(red) car on lift service light?
11-15-2010, 08:48 PM | #1 |
Rep 367
whats up guys, i turned my 335i on today and found nice red exclamation mark on my dash. I scrolled through the menus and saw a symbol of my car on a lift that was illuminated red. Prior to this I had gotten several o2 sensor codes which caused a (service engine soon) light. as well as some "short circuit codes"
E18C: Device didn't accept or confirm monitoring message (Error_Monitoring) Error will not cause a warning light Error is not currently present Test conditions have been completed MSD80/MSD81 Engine module for N54 Current Fault Codes 2C2E: 2C2E Lambda probe in front of catalytic converter 2, thrust control Error will cause a warning light Error is not currently present Test conditions have been completed Short circuit or signal interruption 2C3E: 2C3E Lambda probe in front of catalytic converter 2, control failure or cable transmission failure? Error will cause a warning light Error is not currently present Test conditions have been completed Timeout Freeze Frame Information Odometer 42200kms 26221miles suction pipe pressure 25.00 kPa voltage Lambda probe in front of catalytic converter bank 2 2.77 V symptom bei Schubabschaltung Sonde in front of catalytic converter bank 2 1.00 0-n ceramic temperature Lambda probe in front of catalytic converter bank 2 0.00 °C 29D2: 29D2 Misfirings, cylinder 6 Error will cause a warning light Error is not currently present Test conditions have been completed Short circuit or signal interruption 2FCA: Error will not cause a warning light Error is not currently present Test conditions have been completed Short circuit or signal interruption 2FDA: Error will not cause a warning light Error is not currently present Test conditions have been completed Short circuit or signal interruption 2FDB: Error will not cause a warning light Error is not currently present Test conditions have been completed Short circuit or signal interruption 29D2: 29D2 Misfirings, cylinder 6 Error will cause a warning light Error is not currently present Test conditions have been completed Short circuit or signal interruption Now the manual says: Starter failed or ignition malfunctioning or lighting system failed. None of these things seem to be the problem. Im thinking maybe i did something wring the last time i installed the procede. Do you guys have any idea what these "short circuit or signal interruption" codes are for? |
11-16-2010, 12:10 AM | #2 |
Rep 2,554
well i don't know anything about all those codes.. but i think that means its time for the scheduled check up.. (maintenance) I'm just going by the pics i saw on my idrive
edit: its red, so i guess its not maintenance, sorry bout that Last edited by username604; 11-16-2010 at 12:11 AM.. Reason: re-read OP's post |
