Is there any way to "reset" your "learned" throttle response in a 2009 328 coupe?
05-14-2010, 09:50 AM | #1 |
Came to the N55 Darkside
1115
Rep 12,740
I am getting some odd jumpiness since I had the BMS Powerbox installed, and would like to reset the learned throttle response to have the car "relearn" with this mod in place. Any ideas that work save going to the dealer and resetting it there? Thanks!
05-14-2010, 09:54 AM | #2 |
I do my crosswords in pen.
17
Rep 751
1. Get in the car
2. Put key in ignition, foot off the brake, do not start the car 3. Floor the gas and hold it for at least 30 seconds. Your throttle should begin the process of adapting again.
GRUPPE TITAN Midwest
05-14-2010, 10:46 AM | #4 |
17
Rep 751
Also, once you reset, if you're wanting alot of responsiveness be sure to floor it a couple times so it learns to respond even quicker. If you're looking for a softer pedal go easy on it.
05-14-2010, 10:57 AM | #5 |
Rep 1,300
Stupid question maybe, mine has no mods but I have poor throttle response, it has flat spots, will this reset a stock setup as well?
Brian
Black Sapphire, Black w/Burrwood Trim & Shifter, 162's, Mtec H8 AE's, DS1 HID 6000K |
05-14-2010, 11:19 AM | #6 |
17
Rep 751
Yea absolutely. The stock response is pretty tame compared to one with a PBX, but resetting it and driving aggresively should help a little bit. Reset away! I do it like every week just because I like the most brutal response I can get.
05-14-2010, 11:20 AM | #7 | |
The Sinner
15
Rep 341
For the 2nd part, do I hold the start button without pressing the clutch or do I just put the key in the hole and then floor the gas? |
05-14-2010, 11:37 AM | #8 | |
17
Rep 751
There's tons of info about this if you guys want more just search a bit. There's some gargantuan thread about the pros and cons of this and whether it actually works. I for myself feel the difference when I do this, and it has led me to firmly conclude that this is the way to reset the throttle without an OBD2 cable.
05-14-2010, 02:16 PM | #11 |
17
Rep 751
No that's my bad dude, i was rude and didn't realize you were the OP. Heh! Sorry!
