Has this happened to anyone?
11-08-2010, 01:22 PM | #1 |
Rep 221
I stopped to pump some gas this morning. I turned the car off but didn't remove the key as I usually lower the rear pass. window so I can listen to my music while I stand by the pump. Anywho, I finished pumping, got back in the car, depressed the break and hit the Engine Start/Stop button. That's when it happened: everything turned off! Everything. The radio went off, the interior lights, the display, everything! I kept pressing the brake and start button and nothing happened. I even pressed the radio power button and it didn't turn on.
I removed the key, re-inserted it, and it started up normally. WTF? Electrical gremlins? |
11-08-2010, 01:54 PM | #4 |
Rep 221
11-08-2010, 01:59 PM | #5 |
Rep 2,900
It seems like the normal process of things in a way.
Car is running Push Start/Stop button turns off car, electronics still on Press again, turns everything off Seems normal to me. |
11-08-2010, 02:08 PM | #6 |
Rep 8,693
Drives: 06 330i
11-08-2010, 02:25 PM | #7 | |
Rep 221
Push Start/Stop button turns off car, electronics still on depress brake, press start/stop, car should start (not turn everything off). I suggest you go to your car and try it. Also, if it were normal operation, the radio would've turned on when I pressed the radio power button, but it didn't. |
11-08-2010, 02:31 PM | #8 | |
Rep 8,693
Drives: 06 330i
false. it will power everything off. |
11-08-2010, 02:57 PM | #9 |
Rep 221
Really? I just went out to my car and tried it.
I turned the car on, then turned it off, and left the radio on. Opened the door, closed it, then opened it, closed it, depressed the brake, hit the start button and the car started up. Same sequence as before, only this time it started instead of turning everything off. I suggest you go try it before posting. |
11-08-2010, 10:58 PM | #11 |
Rep 6,604
Drives: e92 335i
normal, mine does that when i sit in the car while listening to the radio with the engine off
11-08-2010, 11:52 PM | #12 |
Rep 282
hmm... is it becuz of the model year of the car... mine is 2009 e90 and i got the same results as couch:
Car is running Push Start/Stop button turns off car, electronics still on Press again, turns everything off |
11-09-2010, 06:57 AM | #14 | |
Rep 221
If you don't press the brake then it will turn everything off (that's normal). What's not normal is when you press the brake, everything goes off, and you can't even turn the radio on by pressing the radio power button. |
11-09-2010, 08:18 AM | #15 |
Rep 251
Drives: 2007 e90 335i 6MT (ZSP)
I read something that you just hold start button down a couple seconds to start the car without it turning off the electronics.
11-09-2010, 08:23 AM | #16 | |
Rep 8,693
Drives: 06 330i
i suggest YOU go try before you post. |
11-09-2010, 10:09 AM | #17 | |
Rep 221
I'm writing it off as a fluke. |
11-09-2010, 12:11 PM | #18 |
Rep 3,342
Drives: 2022 M3, 2022 X5 40i;
If the car loses its power in that timeframe where there is limited power to your electronics, you will have to remove the key and reinsert it to turn things back on.
What you describe is normal - so you may have pumped more gas than usual/taken longer, or for some reason had a low power situation. If the power does NOT shut off, then you should be able to start up just by touching the brake & pressing start. To reproduce the problem - Start car. Shut off car, leave fob in place. Wait until your electronics/iDrive shut off. Try to start the car - it shouldn't. Start car by removing and replacing the key. |
11-09-2010, 12:46 PM | #19 |
Rep 2,900
11-09-2010, 01:57 PM | #20 |
Driver
37
Rep 1,577
I read the original post.. and what happened makes sense.
When the car is on and you press start/stop once, the car goes off but electronics stay on if they key is inserted in the ignition slot. If you open the door, the very next time you press start/stop regardless if you press the brake or not, should power off all the electronics not start the car. Then you will have to remove, and re-insert the key. If you do not open the door, the car should start up if you pressed start/stop. I'm not saying this is the truth, this is just my experience with the start/stop feature. |
09-25-2011, 11:56 AM | #21 |
Registered Offender
Rep 39
Sorry to resurrect this old post, but my '09 335ix E92 Steptronic CA managed to surprise me this weekend:
I moved the car out of the garage, shut it off in park with the pushbutton (keyfob in my pocket), foot off the brake pedal to make it so that just the electronics were powered up to run the radio without it 'timing out'. I sat there for 5~10 minutes with only the 'middle' instrument-cluster lights showing, and when my spousal unit came out and sat down in the car (via opening and closing the RH door) I put my foot on the brake and pushed the 'start' button. The starter began turning the engine over furiously, the 'service engine soon!' warning came up on the cluster, and the engine failed to start. I pushed the start button again, the starter stopped, and with my hoof still on the brake pushed the button again--and, again get just the starter cranking away madly and no start with the check-engine warning. So-I took my foot off the pedal, pushed the button again to stop the starter, pushed it again to power off everything, then put my foot on brake again and pushed the button--VOILA! Engine starts fine, check-engine light goes out, all's well. I tried it again immediately--all's fine, and it has been since. I believe that my car is entirely too smart for my own good, and I'm not nearly as smart as IT is as it wants to make SURE that I fully intend to start the engine after listening to the radio for awhile and that I am not just messing aorund with it. |
09-25-2011, 11:59 AM | #22 |
Rep 8,693
Drives: 06 330i
you have hooves?
