Check Engine Light on, covered by CPO?
05-16-2010, 11:19 AM | #1 |
Rep 343
Just started my car the light is on. Turn it off started again still on. Is that covered by CPO? I mean checking what is causing the light?
I just had the car inspection and they didnt find a thing last week.... |
05-16-2010, 11:27 AM | #2 |
Rep 6,128
Most likely, yes it will be covered. No guarantees. If whatever has to be fixed is not covered under the warranty or if you are modified, then it probably won't be covered.
When you say impact instead of affect/effect, you are communicating that you don't understand the difference between the two words, and are too lazy to learn.
05-16-2010, 11:41 AM | #3 |
Rep 343
I read the fault code myself just now using peake tool, it said misfire Cylinder 6. So does that mean one spark went bad? And if this cylinder misfire is covered by CPO? Thanks...
05-16-2010, 12:01 PM | #4 |
Rep 6,992
Drives: 15 F80 M3, 22 G01 X3 30i
Again, depends on what they diagnose as the cause. Could be faulty plug or coil, which is easily fixed. Will your peake tool reset it? Might try that and see if it happens again. If it does, then take it to dealer 1st, see if it's covered, then if not, take it to a good independent BMW shop.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey |
05-16-2010, 12:01 PM | #5 | |
Where my bitches
749
Rep 1,924
Drives: Cadillac coupe deville
http://www.bmwusa.com/Standard/Conte...y/Covered.aspx 5 seconds of searching man http://www.bmwusa.com/Standard/Conte...otCovered.aspx whats not covered^^
