E90Post
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Torque specs - MT and differential plugs
Reply
      05-26-2010, 08:32 AM   #1
Wrighton
Drives: E90 335
I am planning on changing the manual transmission fluid and differential fluid (I know, they are supposedly 'lifetime' fluids). I have searched, but not found the torque specs for the 8 mm hex fill and drain plugs for the transmission. Or the torque spec for the 14 mm hex differential plug.
This is for an E90 335i w/sport pkg, if it makes a difference
Thanks for any help!
      05-26-2010, 09:42 AM   #2
orangedawg
Drives: 328xi
Front differential (at least on xi models), according to Bentley says "oil filler plug to differential" is 44 ft/lb. Same for rear diff.
For MT, it list two values. For M12 x 1.5. it's 18 ft/lb. For M18 x 1.5, it's 26 ft/lb. Hope this helps.
      05-26-2010, 04:36 PM   #3
Wrighton
Drives: E90 335
Thanks. Both the MT fill and drain are the same, the M18. Really just concerned about 'over torquing' and damaging anything.
      05-26-2010, 08:36 PM   #4
Oulixes
Oulixes's Avatar
22
Drives: 330xi, 335i
+1
Reply
e90post
