Warning messenges covered under warranty?
12-30-2010, 09:15 PM | #1 |
Rep 147
is this covered under bmw warranty? also i hit a pot hole... and this went off.. so i'm guessing it triggered a malfunction somehow... ...
---------------------------------------------------------------------------------------------- 2007 BMW 328i Coupe|Sapphire Black|Gray Poplar Wood Trim|Premium Package|Sports Package|Navigation iDrive|Park Distance|Aero Body Kit|Logic 7 Last edited by evicfinite; 12-30-2010 at 10:20 PM.. |
12-30-2010, 09:52 PM | #2 |
Rep 147
also is their any safety concerns i should be aware of?
---------------------------------------------------------------------------------------------- 2007 BMW 328i Coupe|Sapphire Black|Gray Poplar Wood Trim|Premium Package|Sports Package|Navigation iDrive|Park Distance|Aero Body Kit|Logic 7 |
12-30-2010, 09:58 PM | #3 |
Rep 8,003
Drives: '08 E90 335i, '99 E36 M3
Hitting a pot hole and expecting BMW to fix the damage is not going to fly.
12-30-2010, 10:01 PM | #4 |
Rep 147
yea but for a system to break this easily is kind of weak....
12-30-2010, 10:06 PM | #5 |
NHTSA Nazi
28
Rep 1,983
You must have really whacked that pothole. The damage won't be covered by BMW but you can file a claim with the municipality where the pothole is located or with you insurance company.
12-30-2010, 10:09 PM | #6 |
Rep 2,783
Take it to the dealer and play dumb (I was riding along and while I was stopped at a light these warning messages popped up....). Just make sure you put in writing on their check-in sheet to only perform warranty work.
12-30-2010, 10:19 PM | #7 |
Rep 147
thats what i was going to do... cause nothing is wrong with the car... i'm guessing it might have just loosened something up...
12-30-2010, 10:23 PM | #8 |
NHTSA Nazi
28
Rep 1,983
12-30-2010, 10:28 PM | #9 |
Rep 660
Is your steering wheel off center while driving straight. That is the most likely cause of the warnings. I'm almost 100% positive you knocked your alignment off when you hit the pothole. An alignment and recalibrating your steering angle sensor should fix it as long as you did'nt bend any suspension components. I also love the advice on here to scam the dealer and play dumb, and people wonder why society is falling apart, there are no ethics or morals anymore.
12-30-2010, 10:29 PM | #10 |
Rep 660
ABS wheel speed sensors have nothing to do with headlight leveling or the adaptive feature. Leveling is controlled by front and rear suspension ride height sensors and adaptive lights are controlled by the steering angle sensor connected to the steering column near the steering wheel.
12-30-2010, 10:35 PM | #11 | |
NHTSA Nazi
28
Rep 1,983
However, severe pothole hits often damage the headlighting system as well and the affected HID lighting unit will go into "safe mode" and point downwards. The malfunctions noted on the nav screen may well be connected to a damaged sensor. One pothole can cause two separate problems. I should have explained my questions better. |
12-30-2010, 10:36 PM | #12 |
Rep 147
yea my headlights are perfectly fine... they move around when i turn still and seem leveled...
i haven't notice any alignment off centering... other then since i changed the tires 4 months ago the alignment was slightly off, but still straight in my book, but that didn't throw any codes.... also the warnings codes didnt go off till today... and that happened yesterday... weird....
12-30-2010, 10:37 PM | #13 | |
Rep 660
12-30-2010, 11:12 PM | #14 |
Rep 433
Definitely the steering angle sensor. Mine went out last year and the idrive displayed the exact same warnings. It's an easy fix at the dealer that will be covered under warranty.
f30 335i: Current
e92 335i: Sold 10/29/2015 e90 328i: Sold 12/7/2013 |
12-30-2010, 11:26 PM | #15 |
Rep 533
+1
Old head
12-30-2010, 11:32 PM | #16 | |
Rep 2,783
Yeah, poor poor dealerships. OP: tell the truth that you hit a pothole and it's your fault and you will pay for it. We wouldn't want the dealership/BMW to go bankrupt. lol
12-30-2010, 11:41 PM | #17 |
Rep 147
lol u guys are very knowledgeable...
i probably wont play dumb... but i'll just book an appointment and if they find anything wrong that i was at fault then i'll say what happened... and if they dont find anything wrong and fix the problem under the warranty.... then all the better...
12-31-2010, 07:55 AM | #18 | |
Rep 14,829
As far as society falling apart, I attribute that to everything being dumbed down. Like when the auto insurance agent, mortgage officer, financial advisers of the world can't even answer ordinary day-to-day questions, yet they are licensed and have 4+ year degrees. It's as if life is one big bluff.... |
