E90 completely dead....
05-16-2010, 10:02 PM | #1 |
Rep 427
Here's the scenario in all the steps in as much of detail as possible:
1. open the car with the fob all the interior and exterior lighting is on. 2. put the fob into the dash, get the nice ring ring from the car, radio comes on everything is normal. 3. step on the clutch press the start engine button 4. the engine starts to crank for like 1/4 of a second and then bam everything just shuts off. 5. there is no power at all anywhere, windows don't work, dome lights don't turn on anything electrical will not turn on, complete darkness. 6. Fob is stuck can't remove it at all, can't close the driver side door either. Anybody know what could be wrong. No warning sings of any kind preceding this. Drove the car perfectly fine 2 hours ago prior to this. Any help at all? |
05-16-2010, 10:31 PM | #3 |
Now in the dark side !
65
Rep 1,136
I've seen this on other cars before.
Look if one of the terminal on the battery is not tightened enough. Will work until you put some load on it (starter for instance). Let us know.
Present: 2011 Porsche Carrera S Cab, white (Now on the dark side!)
BMW X3 M40i (wifey) Past:2012 335i Sport Black, 20" 356 wheels, M Sport Aero, MPE (Sold -kinda missed) 2010 X5 35d Black fully loaded (Sold) 2007 335i sedan Antracite (Sold and missed !) |
05-16-2010, 10:34 PM | #4 |
Rep 1,922
Drives: 2021 G80 M3
I'd say alternator, but the car is not that old to need its alternator replaced. but sounds like a big load like the starter is pulling more current than the battery or alternator handle. keep us posted
'21 G80 M3
'11 E82 135i DCT (Gone but not forgotten) '08 E90 335i (Gone but not forgotten) |
05-16-2010, 11:14 PM | #5 |
Rep 6,149
Keep us posted OP. Good luck, hope it is minor.
If you will be purchasing ANY AT&T services online or in store could you mention that you were referred by me? My Employee Referral ID is eo4489. This would be a great help and it costs you nothing, thank you!
05-17-2010, 10:27 AM | #7 |
Rep 612
+1. Sounds like a dead battery to me
My Garage:
'13 F30 328i (Wifey) '11 Silverado CC (DD) '06 Carrera S (Fun) Sold: 08 E92 335, 07 X5 |
05-17-2010, 03:14 PM | #9 | |
Rep 214
05-17-2010, 03:27 PM | #10 |
Rep 1,046
Could be a bad rotary girder.
'17 M3 Imola Red/Carbonstructure Cloth, Competition, Lighting, 6MT
Retired: '93 325i |'99 Jeep Wrangler Sport |'06 330i Sport |'08 335i Sport |'08 328i Sport |'09 335d Sport |
05-17-2010, 04:05 PM | #11 |
Rep 2,017
Drives: AW 07 e92 335i + AW 11 X5 35d
I had the same exact thing happen to me after starting my car from extended trip (3 weeks). It was a bad battery cell. Dealer replaced and new battery and I was good to go.
05-17-2010, 04:21 PM | #12 |
Rep 427
It's not a bad battery. Got home from work, opened the car, still dark like the caverns in there as if the car had no battery in it. Hooked up the multimeter and getting a readout of 12.5 volts, which is exactly right. Nothing loose on the terminals either.
05-17-2010, 04:29 PM | #13 |
Rep 125
No volts
Could still be battery since voltage reading is only a good test when battery is under load. However, since you say everything is now dead (no lights, etc.), I'd say your battery connection is bad.
Someone recently had the same problem and it was a bad negative ground cable, i.e., connection was good on both ends, the cable itself had become defective.
___________________
Robert |
05-17-2010, 04:41 PM | #15 |
Rep 427
Ok now this is really effing weird. As I was walked into my house my father asked me what I was doing. I told him what happened and I went into the bathroom, I came out and he tossed me the fob and said the car is fine.
I asked him what the hell did he do, he said that he just went over to my car opened the door and the radio was on and all the lights were on as well, (I left the fob in the dash), he just pushed the fob in and took it out. I jumped into the drivers seat put the fob in and everything is back to normal and the car starts as if nothing ever happened. The only trace is that the clock is reset and the radio stations. WTF!!?? I searched the board and I'm not the only one, at least another instance on this board of this issue has been documented same symptoms issue also resolved on it's own... http://www.e90post.com/forums/showth...stuck+car+dead |
05-17-2010, 04:43 PM | #16 |
missing two turbos.
581
Rep 4,859
Drives: fast around corners.
dude watch out. Transformers. she just messin' with you.
06 AW E90 330i ZPP/ZSP/Step/Expired Warranty : Prior Design Front : ACS Rear : ACS Roof : BlackLines : Simota Intake : Carbon Fiber Interior Trim : : MTEC V3 : 24% Charcoal : V1 Hardwired : Solaris Invisibulbs/LED interior : |
05-17-2010, 05:35 PM | #18 |
YNWA
194
Rep 1,814
Dude same thing happened to my car. It was just a bad battery and BMW replaced it for me
And for me it too came without any warning.
Imola Red ZCP F80 M3
05-17-2010, 06:19 PM | #19 | |
Rep 1,938
12.6 V or more for fully charged 12.4 V 75 % charged 12.2 V 50 % 12.0 V 25 % 11.7 V or less for fully discharged On my 330xi, the lights would not turn on and the voltage was so low the lock solenoids failed, I had to use the mechanical key to get in. BTW, I took the car to the dealer next day or so, hoping that he would read the error stack, and he told me that the car failed to go to sleep properly. Mercifully, the low battery show has never been repeated. I hope this helps - good luck. Last edited by Oulixes; 05-26-2010 at 04:24 PM.. |
05-17-2010, 06:35 PM | #20 |
Rep 14,829
Our cars are pretty complicated, so unfortunately I think it has to go to the dealership. We are totally speculating on this thread. We're so far from the days when you checked fuel and spark, and could narrow it down just like that, from there.. Even the dealership (from my experience) has problems programming and "adapting" the car, and needs help from BMWNA.
05-17-2010, 09:07 PM | #22 | |
Rep 219
I've seen this happen, especially if the negative cable is loose. I had a similar situation happen on my old E36 (no fob of course), and it was a loose cable too. Be sure to check or have someone check both connections of each cable. |
