E90Post
Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > Africa > Subwoofer
Reply
      06-05-2010, 03:16 AM   #1
Hensel
Drives: BMW 330i Sport auto
Subwoofer
Hi Guys,Took delivery of a used BMW yesterday but found out that the speakers under the seat don't work. Sound system does not sound good at all. what could be the problem
      06-05-2010, 06:31 AM   #2
BMW-NC
Selling drugs to BMW addicts
BMW-NC's Avatar
Germany
17
Drives: 135i e82 6MT N55
take it to the dealer???
a bit more information might be helpful....
Quality US Spec Used Cars for Military Members stationed in Europe. Specialized in BMWs and MINIs up to 10k miles.
      06-06-2010, 11:58 AM   #3
Menno11
Member
Menno11's Avatar
South Africa
35
Drives: 320d
2005 320d  [0.00]
Lift up the carpet next to the front seats (between door and seat at the join) and check that the wire is connected to the underseat speakers. Sometimes the audio guys use the signal for additional subs in the boot.
      06-11-2010, 08:36 AM   #4
Hensel
What subs can i replace the ones under the seat with
      06-13-2010, 03:54 AM   #5
Menno11
Member
Menno11's Avatar
South Africa
35
Drives: 320d
2005 320d  [0.00]
you can use the earthquake SWS8, or the Pioneer FLAT 8", these are the ones that fit in the current enclosure, there are a number of 6.5" split systems that fit too, but the grills then stick out.
      04-06-2011, 08:15 PM   #6
virk007
virk007's Avatar
Drives: 2007 E90 328i AW
2007 BMW 328i  [0.00]
2000 BMW 323CI  [0.00]
same thing happened to me today i was driving and all of sudden my bass stops working. Will this be covered under warranty?
      04-07-2011, 12:19 PM   #7
7isPerfect
7isPerfect's Avatar
Drives: F06 650I
if you are under warranty everything should be covered
      04-26-2011, 10:22 AM   #8
Menno11
Member
Menno11's Avatar
South Africa
35
Drives: 320d
2005 320d  [0.00]
Virk, did you get your subs replaced?
      04-26-2011, 10:27 AM   #9
aarwilli
Drives: 08 335i Coupe
In my 08 e92, I can't really hear the subs doing anything either and can only barely feel them moving. Wonder if this is my problem as to....Do you guys usually hear them specifically hit. I always just thought they were designed to blend in well to the rest of the sound so you didn't hear them specifically.
      04-27-2011, 02:11 AM   #10
Menno11
Member
Menno11's Avatar
South Africa
35
Drives: 320d
2005 320d  [0.00]
The stock E9x system without logic7 is a very underpowered system as proven by the many people complaining about the sound. There is a distinct lack of bass, especially midbass in the saloons. I have personally replaced my underseat subs with Infinity 6.5" mid bass driver that is now powered by an amp in the boot and boy is there a marked improvement in the mid-bass and as stated you can actually feel the music now!
Word of warning, if you dont have a logic7 system, dont try and amplify the stock underseat subs as they are 2ohm to work more efficient on the low power from the head unit. I amplified my stock subs and consequently melted the coils on both subs, hence the replacement :-)
Reply
e90post
