine throughout the day. Late night at 10pm, trying to go home from my buddy's.. I start the car and all of sudden my car was acting like a 9sec-drag racing car with quad turbos. The whole car was vibrating like a cell phone and exhaust note was louder than a WRX with 5" piping. I try to rev the car a little bit and took it up to 2000rpm. It sounded like I was at 9000rpm. It was so loud. High-pitched screaming in a very bad way. I reversed out of the parking lot and try to get home(less than 0.5 miles away) without using the gas pedal. Afraid of damaging anything further, I stopped the car and pushed the car home. Mean while, a nice red 350z and gray G35 passed by, laughing. which I understand. I would too. Long story short, I just picked up my car from BMW of Eugene. $70 for towing $90 for rental car $310 for the repair + diagnoses = Grand total of $470. Thank you very much. Superb engineers in Germany builds these cars so well, they made sure it breaks down RIGHT after the warranty expires. Cheers. Those of you hesistating for extended warranty, this is exactly what I was talking about in those previous threads. For those of you with knowledge in mechanical experiences, please help me analyze what caused this, what is long-term effect of this, and what I have to do to prevent this problem: "Customer states there is a vibration/noise upon acceleration. Had to have the car towed. Check and report, verified car is missfiring. Checked faults in DME. Followed SIB 110505. Removed VANOS solenoids and cleaned with air. Reinstalled and checked integration level. Ok. Started the car, still missfires. Removed spark plug and coil on Cylinder 5. Insulation of plug appears to have been overheated. Spark plug and ignition coil on cylinder 5 are bad. Replaced spark plug and ignition coil for cylinder 5 and cleared faults. Car starts and runs smoothly. Parts: Spark plug. High PO: $21.66 Parts: Ignition coil: $58.16 Job: Labor - $220.00 Job: Shop supplies - $10.00
06 AW E90 330i ZPP/ZSP/Step/Expired Warranty : Prior Design Front : ACS Rear : ACS Roof : BlackLines : Simota Intake : Carbon Fiber Interior Trim : : MTEC V3 : 24% Charcoal : V1 Hardwired : Solaris Invisibulbs/LED interior : Last edited by lux.sh; 05-24-2010 at 05:07 AM.. |
05-05-2010, 06:33 PM | #2 |
Rep 1,160
Well its common for spark plugs and coils to go in about any car.
My coil went on me a few months ago cost $80 from the dealer and replaced it myself
Monaco Blue 330xi - Terra Interior/6-MT/Sport/Premium/Cold/CSL's/M3 Spoiler Lip/Black Kidney's
05-05-2010, 06:35 PM | #3 |
Rep 6,149
Heck the whole car is a computer. They have it programmed to automatically self destruct after 50K is you do not have extended warranty.
If you will be purchasing ANY AT&T services online or in store could you mention that you were referred by me? My Employee Referral ID is eo4489. This would be a great help and it costs you nothing, thank you!
05-05-2010, 06:43 PM | #4 |
Rep 131
05-05-2010, 06:43 PM | #5 |
Rep 195
05-05-2010, 06:54 PM | #6 | |
missing two turbos.
581
Rep 4,859
knowledge is power guys. Learn how to do it yourself and don't waste $220 on labor like me.
06 AW E90 330i ZPP/ZSP/Step/Expired Warranty : Prior Design Front : ACS Rear : ACS Roof : BlackLines : Simota Intake : Carbon Fiber Interior Trim : : MTEC V3 : 24% Charcoal : V1 Hardwired : Solaris Invisibulbs/LED interior : |
05-05-2010, 07:17 PM | #7 |
Rep 1,754
You know, I like BMW of Eugene -- they helped us out a number of years ago when the crank sensor went out on my E36 M3 in the middle of a long road trip. Very nice to deal with...BUT:
You got an not-so-expensive lesson on why not to take your car to the dealer for non-warranty work. You could have had the job done for half that at almost any independent BMW shop, using the same parts. If this had been a big labor job, though, you could have spent hundreds, needlessly, just by using the dealer. |
05-05-2010, 07:29 PM | #8 | |
missing two turbos.
581
Rep 4,859
It was definitely cheaper to get it diagnosed at the local shop. I was worried about the problem being bigger than I expected, so I decided to take it to the dealer just for diagnoses. If extensive repair is needed, I was going to take it to the local shop and tell them what the problem is according to BMW dealer and let them repair it. When the dealership said total is $310 including diagnoses, I figured towing it back to local shop and all is going to be a big hassle so I just told BMW Eugene to do it. I know what to do next time. Thanks for the tip.
05-05-2010, 07:55 PM | #9 | |
Rep 14,829
The 335 has stalled over 40 times and failed to start 3X. I know, high mileage, 18k. |
05-05-2010, 08:00 PM | #10 | |
Rep 1,754
05-05-2010, 08:09 PM | #11 |
missing two turbos.
581
Rep 4,859
whats wrong with nissan again?
05-05-2010, 08:53 PM | #13 |
Rep 195
Do you want to take a gander at how much a brake job costs at that little gem? Nope...too low. According to automobile magazine at 21k they paid $7346 to get new pads, discs, and fluid changed. High performance costs money. The better performing and more advanced vehicle the higher the costs to own will be. I am not defending BMW as hpfp problems really suck, but I know all competitors to this car are not perfect either. The 08 G35 I had was certainly not.....the rotors warp like clockwork and the interior wears horribly, the dashboards warp (good luck getting that covered under warranty...I was told "they all do it...go check the lot")...check those forums if you don't believe me. Now, I am not bashing a Camry or Altima owner, but don't try to compare this vehicle to a BMW and expect it to be the same.
05-05-2010, 10:13 PM | #14 |
Max Powers
29
Rep 271
i had the same problem in my 330i. misfire...same symptoms...faulty coil replaced. fortunately it was covered under CPO warranty. just plain bad luck, i guess. i gotta find an indi-shop for when my CPO runs out.
05-05-2010, 10:19 PM | #15 |
Rep 7,089
Drives: '06 AW 330xi
You guys are all scaring me. I'm approaching 57K...I've already hit 4 years this month and have 52175 on the OD. I think one of my coils are going bad too. I'm been experiencing long cranks in the morning and my car feels slower.
05-05-2010, 10:29 PM | #16 |
Rep 2,783
To the OP and anyone else thinking that the extended warranty is a god send. I don't think the coils or plugs are covered. http://www.e90post.com/forums/showth...ghlight=beware
You need to invest in a peake reseach tool or a BT scan tool. You will save a ton of money and it will pay for itself after just one scan. |
05-05-2010, 10:36 PM | #17 | |
missing two turbos.
581
Rep 4,859
What people often get confused with these "top notch" vehicles is that general population expects "better quality per dollar". These people don't know too much about cars, they just expect better quality overall. Most of us, who knows about cars do not expect Toyota reliability(this term should no longer be used due to recall issue ), but rather "better performance per dollar". This becomes quite annoying however, when repair bills add up or time spent at dealership getting stuff fixed is becoming overwhelming(or interrupting your life). I think thats where people start complaining, even though they know they paid extra for the performance/balance aspect, not a trouble-free fee. This applies to ANY brand, like your Infiniti. Comparing Camry to 3 series is just plain stupid and I think we all know that we sacrificed a bit of reliability for performance. Hey now that I think about it, this might be a fun topic to discuss in this forum. I might create a thread regardint reliability. Pitch in if you see it.
05-05-2010, 10:39 PM | #18 | |
missing two turbos.
581
Rep 4,859
05-05-2010, 10:58 PM | #19 | |
Rep 1,754
05-15-2010, 09:19 PM | #20 |
Rep 69
Sorry to hear about the mess. At least it was not too costly. My old Honda cost me about $600 while it was STILL UNDER WARRANTY to fix mega crappy brakes more than once. You never know, but there are many people on here with e90s that have not spent much at all on repairs / maintenance. One thing here and there is bound to happen.
05-16-2010, 12:13 PM | #21 |
Rep 6,992
Drives: 15 F80 M3, 22 G01 X3 30i
Within any family of vehicles, be it BMW or Kia, you're going to get some with more problems than others, and some that have none at all. I had a coil go out on an '03 ZHP, and it turned out that there was a service bulletin on a bad design that caused the coils to overheat and fail. They replaced all 6 at no cost to me other than the time spent at the dealership.
That said, with sophistication comes complexity, and with that complexity, the probability of a failure will increase. My wife's Altima will probably never have any of the issues that pop up with cars that are loaded with electronics and the superior handling and performance of a BMW. But it will never look, handle, or perform like a BMW either. Are we "compromising" reliability for performance? Depends on your viewpoint, but I had my share of issues with the Porsches I used to own too.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey |
