Lowered my car and....
05-18-2010, 09:55 PM | #1 |
Hye
22
Rep 140
So i lowered my 335xi today and i have several issues....if any of you can let me know what could be wrong, it would be immense help.
I will try to explain how much it was lowered. The front: from the bottom of the lip (of the rim) to top of the tire, the measurement was to lower the car to 60 cm, Back: 59.5 cm. A finger still fits between the gap in the front, not so much in the back. Its dark out, tomorrow ill take some pictures for better understanding. When i accelerate from 0 to 60...the car is very slow compared to before and the yellow traction lights start blinking, i believe this means its slipping...never had this happen before....also at some point when accelerating the rpm was stuck at 3000 r/min for a good second and it did not go up....im worried, what could be wrong? I have not done alignment yet, im waiting a while for springs to settle in....would alignment fix this problem or is it totally something else
05-18-2010, 10:05 PM | #2 |
Rep 2,731
sound like the dsc is detecting wheel slippage and is limiting power. kinda like if you floor it on ice or sand the car will just pull away slowly.
did you damage the wires or sensors during the install? |
05-18-2010, 10:06 PM | #3 | |
Hye
22
Rep 140
i didnt install it...local shop did.....what should i do? go somewhere different and get it checked to see if everything is ok?
05-18-2010, 10:10 PM | #5 |
Hye
22
Rep 140
nope i didnt change anything else, just installed kw v1s....same tire and rims as before....rims are 19 inch, tires are 235 in the front and staggered 265 in the back i believe.....dunno exactly right now, i can check and let u know.
05-18-2010, 10:16 PM | #6 |
Rep 2,731
was just wondering because on an xi if the rears have a different overall diameter than the fronts it can cause issues with the dsc and all wheel drive.
anyway im thinking that if you are sure you arent rubbing thats causing the interference during acceleration, then its the dsc or some kind of engine management shit doing it. would make sense that a wheel speed sensor or wire could have been damaged in the wheel well but i would think you would have a dsc failure and abs failure warning light right now. if you are rubbing reallly really bad enough to slow the wheel to the point that it lost traction that the dsc would see that as slipping and intervene. thats some serious rubbing though lol. as far as your alignment question....maybe some kind of fucked up alignment shit where the toe is so excessive on one side of the rear that the wheel speed of that side if getting thrown off and confusing the dsc, doubt it though, never heard of anything like that. Last edited by mike3000fl; 05-18-2010 at 10:22 PM.. |
05-18-2010, 11:00 PM | #9 |
Rep 6,473
Maybe it was just cociendence that this is happening the right after you lowered your car. I would d=take it back to the installer and have them raise it up while you visually inspect it for damage.
05-18-2010, 11:04 PM | #10 |
Hye
22
Rep 140
i think i will do that......i was testing it the whole night on map 3.... the car revs high as it should, but the car doesnt move as fast as it suppose to during those revs
05-20-2010, 08:03 AM | #12 |
Rep 3,606
I cant believe a reputable service guy would do the suspension work without doing the alignment. Who did it? A gas station? Get that fixed first.
05-20-2010, 08:05 AM | #13 |
Rep 3,606
05-20-2010, 08:19 AM | #14 |
Rep 896
Drives: 2021 X5
I have an OEM 18'' staggered set up with the sport package option on my 335i xDrive
2018 540d xDrive Carbon Black Metallic on Cognac leather. Spec'd out to the max
2017 Mercedes C43 AMG Coupe. Black on black |
05-20-2010, 01:40 PM | #15 |
Rep 1,730
I've got OEM 18" staggered on 335xi with KWv1 installed. I initially had rubbing when first installed due to 12mm spacers on the rear. I feel no difference in speed whatsoever.
Jack it up and check for any damage to wires, etc. Something went wrong during the install. Maybe the mechanic stole your tune...
'11 Space Grey E92 335xi M-Sport (KWv1 Coils | Saddle Brown | Bamboo) (Returned)
'14 Mineral Grey F32 335i M-Sport (Dinan DHP | LED Lights | Coral Red | Hexagonal Aluminum) (Returned) '16 Mineral Grey F80 M3 ZCP |
05-20-2010, 01:52 PM | #17 | |
Rep 3,606
05-20-2010, 08:05 PM | #20 |
Rep 2,731
05-21-2010, 06:45 AM | #21 |
BMW 321 1947
Rep 1
I am quite sure that problem is sensor of the steering axis (sorry, don't know the correct name of this axel). This sensor think now that your car don't go straight and it gives error messages for the system and power goes down. They have tools for adjusting in the BMW's dealer workshops. They can also check first is this sensor adjusted the right way. I have heard that position of the sensor is quite critical, so maybe something has changed in your car.
BMW e91 320Ad 2006
BMW 321 1947 |
05-21-2010, 11:05 AM | #22 |
One cam is enough
Rep 6,801
