Help Bms Powerbox Owners
09-14-2010, 07:03 PM | #1 |
Rep 3,900
I have the BMS and its ready to be installed. I searched but couldn't find anything on how to switch the maps? How do I know which map im on? Can someone clarify this for me?
09-14-2010, 07:13 PM | #2 |
Rep 392
Drives: 2017 Tacoma TRD Pro
BMS Power Box Map Guide
Map 0 - Disables BMS Power Box (Stock) Map 1 - 30% throttle remapping, performance tuning on Map 2 - 60% throttle remapping, performance tuning on Map 3 - 100% throttle remapping, performance tuning on Map 4 - 30% throttle remapping, performance tuning off Map 5 - 60% throttle remapping, performance tuning off Map 6 - 100% throttle remapping, performance tuning off Map 7 - throttle remapping disabled, performance tuning on BMS Power Box How to Switch Maps from the Driver's Seat Insert the keyfob and press the start button to turn the ignition on (lights on the dash but the engine is not running). Press and hold the gas pedal down to the floor for 4 seconds or more, then release. This puts the Power Box into listen mode. If you start the engine at this point you will be on map 0. For performance maps press the gas pedal to the floor and quickly release one time for each map you would like to select. For example, for map 3 press and release the gas 3 times, then start the engine. Your map setting will be saved until it is changed. |
09-14-2010, 08:35 PM | #4 | |
Joint Chiefs of Staff
4924
Rep 116,006
Mike |
09-15-2010, 01:26 AM | #6 |
Rep 3,900
Honestly when i came home my sister ripped the box open thew it out and said some wire thing came and i threw the box out and assuming it was everything in it. Just took out the plastic inside. Oh well but I guess I just have to do some runs and see which maps I like.
09-18-2010, 04:48 PM | #7 |
Rep 3,566
Drives: F30 M-Sport 328i Estoril Blue
Map 3 for me all the way!!!!
328i M-Sport, Estoril Blue, Carbon XP 35 Tint, front heated seats, black Dakota, Sports Suspension, Anthracite Headliner, HUD, Pro Nav, Sunroof, hk 600w, Bi-Xenon, 19" 403M wheels, Reversing Camera, DAB+, Xenon, BT Ext Connect, MST turbo intake pipe, MST Cold Air Intake, JB4 on Map 2 with Catless DP produces awesome performance in Sport.
