can my car catch on fire because of some new headlight bulbs
01-14-2011, 07:15 PM | #1 |
Rep 1,304
Yea kind of a stupid question but is it possible that your car can catch of fire because of your light bulb. I read a couple threads about there cars catching on fire and some people said it might have been there headlights.I was thinking of switching the oem bulbs for gp thunder bulbs because the oem's are getting weak and i'm worried about messing up something.
08 TIAG 328i
13 DGM 550 x drive Last edited by ryan970; 01-14-2011 at 08:35 PM.. |
01-14-2011, 07:25 PM | #2 |
Rep 105
if u install higher capacity bulb than indicated i think it might melt some plastic around because of heat just replace with the same bulb type.
also it will display a fault on your dashboard |
01-14-2011, 08:11 PM | #3 | |
NHTSA Nazi
28
Rep 1,983
An electrical failure causing lots of money to repair is more likely than a fire though. |
01-14-2011, 08:18 PM | #4 | |
Slow rollin
10
Rep 406
eee gads man....
Business: BMW 328i Coupe Pleasure: Ducati 1098S |
01-14-2011, 08:31 PM | #5 |
Rep 1,304
haha my bad for not making correct sentences.
08 TIAG 328i
13 DGM 550 x drive |
01-14-2011, 08:37 PM | #7 |
Rep 1,304
It's not likely to cause a electrical failure is there.
08 TIAG 328i
01-14-2011, 10:15 PM | #8 |
Rep 6,604
Drives: e92 335i
it is possible but not likely
01-15-2011, 10:40 AM | #9 |
NHTSA Nazi
28
Rep 1,983
If you use a bulb that draws a different amount of current then an electrical failure is very possible.
Our cars are, in general, very reliable, but the electrical system does not like modifications and problems may not appear right away. |
01-15-2011, 01:17 PM | #10 |
Rep 1,379
Is anyone here actually speaking with any knowlege of electrical systems? Or are they just speculating? eg "It's German therefore it must catch fire easily".
It's very unlikely that you'll overload the electrical system because it's overbuilt. You'd have to be doing really crazy things to cause an overload and fire. Your GP thunder bulbs won't cause anything to overload. Though because they use a blue coating to make them whiter the bulbs sometimes contain more fillament to make up for the loss of light output. This means that the bulb itself runs hotter. What could happen is that the plastic might melt around the bulb casing, which may cause some wires to short due to their casings melting and probably nothing will happen, or a fire might happen. Your best bet to figure out if your headlights will melt or if they are built strongly enough not to is just do a google/forum search and see if it's happened to anyone. If it hasn't then chances are that our headlights are resistant enough not to melt. The reason people were asking the guy with the car that caught fire if he had aftermarket bulbs is because that would be an easy way for BMW to blame him for starting the fire.
Clean cars are happy cars! CANON PHOTOGRAPHER |
