E90Post
Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > newbie question...how is the 330i pulling 15 extra hp over the 325?
Reply
      09-04-2005, 04:58 PM   #1
nine4surfah
nine4surfah's Avatar
Drives: 325i Electric Red
2006 325i  [0.00]
newbie question...how is the 330i pulling 45 extra hp over the 325?
I'm new to the BMW community and I just recently purchased a 325I. I really wanted a 330I because of the extra hp! Unfortunately I was on a budget restraint . After doing some research I noticed that the two have the exact same motor displacement and compression. Are the 330's tuned more aggressively than th 325?
Last edited by nine4surfah; 09-04-2005 at 09:08 PM.. Reason: typo...I meant 45hp not 15.
      09-04-2005, 05:18 PM   #2
Ed_330i
Ed_330i's Avatar
60
Drives: 2006 330i
the double vanos is stronger on the 330i.
and i thought it was more than just 15?
      09-04-2005, 05:23 PM   #3
theclay
theclay's Avatar
20
Drives: '06 330i
2006 330i  [0.00]
Yeah, it's 40.
Jet Black, Black Leather, Aluminum Trim, Sport, Premium, Steptronic, 35% tint
      09-04-2005, 09:07 PM   #4
nine4surfah
2006 325i  [0.00]
typo......sorry i meant 45hps
      09-04-2005, 09:11 PM   #5
coco
coco's Avatar
14
Drives: Bimmmer
Check out these thread, mainly it's probably the ECU and the intake that makes the difference.
http://www.e90post.com/forums/showthread.php?t=1596
http://www.e90post.com/forums/showthread.php?t=1360
Also, here's a chart of the same/different parts between the 325 and 330
      09-04-2005, 09:16 PM   #6
nine4surfah
2006 325i  [0.00]
I'm such a newb.....I did a search and found my answer....previous posts
sorry for the repost!
      09-04-2005, 09:18 PM   #7
ZenDriver
Do Not Taunt Zen Driver.
ZenDriver's Avatar
12
Drives: 325i w/ MT, ZSP in Graphite
The engines are the EXACT same... the part numbers are identical (11000404774).
In fact, both engines are clasified as the same (N52B30) by BMW. Checking the ETK, the only part differences between the two are the intake plenum. Most of the 45bhp difference comes from software changes. The N52B30 was designed in the 330i configuration and nutered to make the 325i configuration.
I suspect Dinan and Jim C will have a field day with the 325...
      09-04-2005, 09:29 PM   #8
RichReg
RichReg's Avatar
Drives: 2015 435Xi GC & 2000 323Ci.
Yeah, sure they will.
That's why they have no replies when I ask them when something will be available for the 325.
Also, the chart that coco posted doesn't list the different intake manifold for the 330, as well as the adjuster units for the variable intake:
330i
Intake manifold : 11 61 7 522 927
Adjuster unit : 11 61 7 522 929
Adjuster unit : 11 61 7 522 928
325i
Intake manifold : 11 61 7 542 757
(No adjuster units)
It should also be noted that the manual transmission on the 325 is not rated for any more hp than 215. I have all 3 Dinan upgrades on my 323Ci and recently when I went for an oil change @ 83K miles, the mechanic noticed a very slight leak of transmission fluid in the driveshaft. He said its normal @ that mileage, but I'm still wary....
      09-04-2005, 10:52 PM   #9
Ed_330i
Ed_330i's Avatar
60
Drives: 2006 330i
wtf, you mean the tranny in the 325 cant handle safely more than 215?
god BMW, jerks!
      09-04-2005, 11:21 PM   #10
blueStreak
Drives: 550i
I'd think the cams would be different as well.
      09-05-2005, 12:02 AM   #11
deutschmann59
Drives: 2006 325i
Hey don't forget the 330i has some kind of valve on the exhaust and the 325i doesn't. Not sure what it is or does, but I'm pretty sure it's for performance. (Sorry, don't know if you guys mentioned it yet...I'm not up on my car parts vocab.)
http://www.e90post.com/forums/showthread.php?t=1488
      09-05-2005, 08:54 AM   #12
ZenDriver
ZenDriver's Avatar
12
blueStreak- The BMW part numbers for a motor are absolutely identical. Therefor, the cams are the same on the 325/330. The intake is different, the exhaust is different and the software is different.
sharp1183- The exhaust valve exists to improve low end torque in BMW's stock exhaust system. Cutting it out of the 325 was a cost cutting measure. It does not produce too much of an effect as people who disabled the system on the E46 never felt much of a difference.
      09-05-2005, 09:10 AM   #13
RichReg
RichReg's Avatar
As per the chart above, the remainder of the exhaust parts (excluding the valve) are pretty much the same on both cars.
      09-05-2005, 09:14 AM   #14
RichReg
RichReg's Avatar
god BMW, jerks!
I should rephrase: Its not RATED for more than 215 hp. Whether or not the unit inside any one particular 325 will be able to withstand any upgrades over the long term is anybody's guess.
      09-05-2005, 03:46 PM   #15
mattldm
M40i Soon!
Drives: 2020 X3 M40i coming soon
So with these two engines being almost identical, does that mean that at some point BMW may drop the 325 and bring some form of a 335 to the US?
I have heard roumers of a 335 with close to 300 HP, but I have always dismissed them because BMW has never had more than 2 cars in each line up in the US. Maybe the will intruduce a more powerful 3 in a couple years. They are falling behind...
Acura TL - 270HP
Lexus IS - 306HP
MB C class - 268HP
255 seems to be to low these days. the line up would look great like this...
330i 255HP & 220 ft lbs
335i 295HP & 250 ft lbs
M3 410HP & 305 ft lbs
what do you think?
      09-05-2005, 04:31 PM   #16
stressdoc
Moderator
stressdoc's Avatar
Dominica
618
Drives: BMW i8; Toy 4runner TRD pro
I think it would look even better with the 320d, 330d, and 335d on the list as well.
      09-05-2005, 05:58 PM   #17
ZenDriver
ZenDriver's Avatar
12
525i
530i
550i
      09-05-2005, 07:37 PM   #18
marcus330i
marcus330i's Avatar
42
Drives: 2006 330i 6spd
3.0i
4.4i
4.8is
excluding the M3 has there ever been more than two 3 series engine variants in the US?
Realtor Mobile: 6spd / Sport / Prem / Navi / ED 3-30-06
73 3.0s/84 528e/90 525i/97 M3 4dr/99 M3 Conv/2001 330i/2004 545i ED/2006 330i ED June 05
You're in control...is there anywhere you want to go ? -------------------------
      09-05-2005, 08:11 PM   #19
mattldm
M40i Soon!
Oops, Guess I stuck my foot in my mouth with that coment! Duh!
I think what I was trying to say is that there has only been two 3 series cars for about 10 years. (Excluding M cars)
When was the last year they sold the 318 in US?
      09-05-2005, 10:36 PM   #20
Ed_330i
Ed_330i's Avatar
60
Drives: 2006 330i
i think there were 318 E46s.
      09-05-2005, 10:52 PM   #21
ZenDriver
ZenDriver's Avatar
12
The E46 was introduced as the 323i and 328i. These got bumped up in 2001 to the 325i and 330i. This is in the US of course, other markets get all sorts of wacky configurations.
      09-06-2005, 09:24 AM   #22
mattldm
M40i Soon!
I dont know, I was thinking the last 318 was an E36 in the US.
Reply
e90post
