3 months low on oil and service reader problem
01-05-2007, 08:38 PM | #1 |
Rep 41
ive only had my 335i for 3 months and its already low on oil... could this be an oil reading problem?
and also my service mileage is still at 15000.... weird |
01-05-2007, 10:02 PM | #3 |
Rep 2,168
My 325i used all of it's oil in 6 months. It turned out to be a slow leaking sump plug, discovered after I had it serviced and oil changed, after which oil started pouring out onto the garage floor the day I got it back.
Before I had the oil changed, the service indicator still had 1000's of kms left on it, but it was complaining that it needed 1 litre of oil. I noticed that the oil consumption was up, but then in a space of 2 weeks it went from 3 blocks of oil left to none on the display. If your car's behaviour is similar, I would get it checked out pronto. Since the sump plug was fixed, no oil use what so ever.
'05 E90 325i | '06 E90 325i | '08 E90 325i LCI | '13 F30 328i M-Sport | '14 F10 535d M-Sport
Current: '19 G01 X3 M40i |
01-06-2007, 05:45 AM | #5 | |
Rep 724
My graft was down half way from the max line. Took to dealer @ 3400 miles for first oil change. After change it's little over half mark not @ max line. Dealer says it's normal & not to be concern. Claims when it's down half way it's less than 1/2 qt.? I told him when I had my 06 330i @ 5000 miles was still @ max line. Dealer claims the turbo uses little more oil & no need for any concern? |
01-06-2007, 11:03 AM | #7 |
Rep 3,469
How coincidental, last night as I was coming home I got the low oil warning and the meter showed it on minimum. Ive had the car about 3 months and 6600 miles. Is there a dip stick to check the oil level visually in this car?
2016 Alpine White M3 (gone)
2019 Alfa Romeo Guilia (Totaled) 2020 Car-less 😁 (no more) 2020 M340 |
01-06-2007, 12:33 PM | #8 |
BMWCCA 149159
38
Rep 847
Turbo's use more oil? BS! My Ford Super Duty has 150,000 miles on a turbo the size of a basketball and my truck never uses any oil including the turbo. If it is using oil it is blowing it past the turbo seals and that is not a good thing.
Most manufactures will tell you that 1 qt every 1500 miles is normal. I think it is more of an indication of the bear in process and will taper off. LS-1 engines burn oil based on the type of oil used. My uncles 300hp Caddie has burned oil from day one and it is within GM specs. |
