Strange comfort access problems.
08-13-2010, 01:35 PM | #1 |
Rep 361
I did a search before posting and really couldn't find anything quite like my problem, so here goes. The first problem was when my doors wouldn't open automatically on my '06 330xi about a month ago. Now it won't start unless my key is in the ignition. I get the key error when I step on the brake and push the button. However, if I start it with the key in the slot, then stop it, take the key out, and restart without it in the slot, it will start with no trouble.
As for the doors, I opened them manually with the key fob, locked them by touching the ridges on the handle, and was then able to open them with the fob in my pocket. So I guess it will work only after using the the buttons on the fob. Any ideas as to what the heck is going on? It worked perfectly since I bought it new. I only have one key fob that works, so using the spare is not possible. Thanks in advance for any suggestions. |
08-13-2010, 01:42 PM | #2 | |
Well officer, what had happened was...
104
Rep 1,161
Drives: Grocery Getter
Old: BSM '09 E90 335i. PROcede Tuned & Modded | AW '13 F30 335i M Sport | AW '16 F36 428i xDrive M Sport Gran Coupe | AG '19 G05 x5 Individual
Current: IOMG '22 G80 M3C w/ go fast parts |
08-13-2010, 01:49 PM | #4 |
Rep 175
http://www.e90post.com/forums/showthread.php?t=412598
Try this thread they have been having similar problems. If the car is awake everything works if the car is asleep you have to hit the key fob to wake it up and then everything id OK again. I believe the batteries were checked? |
08-13-2010, 07:45 PM | #5 |
Rep 361
You guys hit the nail on the head. I really didn't think the battery was shot because the doors were opening easily from a distance with the fob buttons, and locking too. I thought it has something to do with a sensor, especially since the CA would work sporadically. I just replaced the battery (by sheer luck I had the exact battery as a spare for our electronic bathroom scale. Go figure) and it's working like a champ, CA and all.
THANKS A TON! |
08-13-2010, 08:10 PM | #6 | |
Rep 1,938
