Going to the dealer for service (question)
01-12-2011, 08:59 PM | #1 |
AC Milan Rossenari
16
Rep 158
Hi. I have been a proud owner of a 2007 e90 328i since June 10'.
I am going to my dealer tomorrow to get the micro-filter replaced (my Nav told me that it needs replacing), plus, it looks like I need to do the state inspection test, which I think the dealer will do for me? My main question is: Is there anything else I SHOULD ask the dealer to do to my car? My warranty is going to run out on the 23rd of this month, so I would like whatever I can from them while it is still free and capable. I don't plan on extending the warranty because the 328i is pretty reliable. The brake pads arent due for another 3800miles, so a replacement would be out of the question. Are there any little "perks" I can tell them to do? When I accelerate, I do experience some lag between acceleration sometimes and sometimes I get this "clunky" shift feeling when the car is going through rpms. For example, going from 3000 to 2000rpms or 1000 to 2000rpms, etc. Thank you and I look forward to being a member of this great community of e90 owners |
01-12-2011, 09:04 PM | #2 |
NHTSA Nazi
28
Rep 1,983
You are asking a bit late but you should find an independent tech to give your car a close once-over to check for problems. expect to pay about an hour worth of labor for this but it could save you thousands.
01-12-2011, 10:46 PM | #3 |
AC Milan Rossenari
16
Rep 158
Thanks Ceb. However, when I bought the car from an independent dealer (lot), it was located right next to the actual BMW dealership. So, the owner of the dealership where I bought my car went to BMW to get a diagnostic check-up.
The only thing that BMW said was that it needed a brake flush and new brakes. So, the owner of the lot did all that. He showed me the report of it too for proof. So, I was wondering if there are some certain "hidden" things or something nice that I should have the BMW service department do when I take my car in tomorrow. Appointment is at 5:45pm Pacific time. So, any further help would be appreciative guys! EDIT: They could be novice things as well like "getting tires aligned", fixing some mirror, etc, etc. Even if it is VERY SMALL of a change, I would welcome the opinion/thought. Thank you. |
01-12-2011, 10:50 PM | #4 |
¡Viva España!
376
Rep 7,803
I always have them change out the wiper blades when I go in.
23 G42 230i Mineral White Cognac, Aluminum With Mesh Effect Interior Trim MODS Clear Guard, 15% Ceramic Tint, Floating Caps
01-12-2011, 11:02 PM | #5 |
AC Milan Rossenari
16
Rep 158
01-13-2011, 12:36 AM | #6 |
Your Text Here
Rep 153
Like ceb said, you should have a full inspection done by a independent shop (cost you $50 or so) and have them give you a list of things that are worn, broken or could be replaced.
Then take it to the dealer and have said things replaced under warranty. |
01-13-2011, 03:07 AM | #8 |
Rep 197
about the clunkyness going through the revs, i'm thinking what you refer to is the DISA valves opening? This happens at specific rpms, 3,200 and 4,500 i believe.
01-13-2011, 03:11 AM | #9 |
Rep 229
Go through the tsb's (sib?) in the service sticky and see if any of them apply to you. Some of them they may not act on without seeing the code but it's worth the 15 minutes to check.
2007 335i, Space Gray, Black/Alum, Sports, Prem, CA, Navi, iPod
01-13-2011, 07:53 AM | #10 | |
NHTSA Nazi
28
Rep 1,983
http://www.e90post.com/forums/forumdisplay.php?f=47 |
01-13-2011, 09:05 AM | #11 | |
AC Milan Rossenari
16
Rep 158
thank you. |
01-13-2011, 09:51 AM | #12 | ||
Rep 2,783
01-13-2011, 10:10 AM | #13 |
Rep 7,089
Drives: '06 AW 330xi
Any peeling trim pieces?
You can reset the adaptive throttle by switching your car on ACC power then holding down the throttle for 30 seconds. To turn on ACC power, press the start button twice without your foot on the brake. That should solve your jerky shifts. |
01-13-2011, 10:13 AM | #14 |
Rep 5,018
Drives: VALNCYA
Have them do a full inspect on the car and any warranty-able items should be replaced....any wear you see...have them replace.
01-13-2011, 11:44 AM | #15 | |
Rep 5,627
Tom |
01-13-2011, 11:56 AM | #16 |
Rep 530
Have them scan the vehicle history and make them replace anything that hasn't been done. Oil change (allowed once per year even if miles don't say it), wiper blades, filters, flush, etc... The car's computer will tell them everything about the history.
They can also reset the transmission for you.
08 328xi - SOLD | 08 S5 | 02 S4
01-13-2011, 03:56 PM | #18 | |
AC Milan Rossenari
16
Rep 158
Edit: sorry for the double post Last edited by balgopi; 01-13-2011 at 04:49 PM.. |
01-13-2011, 05:28 PM | #19 |
Rep 14,829
If I knew it would happen 14 days out of warranty, I would have mentioned the battery seems to be weakening, although I was told by the SA after the fact BMW rarely will replace a battery under warranty, they claim it should last 5-6 years and would simply charge it.
01-13-2011, 05:39 PM | #20 |
Rep 13,122
You mignt be entitled to a free oil change
You might be entitled to a free oil change
If the oil hasn't been changed in a year regardless of the miles left on the service indicator. I would have them check for any of the common problems like broken head bolts if you have a 328 or 330. Check the oil level before and after you go in to be sure its not under filled before or after . Head bolt breakage is a known problem on the 328 and 330 I would be replacing the lifetime fluids at and Indy shop after going off warranty trans, diff, radiator , brake, power steering etc.. |
01-13-2011, 09:54 PM | #22 |
Rep 530
^ No -- not needed yet. Only once per year (I think it's once per 12 months) OR when the mileage is up. But I doubt it is unless the car was driven a lot.
