Door lock broke twice...
11-10-2010, 09:22 AM | #1 |
Rep 25
2 months ago, my 06 325xi sedan's passenger door lock broke - it locks but won't unlock using the fob or the central locking system. I replaced the actuator and that fixed the problem. Now it's broken again, with the same problem as before.
Is this just bad luck, or is something else causing the actuators to prematurely fail? I don't want to replace it only to have it break on me again. |
11-10-2010, 09:24 AM | #2 |
Rep 8,693
Drives: 06 330i
did you recently replace your battery
11-10-2010, 09:27 AM | #4 |
Rep 8,693
Drives: 06 330i
sounds like a voltage issue or just bad luck i guess
11-10-2010, 09:46 AM | #5 |
Rep 17
could also be a fuse issue..this happened to me last year. the dealer replaced two actuators and changed the fuse from a 15A to 20A..knock on wood, no problems since. from my readings, this is fairly common on our cars, i have an 06 E90.
