E90Post
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > Trouble starting E92 335d today....
Reply
      12-26-2006, 12:20 PM   #1
335d coupe
Mike
335d coupe's Avatar
United Kingdom
Drives: Z4M Roadster
Angry Trouble starting E92 335d today....
Hi folks,
Went out to start my car just now and I slot the key in, foot on brake, car in park etc. etc. and thumb the button and.......... nothing (as in engine NOT turning over at all - and plenty of juice in battery...all lights working OK). Again. Nothing. Etc. Etc. Then on about the sixth try... thumb the button.....coupla seconds of nothing...then car starts. Hurray! But. WTF was up? Last time I drove the car was only a coupla days ago. When I sprayed the English Winter salty road grime off at the local car-wash. (I also ended up with a little mist/condensation in both headlights - won't go so close with the lance again...) Could it have been some damp that had got onto some electrics somewhere when I washed the car as abovementioned?? Anyone else out there had anything similar going on?
Mike F.
06/06 Z4M Roadster. Interlagos/Light Sepang/Ally Trim and plenty of toys.
      12-26-2006, 12:50 PM   #2
JaredM
Have you tried with the 2nd key?
      12-26-2006, 01:06 PM   #3
Z4 Beemer
Z4 Beemer's Avatar
Scotland
84
Drives: 2009 Z4 sDrive 23i
2006 E92  [0.00]
2004 Z4 2.2i  [8.00]
What you say is quite interesting. A while back I got a lift to work from the dealers (320d saloon) when the Z4 was in for some attention. Moving away from a set of traffic lights, slightly downhill, 2nd gear, the driver stalled it (made an excuse that with the diesels it wasn't easy to pull away in 2nd ) Anyway, hitting the start button a few times did nothing and there was no sign of life at all - the engine wouldn't even turn over. Eventually he took the key out, pushed it back in and it started right away. There was nothing lit on the dashboard to say what the problem was. I wondered if the key/start button setup could be problematic.
E89 Z4 sDrive 23i... for the more discerning driver
      12-26-2006, 01:29 PM   #4
JaredM
I reckon its an immobiliser fault/feature...
      12-27-2006, 01:10 PM   #5
RockIt
RockIt's Avatar
England
95
Drives: Mercedes C350 Coupe
Originally Posted by 335d coupe
Hi folks,
When I sprayed the English Winter salty road grime off at the local car-wash...I also ended up with a little mist/condensation in both headlights - won't go so close with the lance again...Mike F.
A bit off topic, but interesting that you should mention this as I'm getting condensation in the lenses without going anywhere near a car wash. My previous car also misted up but only on the rear lenses.
Hope the starting problem is just a glitch rather than a fault.
RockIt!
      12-27-2006, 05:09 PM   #6
ShereKhan
ShereKhan's Avatar
United Kingdom
97
Drives: BMW G20 330e M Sport MY20
2020 BMW 330e  [0.00]
BMW keys are rechargeable. When you slot the key into the receptacle it charges the key.
I think your key may not be fully charged - unusual for a new car.
If you take the car on a few long drives i'm sure it will be ok.
      12-28-2006, 07:58 AM   #7
335d coupe
Mike
335d coupe's Avatar
United Kingdom
Had the car back to the dealer for a diagnostic check. A fault showed with the brake pedal sensor. As such - on the occasions that the car wouldn't start - the car wouldn't start cos it thought I didn't have my foot on the brake pedal. The dealer got the car's computer to do a full reset of itself. As such, the dealer thinks that the car will likely now be OK. If, however, the problem re-emerges, then further intervention will be required.
Mike
      12-28-2006, 09:22 AM   #8
Real Thing
Real Thing's Avatar
24
Drives: Audi TT-RS Plus + MK6 Golf R
I had a similar experience and so has my friend (both got 335i se coupes) felt like there was something stuck under the brake pedal wouldn't press down so start button would operate just released and pressed the brake pedal a couple of times and hey presto started (only done it the once in 3 months) but sounds like it might be a fault.
      12-28-2006, 09:26 AM   #9
Z4 Beemer
Z4 Beemer's Avatar
Scotland
84
2006 E92  [0.00]
2004 Z4 2.2i  [8.00]
Surely the logic must be that if the brake is pressed far enough to light the brake lights, then the car should be happy to start?
Just a thought!
      12-28-2006, 10:52 AM   #10
Real Thing
Real Thing's Avatar
24
Just a thought!
When it did it on mine I must admit I didn't take that much notice but if I remember correctly it felt as if the Brake pedal was locked wouldn't go down more than about 1/4"
      12-30-2006, 07:41 PM   #11
gjdavies
Drives: E90 320d (in 3 months :-()
Didn't think they were on the newer systems?????
AFAIK the new systems don't have any metal-metal contact.
Please tell me if i'm wrong!!!
      12-31-2006, 04:10 AM   #12
Z4 Beemer
Z4 Beemer's Avatar
Scotland
84
2006 E92  [0.00]
2004 Z4 2.2i  [8.00]
I'm pretty sure the non-comfort-access keyfobs are rechargable, and yes there doesn't appear to be any metal-metal contact... but I don't think it needs metal contact to recharge?
I could also be completely wrong!
      12-31-2006, 04:37 AM   #13
vivekk
THE Viv
vivekk's Avatar
England
184
Drives: 330i SE
Indeed- the non-CA keyfobs make use of inductive charging when the keyfob is in the slot & the car is running.
The CA keyfobs have ordinary, non-rechargeable batteries in them- since they will hardly ever be placed into the keyslot anyway.
All the best.
Viv
[TiAg ▪ Dakota Black ▪ Active steering ▪ Sports suspension ▪ 162s ▪ Sports seats ▪ Al trim ▪ Bi-Xenons ▪ F&R PDC NavPro ▪ Voice control ▪ Bluetooth ▪ 6CD Logic7]
      12-31-2006, 05:56 AM   #14
gjdavies
All the best.
Viv
Thanks for the clarification!!!!
      01-07-2007, 11:08 AM   #15
Real Thing
Real Thing's Avatar
24
Mike
Just had the same problem (2nd time) Brake pedal wouldn't move auto gear selector also stuck in park, ignition on, But start button wouldn't turn it over rocked the brake pedal up and down (as much as I could a couple of times) and started first time will try to get it booked in to be looked at. Like you mike (335d coupe) I also had just had it washed Friday and 1st time (Sunday) since I've been in it (so wondered if it was water getting into the sensor or something)
Have you had any problems since going back to the dealers Mike?
      01-07-2007, 11:27 AM   #16
Z4 Beemer
Z4 Beemer's Avatar
Scotland
84
2006 E92  [0.00]
2004 Z4 2.2i  [8.00]
According to the book, the following symbol should appear if you don't have your foot on the brake when hitting the start button. Not actually tried it on mine to see if the symbol shows.
      01-07-2007, 12:37 PM   #17
Real Thing
Real Thing's Avatar
24
Didn't notice but may have missed it so if it does it again I'll look out for that symbol
      01-08-2007, 02:29 AM   #18
Jonn335
South Africa
Drives: F07 535 GT
335D coupe- maby the button on the remote was pressed in constantly by something causing the battery to discharge, this happened to me once with my TV remote, it had fairly new batteries in it, then i left it sitting with another remote on top of it, and the next day the batteries were flat, because one of the buttons was pushed in. Maby the same thing happened to you? if it happend again, try the other key.
535GT
      01-08-2007, 03:12 AM   #19
Z4 Beemer
Z4 Beemer's Avatar
Scotland
84
2006 E92  [0.00]
2004 Z4 2.2i  [8.00]
I'm sure another symbol comes up on the dash to show that the battery in the remote is a bit low on charge???
On second thoughts that just might be for remotes which are for comfort access...
      01-08-2007, 03:43 AM   #20
booforty
booforty's Avatar
United Kingdom
337
Drives: E92 M3
2008 E92 M3  [0.00]
Here is a list of warning lamps and their meanings not listed in the manual: http://www.e90post.com/forums/showth...=warning+lamps
Reply
e90post
