Paddleshifters a deal breaker ?
05-12-2010, 10:31 PM | #1 |
Rep 345
So I have been searching for an e92 328xi for a while now and decided against manual since a)not a fan of the shift feel b)this will be my 'city' daily driver ( lot of traffic )so it just does not make sense for me right now.
With that in mind I really want to at least have paddles. My issue is that I am finding it difficult to find a paddle shift equipped xi. I am almost willing to pick up one without paddles and have it added afterwards through the aftermarket(sponsors?) (apparently this is possible through the threads i've read on it) What are your expert takes on this? Worth converting afterwards or should I just hold off until I can find one equipped with it? |
05-12-2010, 11:15 PM | #5 |
Rep 3,012
I retrofitted my paddle shifters. If my current deal falls through, I'm selling the entire setup for $500 including the retrofit harness, multi-function buttons and paddleshifters all of it only a few weeks old... Then tell me how much the dealer option costs. I seriously doubt its cheaper than that. Plus, the install is really simple if you have a screw driver and a brain.
05-13-2010, 12:16 AM | #6 | |
Rep 15
Also, it's definitely not worth the money to do a retrofit. They're about $100 if you option them on a new car, right? Even at $100 I don't know if I would order them knowing what I know now. It looks cool on TV watching the F1 cars with the push button shifting, but those guys rarely turn the "wheel" more than 90 degrees. |
05-13-2010, 12:20 AM | #7 | |
Rep 203
+1 Vantage_coupe; you do know that you can still go through the gears on the AT's "stick" right? I use that WAY more |
05-13-2010, 01:38 AM | #8 |
Black Mamba
66
Rep 1,326
I was pretty excited that my CPO came with paddles, but honestly after 5 months I might have used it a couple times.
05-13-2010, 08:52 AM | #9 |
Rep 767
Rarely use mine unless I am out for a twisty drive in the country. Plus if you get them be aware that they are wired incorrectly so you will probably want to go in a rewire them anyway !! I did.
05-13-2010, 09:05 AM | #10 |
Rep 367
Drives: E88 135i
I got my 335 with paddles and I love them! I rather have a manual but with the baby and my wife not knowing how to drive stick, it seemed more logical to get a car she can drive if needed. With that I made sure to get the paddles so I can still have fun and I use them all the time, maybe like 80-90% of the time? I don't use them much for going to work (since I work 5 minutes from our house) but on the weekends and long trips, I'll go back and forth between "D" and "M" depending on the driving situation. But I'm probably among the 1% of users who use the auto in this way, but it's the best compromise to getting a manual IMO (unless DCT was available in the states, then thats the best compromise!)
'10 N54 135i Cabrio || ///M-Sport || SCHWARZ/BEIGE
Mods: JB4, Trebila Custom tune, FBO, Fuel-It Stg2 LPFP, Berk Street Performance w/ Berk Resonated Midpipes, & lots of little body/OEM+ mods |
05-13-2010, 09:15 AM | #11 | |
Rep 564
I alternate between using the paddles and console-mounted shift lever. In a straight line, I tend to just use the shift lever. In the twists, I use the paddles. Hard turns that require the wheel to be really cranked, as mentioned in previous posts, require the use of shift level. OP, have you considered ordering the car so that you get everything you want? |
05-13-2010, 11:20 AM | #12 |
BMW Addict
102
Rep 792
Have them but rarely use them. As stated by others, they work best in conjunction with moderate wheel turn. I wouldn't consider not having them a deal breaker, especially if the vehicle is otherwise optioned out the way you want it.
'11 Black Sapphire F10 550i l ZSP l Avant Garde 20" M310
05-13-2010, 11:28 AM | #13 | |
Rep 609
1.) when I'm turning into a corner and downshift just before the turn 2.) Coming out of a turn and want to downshift for extra power 3.) Just before I pass a car, I hit it twice to downshift and then take off
2019 Z4 sDrive 30i Msport,
Previously owned BMWs, 2014 428i Msport, 2008 335i Coupe, 2007 328xi sedan, 2002 325i sedan 1996 318ti (loved this little car) |
05-13-2010, 11:36 AM | #14 |
Rep 261
The paddles are alright, but more often then not I find myself shifting using the stick. It's just not convenient if you're in the middle of a turn to try and find a paddle on the wheel, but I do use them on straights.
05-13-2010, 11:41 AM | #15 |
Rep 4,771
wow, that's exactly the opposite of what I do. I find it amazing to use the paddles on the straights but because of turning the wheel I use the stick in corners
05-13-2010, 04:24 PM | #17 | |
I ask the questions you're afraid to ask.
44
Rep 2,489
The paddles (as an option on a new 3 series) cost $100 |
05-14-2010, 09:15 AM | #18 |
Rep 345
Thanks for the comments guys! In an interesting turn of events I've found a
07 with 52k without paddles 08 with 20k with paddles for an extra 2 grand with less warranty and some minor scuffs I'm swaying towards to the 07 since it's got extended warranty already purchased to 2013 (08 just has regular warranty to 2012) thoughts? |
05-14-2010, 11:57 AM | #19 | |
Rep 203
2008 has less milesf for 2000 more sounds good. The 08 may have scuffs but where? Bumper? you may want to change it anyways down the line. 2007 may have extended warranty, but have more than double the miles. Check the 07 to see if it has the oil cooler. |
05-14-2010, 02:54 PM | #20 | |
Rep 345
I was under the assumption that it was only the 335s that had the oil cooler? Does the 328xi also have/need one? |
05-14-2010, 04:35 PM | #22 |
Rep 1,859
Never even bothered with the paddles. I hate how they're set up. Much more fun just leaving the car in "DS" or if anything just shift using the shift lever in M mode. The M3 with the DCT paddles are set up perfectly, not so much on Step 335's.
