E90Post
Studio RSR
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > strange stop/start button issue
Reply
      11-03-2010, 08:19 PM   #1
fourfourtwo
Soccer Guy
Drives: space gray 2010 328i
Hi all - just started experiencing an issue with the stop/start button on my 2010 328i. Used to be able to get in the car, press the brake, put the fob in the dash and then press the button and it would start. Now, for some reason, I do all that but no start...I remove the fob and try again...and then it starts.
Is there a "time limit" when the fob is in the car bit no start attempt is made...seems as if the sequence of the start procedure has been disrupted...or else I'm doing something new that has caused the problem.....all a bit confusing.
Any thoughts?
THanks,
442
      11-03-2010, 08:27 PM   #2
Chriztofor
Chriztofor's Avatar
Drives: '06 325i and '13 X5
Column lock might be failing...do a
Wait a minute...2010? Take it to the dealer and have them look at it.
      11-03-2010, 08:40 PM   #3
papiti
papiti's Avatar
Puerto Rico
17
Drives: 2011 E92 335i Coupe M-Tech
Probably a battery issue. Check the battery in the FOB.
      11-03-2010, 10:21 PM   #4
chromisdesigns
Drives: 2008 BMW 335i sedan
Is your brake pedal very stiff when this happens? There have been reports of the brake booster leaking so badly that it became difficult to get the pedal to depress enough to defeat the anti-start switch.
      11-04-2010, 06:25 PM   #5
fourfourtwo
Soccer Guy
Yes - it's the weirdest thing - when the fob is in, the brake pedal is sometimes really stiff and after I remove it and try again, the brake releases and the car starts...I've also been able to start the car when the brake pedal is really stiff...totally confused...running into problem with both fobs...doubt it is battery issues....very frustrating...!
      11-04-2010, 07:07 PM   #6
J02 335i
J02 335i's Avatar
Drives: F80 M3
He can't check the battery.
Sport pack, JB3, Dci, factory oil cooler, 18" M3 reps, Michelin PSS, painted trim, black grills, smoked side markers, LED plate lights, H&R coils, Borla catback
      11-04-2010, 07:37 PM   #7
chromisdesigns
Have the check the brake booster. Dollars to donuts it's leaking. Very common problem in E9X, though not always to the point of interfering with the starter.
      11-12-2010, 09:13 PM   #8
fourfourtwo
Soccer Guy
strange stop/start button issue - brake booster issue
Hey guys - looks like it was the brake booster - has been at the dealer all week so hopefully will be returned to me on Monday. Someone said there was a TSB on this issue - anyone got that link or reference?
Thanks all,
442
      12-01-2010, 05:43 AM   #9
ThreeseriesFTW
ThreeseriesFTW's Avatar
15
Drives: 335
Subscribing to this thread....same thing happened to me this morning.
I put the key in, pressed started...the engine turned over once then said "F this, I'm not doing it" and shut off.
After that, the car would light up like it wanted to turn on, then just shut off without bothering the engine. I tried that 4 or 5 times, then sat there for a minute wondering what to do.
I then tried it again and it came on. Still sounds like brake booster?
Reply
e90post
