11-16-2010, 09:04 PM | #2 |
Rep 183
fatty
2008 Jet Black/ Black Dakota/ Aluminum E92 335xi
OEM Front Lip | Seibon CF Trunk | CF Kidney Grills | Painted Reflectors | GP Thunder Angels | ACS Roof Spoiler | Rear Fogs |
11-16-2010, 09:30 PM | #3 |
Rep 10,309
Drives: A///MERICAN!!!
Extreme strength rolaids...when I had this I would chew like 5 and be good
11-16-2010, 09:55 PM | #5 |
Rep 1,247
Drives: E60 M5, E71 X6M, E46 M3
Garage List 2006 BMW E46 M3 'vert [0.00]
2008 BMW M5 [0.00] 2011 BMW E92 [0.00] 2012 BMW X6M [0.00] 2003 E46 M3 [0.00] |
get the store brand famotidine....20 mg twice daily as needed
Current: 2006 E46 M3 'vert 6-sp 2008 E60 M5, 2011 E92 328 6-sp, 2011 E70 N55, 2012 E71 X6M
11-16-2010, 10:16 PM | #6 |
Rep 1,838
"Place 1/2 teaspoon of baking soda in 1/2 glass water. Check the antacid use information on the box before using this remedy, however. Warning! If you're on a salt-restricted diet, do not use baking soda. It's loaded with sodium. And do not use it if you're experiencing nausea, stomachache, gas, cramps, or stomach distention from overeating.
You can also mix 1/2 teaspoon of cream of tartar with 1/2 teaspoon baking soda in a glass of water. Take 1 teaspoon of the solution as needed. At the first sign of heartburn, try mixing 1 tablespoon apple cider vinegar, 1 tablespoon honey, and 1 cup warm water."
11-17-2010, 12:49 PM | #10 |
Rep 1,352
Be careful with antacids. They can exacerbate the underlying problem of LOW stomach acid (hypochlorhydria). The stomach must be acidic to set up the rest of the GI tract to digest/assimilate/eliminate properly. H.pylori infection and diet/lifestyle/stress are usual factors in the problem.
11-17-2010, 08:17 PM | #12 | |
Rep 1,414
So I just wanna get rid of the symptoms for now... |
11-17-2010, 08:57 PM | #13 |
COBB'ed
65
Rep 2,228
Prilosec OTC or Prevacid24HR should work well. Also I would recommend you go and see your doctor asap. Learn from my mistake, take heartburn seriously. I didn't and ended up in a hospital with a bleeding ulcer. Make sure your doctor tests you for the H.pylori bacteria. Good luck
13 Mini Cooper S 08 E92 335i (SOLD) |
11-17-2010, 10:16 PM | #14 | |
Rep 1,432
There's two types of antacids: H2-receptor antagonists and PPIs. H2-receptor antagonists (like Zantac) are available OTC and are generally less effective. PPIs (proton pump inhibitors) are more effective but require a prescription. The most common one is Omeprazole. You also need to be careful, because PPIs in particular can interact with other drugs you are taking and lead to toxicity. You might laugh, but even something as simple as tylenol can lead to as far-ranging consequences as ineffectiveness of the drug to acute liver toxicity. |
11-17-2010, 11:35 PM | #15 |
Rep 247
prilosec and prevacid both have OTC preperations.
both have side effects, prolong heartburn can lead to cancer. so dont take it lightly. NO medications will work unless you fix your diet. you have to ID the foods that make you get reflux. stuff with caffeine, spicy foods, sour foods. |
