BIMMERPOST Universal Forums Off-Topic Discussions Board Video + PC Gaming / Computing
      01-17-2011, 12:47 PM   #1
Crisp
Crisp's Avatar
Albania
440
Drives: F95 X5M
GT5 Tuning
Share your tuning here or post it up for constructive criticism (which is what I'll be doing).
I need some suggestions for my E92 M3. The setup is not very aggressive, but the car is not staying as planted as I would like around the Nurburgring.
It did 7:16 around the ring with 2 huge mistakes but it was still very hard to control since they tail was always kicking out during BRAKING (even with a brake distribution of 7 front and 3 rear and lower in the rear than the front) and also going "air born" a bit too much to take high speed turns.
I'll post my exact setup tonight but here is the video:
<object width="400" height="224" ><param name="allowfullscreen" value="true" /><param name="movie" value="http://www.facebook.com/v/185861418109976" /><embed src="http://www.facebook.com/v/185861418109976" type="application/x-shockwave-flash" allowfullscreen="true" width="400" height="224"></embed></object>
Constructive criticism is welcomed as I am still a novice.
Edit. Damn FB video isn't working.
I'll upload it to youtube later or add me on FB. lol
Current F95 X5M; E60 M5 6spd; Mclaren 570s; Aston Martin Vantage; Ferrari FF
      01-17-2011, 01:30 PM   #2
1trip5
1trip5's Avatar
Drives: Emme Tres
2002 BMW M3  [0.00]
http://www.gt5-tuning.com/index.php?...ecial:AllPages
E46 M3
      01-17-2011, 05:21 PM   #3
Crisp
Crisp's Avatar
Albania
440
Drives: F95 X5M
Originally Posted by 1trip5 View Post
No way, that is way too low and aggressive for the Nurburgring.
He's all the way down to -20mm all around but yet the springs and dampers are no where near that mark in order to match his ride height.
That pretty much allows no suspension travel and the car will be flying all over the track if you clip the apex. (I used to have a similar setup just to see how aggressive I could go)
Maybe it's just me, but I keep it at a more "conservative" tune which allows the suspension to do it's job.
With that tune for the '07 M3, he said he's at a 7:10, but I'm already at a 7:09 with my current setup.
      01-17-2011, 06:45 PM   #4
1trip5
1trip5's Avatar
Drives: Emme Tres
2002 BMW M3  [0.00]
I should have clarified, that is a link to user setups for many cars. it was not meant to be a direct response to your question. it's a good starting point for people that are setting up their cars.
E46 M3
      01-17-2011, 08:05 PM   #5
Crisp
Crisp's Avatar
Albania
440
Drives: F95 X5M
Oh ok.
So I got a slightly better tune going...enough to get me under 7:05 but when I went online to race, the car was driving like shit and sliding all over the place as if I had sport tires not soft slicks.
The host left the aids on (although I only use TCS 1 and ABS 1) but it felt like everything was off, plus sport tires. Ever happen to you?
      01-17-2011, 09:06 PM   #6
kyleb350
kyleb350's Avatar
Drives: '21 X3MC
I've noticed when going into certain online rooms that change your driver aids, those settings will carry over to other races and single player as well, so remember to change them back.
OP, did you buy the front and rear spoilers from the GT Auto section?
      01-17-2011, 09:13 PM   #7
kyleb350
kyleb350's Avatar
Drives: '21 X3MC
I'd also like to know some good settings for a Nascar on Daytona Speedway (top speed tune). With 893hp (after break-in and oil change), I've lowered the suspension 10 mm, lowered the spoilers all the way down, and increased the top speed to 245(ish). Not sure if I should mess with camber or toe or not... any suggestions?
      01-17-2011, 10:08 PM   #8
1trip5
1trip5's Avatar
Drives: Emme Tres
2002 BMW M3  [0.00]
i generally find that maxing out front downforce and fully decreasing rear downforce helps significantly on top speed tracks.
E46 M3
      01-17-2011, 10:54 PM   #9
GregTheStig
derp
GregTheStig's Avatar
Armenia
51
Drives: a Tuk Tuk
For Daytona I take a bit of downforce out of the front and back, but not too much. For the most part I leave it like it is and I definitely don't lower it. That track is pretty bumpy and they already scrape enough as it is.
      01-18-2011, 11:14 AM   #10
Crisp
Crisp's Avatar
Albania
440
Drives: F95 X5M
This is what I used to have when it ran a 7:16 with 2 mistakes.
Now I increased the ride height by a few mm all around, brought the dampers (extension) to 5 and 6 and dampers (compression) to 5 and 4.
I increased the anti-roll bar stiffness to 4 and 4.
Did a test lap and the car ran a 7:09 with one small mistake.
Without any mistakes, the car can probably do a 7:02 - 7:05 with this setup.
      01-18-2011, 11:18 AM   #11
Crisp
Crisp's Avatar
Albania
440
Drives: F95 X5M
Yes I did (although I hate the rear spoiler, it actually helped a lot with high speed cornering).
Yea I know it does that with the aids, but I made sure they were where I wanted them.
I had the same experience again last night. It almost feels as if the car is on sport tires not slicks because everything from traction coming out of a corner to traction in the turn is effected.
I suspect it could be something else though: the option for low grip on the sides of the track. I wasn't paying attention if that option was chosen by the host.
      05-19-2011, 01:12 AM   #12
aCP
Hong Kong
Drives: FO E92 M3
Do you find the M3 understeer even without gas on through low speed corner like the first corner in Tsukuba. Whats your setting for the LSD?
      05-20-2011, 05:10 AM   #13
bluespeed117
bluespeed117's Avatar
Drives: e90 328i
2007 e90 328i  [0.00]
did a 7:05 with my setup. I messed up once that slowed me down a couple seconds. I also forgot i had 100kg ballast setup on the car Lol.
heres the setup and proof of time
Muffler Delete/ Tien S-tech Springs / De-badged /BBS LM Reps 19"/ Nexen tires/DTM M5 Front bumper/ Injen Intake/Blacklines/M-tech Rear/Custom Muffler Tips.... More mods to come
      05-20-2011, 06:12 AM   #14
wisesoul
Savoir Faire
wisesoul's Avatar
Philippines
83
Drives: 2013 BMW M5
Are u guys all stock?
Current: Alpine White F10 M5|H&R springs|12mm/10mm spacers|Eisenmann Race
Sold:Imola Yellow RS4-KW V3|MTM 10mm spacers|Hotchkis rear sway bar|APR Stage 1|Milltek Catless|RNS-E|Euro RS4 Flat bottom Steering Wheel
Sold:E46 323i
      05-20-2011, 11:53 PM   #15
UFhypzM3
allocation hunting g80/911 GTS
UFhypzM3's Avatar
Drives: '20 M2
Do you guys have some type of steering wheel/pedal setup for this game? I think it would be sickkkk
Searching for a G80 M3 allocation/911 GTS allocation
Current: '20 M2 Competition (Hockenheim Silver) - Carless from 2017-2022
Previous: '08 E92 335i 6MT (Space Grey), '05 G35 Coupe, '03 Evolution VIII, '01 Honda Prelude
      05-21-2011, 02:10 PM   #16
GregTheStig
derp
Armenia
51
Drives: a Tuk Tuk
I have a Logitech Driving Force GT set up to a card table and a folding chair It makes the game 10 times more fun.
      05-21-2011, 04:19 PM   #17
bluespeed117
Drives: e90 328i
did that time with the controller at 7 sensitivity
      05-21-2011, 04:45 PM   #18
UFhypzM3
UFhypzM3's Avatar
Drives: '20 M2
OMG im so jelly..does it have like a clutch and shit w/ shifter....ugh would be so fuN!
      05-21-2011, 04:49 PM   #19
GregTheStig
derp
Armenia
51
Drives: a Tuk Tuk
Mine only has the two pedals w/ tiny paddle shift buttons and a sequential stick shifter. I think they sell a DFGT Pro or something that comes with a clutch and an H-shifter. There are a few others that have something similar. Once mine wears out (I can feel the force feedback motor going already) one of those is on my list
