E90Post
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > Cracked Crankcase
Reply
      10-26-2010, 11:17 PM   #1
Go123
Go123's Avatar
Drives: 14 F30
Cracked Crankcase
I brought my e90 330i in for service this week, for an exhaust smell which seemed like burning oil. On evaluation they found a cracked crank case, and incidentally said I need new front control arm bushings. Good thing the case is covered by warranty, anybody know how this may have happened. Mileage is 95k miles.
      10-27-2010, 01:06 PM   #2
IancoleTX
Dillo boxers
IancoleTX's Avatar
Drives: 2019 M5C
Sounds like you ran over a large rock or perhaps a small boulder. Better thank your lucky star$ you're in warranty.
2019 M5C Matte MBB / Tartufo
      10-27-2010, 04:24 PM   #3
e90pilot
Freight Dawg
e90pilot's Avatar
Drives: E90 325i
Well, oil pan isn't that bad. You just need to drop the front subframe which takes a while but the oil pan part is easy.
--Marcelo
'06 Arctic Metallic 325i | Sport Package | 6MT | Dinan Stage III suspension | Dinan exhaust | 330i manifold swap! Click here! | Active Autowerke tune | 135i Brake Calipers | Deiselboost caliper brackets | E46 M3 front rotors
      10-30-2010, 12:24 PM   #4
Go123
Go123's Avatar
Drives: 14 F30
Car is back, the crack was in the crank case valve, they replaced this and the hose, so not a crack in the actual crank case.
      10-30-2010, 06:26 PM   #5
e90pilot
Freight Dawg
e90pilot's Avatar
Drives: E90 325i
That's good. Those hoses get old and dry out. They're really easy to break when they're like that.
--Marcelo
Reply
e90post
