Battery question!
11-13-2010, 05:22 PM | #1 |
Rep 1,943
Battery question!
Hello. I need to change my battery, dealer said is not something I can do my self because it needsto be register to the car and that when the old battery is removed a bunch of sensor will reset so it gas to be done by a pro. They want 250 for oem one plus 1h labor which is 150 plus taxes. That sounds like a lot to me and don't know if they r BSing me.
I call a local shop which is where a get most of my staff done and they said to go after market because the warranty on the battery is 2 years comparing to the 12 month of the OEM. The they charge me 1h labor which is 90$ plus taxes. Then I call my friends mechanic and he also said go aftermarket battery cus is cheaper and better warranty but he's only changing me 15$ because he said is only a 10-15 min thing. So I don't know who to believe now.
PROCEDE, PWM Vishnu Kit, AR catless DP, BMS DCI, Helix IC, P3 gauge, 25% window tint, mattblack window trim, mattblack roof wrapped. Vorstainer CSL trunk, CF wrapped interior, 18'' Forgestar F14 Matt black, quaife LSD, M3 suspension bits, Mtech front bumper). http://www.youtube.com/watch?v=b8JIB8C8HDA
11-13-2010, 05:35 PM | #2 |
Rep 623
Here you go. Hope its help.
http://www.e90post.com/forums/showth...=445615&page=4 |
11-13-2010, 06:53 PM | #3 |
Rep 1,165
Oh God this topic is like Which is better, manual or auto? There has been numerous discussions about this. As for me, I replaced mine with a Walmart battery and 1/2 hour work. Works perfectly, no warnings no issues. I have been to the dealer since installing this battery and no codes were ever found. Dealer quoted me 450. Don't waste your hard earn doe.
2020 X3 X-Drive 30i; Alpine White/Mocha
11-13-2010, 07:30 PM | #4 |
this is the way
18429
Rep 8,582
11-13-2010, 07:38 PM | #5 |
Zoom Zoom This
12
Rep 694
You can Wallmart the Battery but do yourself a favor and buy a BT cable.
You use that to register the new battery. The system uses different charge rates based on the age of the battery. Thats why they tell the system it is a new one. as for the sensors going off: That is complete horseshit. I take my battery cable off all the time to do wiring things and add/remove tune for service etc... never a battery code thrown yet. I'm still at a loss why the system really needs to know about the battery age. I would think it could tell from the charge rate vs current voltage and temp to simply figure out how to charge it. |
11-14-2010, 12:59 AM | #6 |
Rep 680
Changing out the battery is easy. But when the power goed down, even for a second or two, all of the presets will erase - radio, seats, mirrors, even the ECU.
You can buy a tool to temporarily keep the power to the computer for $15-20. Any mechanic has a professioal version ($100+). If you pay a shop to do the change it is thier responsibility to fix anything that resets because the power is lost. But it is a job any compentent mechanic can do in 20 minutes or less. |
11-14-2010, 08:59 AM | #7 | |
Rep 69
It seems the BT cable services up to 2009 BMW models. I guess there is a few years lag in updating. |
