Low end?
08-11-2010, 12:52 PM | #1 |
Rep 128
Low end?
When people talk about "low-end" or "bottom end", for example refering to torque, what is it they are talking about? RPM? What RPM range is considered bottom end?
08-11-2010, 01:08 PM | #3 |
boosted x 2
Rep 108
I say anything under 4000-4500
2007 TIAG 335i || ZPP || CA || LOGIC 7 || JB4 || BMS DCI || VMR V710 || BMW PE EXHAUST || M-TECH CF SPOILER || BLACKLINES || MTEC V3 AE || |
08-11-2010, 03:49 PM | #4 |
Rep 1,644
Take redline and subtract your idle. Then divide that by three. Low-end is the bottom portion.
Former car
2011 BMW 335i Step - Montego Blue / Chestnut Brown |
08-11-2010, 03:52 PM | #5 |
Rep 10,309
Drives: A///MERICAN!!!
For 335 I'd say sub-4000, where you do most of your daily driving
08-11-2010, 04:24 PM | #7 |
Where'd my VTEC go?
481
Rep 6,067
I would consider low end under ~2500, midrange between ~2500 to 4500, and high end ~4500 to redline.
Pretty much just divide the tach in 3 and that would give a rough range for low, mid, high.
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear |
08-11-2010, 04:37 PM | #8 |
Mad Linux Guru On The Loose
1129
Rep 5,400
Drives: 2008 335i Sedan, 2023 M3
Low end: from idle to approx. 2500 rpms
Mid range: from 2500 rpms to 4500 rpms (usually cruising speed) Hi end: 4500 rpms to redline
