2007 335i wet carpet
11-05-2010, 04:26 PM | #1 |
Rep 77
Hey fellas help me out. I was cleaning my car today and noticed my carpet was wet only on the drivers side and only underneath the break pedal and accelerator pedal. It is NOt coolant just plain water. I basically took all the carpet out and can not find where it is coming in from. HELP
11-05-2010, 04:29 PM | #2 |
Mr. Nice Says Hello
637
Rep 16,662
Drives: BMW M3 | X5 xdrive 35i MSport
has it been raining near you?
11-05-2010, 04:30 PM | #3 |
Clutch pedal >> Dead pedal
18
Rep 709
Drives: '11 e92 335is 6MT
Could be a plugged sunroof drain hose.
In my garage: '11 e92 335is 6MT (05/10) SpGrey/CoralRed/GlacSlvr ExecPkg/NavPkg/19" 225M
Retired: '07 e92 335i 6MT (12/06) SpklgGrpht/CoralRed/GreyPoplar Retired: '04 330Ci M-Sport 6MT SilverGrey/NaturalTan/MyrtleWood Retired: '00 328Ci 5MT SteelGrey/Grey/MyrtleWood Retired: '87 Pontiac Grand-Am 3AT White/Grey |
11-05-2010, 04:39 PM | #4 |
Mr. Nice Says Hello
637
Rep 16,662
there isnt much water in there i dont think
11-05-2010, 05:10 PM | #6 | |
Rep 77
Well I found the drains for the sun roof and poured water in them and the water hit the ground so I'm assuming that isnt it. Why would the vapor barrier allow water in one concentrated area? I mean it only wet near both pedals and no where else. I really like this car but some of the BS issues I have had are starting to sway me to get rid of it. New trans, brakes, wheel bearing, cup holders, sun-roof replaced, of course fuel pump, and no there is a clicking noise from the rear front wheel when I hot the brakes...I'm sure it is another brake issue...UGH |
11-05-2010, 05:17 PM | #7 |
Rep 967
Mine would flood the interior whenever I would have the a/c on. Dealer first said it was an "acceptable amount of water".....
I later pulled up the carpet and found water 3 inches deep in the front footwells. They replaced some tube behind that was apparently on a service bulletin and the problem hasn't happened since.
| PROcede Rev3 | Vishnu Meth | DCI | BMW Perf. Exhaust | AR Coated/Catless | CP-E FMIC | Quaife | |
11-05-2010, 06:45 PM | #8 | |
Rep 7,089
Drives: '06 AW 330xi
I don't know if the driver's side was documented. |
