2010 2011 BMW 5 Series Forum F10 BMW 5-Series Gran Turismo GT (F07) Forums General 5-Series GT (Gran Turismo) (F07) Forum 550i GT winter tires and rims
      09-22-2010, 08:12 PM   #1
ld757
Drives: 2018 BMW 750xi
Gents,
Just bought 2010 550i GT with sport package (20" rims) and have a question about winter tires and rims.
Can I go with 18" rims or because of the large calipers I should get 19".
Which tires would be the best?
Bridgestone or Pirrelis?
Thank in advance for your replies.
      09-22-2010, 08:30 PM   #2
jadnashuanh
Drives: 535iGT x-drive; i3 BEV
Usually, but I don't know on that vehicle, you can put any standard wheel on the car. So, if it can come with 18", an 18" would fit. It should say in the user's manual.
On the 18", Michelin just came out with the PA3 snow in run-flat. The first run was small, so there may not be too many around. Call your supplier if you want to check that out. the roads are often crappy in the winter, and the higher profile 18" tires will have a better chance of surviving the winter than 20" tires and wheels.
      09-24-2010, 07:44 AM   #3
ClausCoupe
Norway
27
Drives: Soon: 640xi Gran Coupe
Go with 18"! The more rubber you have, the better grip.
I recommend Haakapeliita R. But not sure if you can buy them in the states.
      09-24-2010, 11:12 AM   #4
juztinl
Hong Kong
26
Drives: 535i
you want narrow tires on snow.
      09-24-2010, 02:20 PM   #5
ClausCoupe
Norway
27
I meant "more rubber" as in height.
But of course the narrower the better too...
      09-24-2010, 05:19 PM   #6
jadnashuanh
Nokian also has the WRG2 in run-flat for the 18" tires that is rated as a snow-tire.
5post
